Regulator STR-58041 will this selfdistruct if
Discussion in 'Electronic Repair' started by Jim Lazzaro, Jul 29, 2004.
  1. Jim Lazzaro
    Jim Lazzaro Guest
    On TV Orion model S21 (which does not start) the power supply
    regulator STR-58041 has 329 volts on pin 3. The schematic shows it
    should have 280 volts.
    Since I haven't been able to solve this start up failure, I am now
    wondering if:
    1) the 329 volts apllied to it is sensed by the regulator as out of
    specs and therefore it does not turn itself on.
    or 2) the 329 volts is just higher because there is no current flowing
    due to the regulator being defenitely faulty.
    Note- all other checks have been done and also there are no shorts
    found, resistors have been checked etc., new caps installed.
    Please pass on your thoughts on this.
    Thanking you
    Jim
    #1
    1. Advertisements
  2. Franc Zabkar
    Franc Zabkar Guest
    On 28 Jul 2004 19:56:11 -0700, (Jim Lazzaro)
    put finger to keyboard and composed:
    >wondering if:
    Pin 3 is the collector of the chopper transistor and is connected to
    the rectified 240VAC via the primary winding of the switching
    transformer. As such it should measure 240 x 1.414 = 340VDC if the PSU
    is in the no-start state.
    >Thanking you
    >Jim
    - Franc Zabkar
    Please remove one 's' from my address when replying by email.
    Franc Zabkar, Jul 29, 2004
    #2
    1. Advertisements
  3. mo
    mo Guest
    Franc Zabkar <> wrote in message news:<>...
    Filed this reply in the wrong pigeon hole,but here goes anyway.
    It is possible that there are 2 resistors of about 120 kOhm in series
    from large capacitor to where you are supposed to find that 0.4 Volts
    on your ic.
    Isolate one end of resistors and measure resistance.
    Good luck.
    mo, Jul 30, 2004
    #3
    1. Advertisements
Similar Threads
  1. Guest
    Sony STR-DA series versus STR-DE series.
    Guest, Feb 6, 2004, in forum: Electronic Repair
    883
    Guest
    Feb 6, 2004
  2. elevman
    STR S5141G regulator IC
    elevman, Sep 15, 2004, in forum: Electronic Repair
    462
  3. motsco_ _
    6
    1,105
    motsco_ _
    Jan 19, 2005
  4. Jim Lazzaro
    Jim Lazzaro, Jul 29, 2004, in forum: Hobby Electronics
    833
  5. Timescope
    STR-Z2156A, STR-Z2154 psu ic datasheets
    Timescope, Oct 3, 2012, in forum: Datasheets, Schematics, Manuals and Parts
    729
    Timescope
    Oct 3, 2012
Loading...
Share This Page
