Reduce power of a microwave oven?
Discussion in 'Electronic Repair' started by mike, Jan 18, 2011.
  1. mike
    mike Guest
    My 27 year old microwave oven was down below 400W output and taking a long
    time to heat my coffee.
    So, I went out and bought a 1100W one.
    Big mistake.
    It works fine on coffee, but WAY overcooks small stuff.
    Yes, it has a power level setting, but the on-time is 15 seconds
    and they modulate the off-time.
    I tried to heat a frozen hamburger patty. It boils the liquid around
    the outside for 15 seconds, but the inside is still frozen.
    This really messes up the cheese stuck to it. If I leave it in
    the frozen burger, it comes out awful.
    What are my options for reducing power?
    Yes, I can stick in a pot of water to absorb energy, but I'm
    looking for a more elegant solution.
    I assume there's nothing I can do on the primary side, cause of the
    filament voltage requirements.
    Assuming I can find a switch that can take the voltage and current,
    can I switch the value of the big cap? Not much else in there to play with.
    Alternatively, there's stuff they put in the bottom of microwave popcorn
    that heats up from microwaves. What is that stuff? Maybe I can find a
    pan with that in the bottom to average out the energy over time.
    There's a "as seen on TV" serving plate that you heat in the microwave.
    It's made of granite. What is it in the granite that gets heated?
    IF I could find a square of floor tile in ceramic or granite, ceramic is
    more easily available, I could stick one of them in the bottom of the oven.
    Suggestions?
    Thanks, mike
    mike, Jan 18, 2011
    #1
    1. Advertisements
  2. Can you return the oven? You can use the argument that it's not fit for its
    intended purpose. Which it isn't.
    I always assumed variable power was simple duty-cycle variation --
    pulse-width-modulation -- over a fraction of a second. That the "on" time
    would be fixed at 15 seconds (!!!), with the off time varied, is absurd. It
    would produce exactly the effect you see.
    There's also the possibility your sample is defective.
    The stuff at the bottom of a microwave-popcorn bag is called a susceptor
    sheet. I think it's a ferrite material, but I'm not sure.
    http://en.wikipedia.org/wiki/Susceptor
    Without any food to absorb heat from the susceptor, it would probably
    overheat and burn fairly quickly.
    You might try putting a brick on the oven, on the remote chance
    fire-hardened clay absorbs microwaves. Bricks made with metallic colorants
    might be the best place to start.
    William Sommerwerck, Jan 18, 2011
    #2
    1. Advertisements
  3. mike
    mike Guest
    >> Big mistake.
    >> Suggestions?
    > RTFM to see how to set the cook power.
    Amazing!!!
    RTFM reply when I stated EXACTLY how the power setting works.
    How about RTFOP?
    mike, Jan 19, 2011
    #3
  4. mike
    mike Guest
    Nope, my inability to forecast the consequences is not the fault of the
    seller.
    Yep, that's the way most of 'em work. The problem is the filament in
    the magnetron. Much shorter and you don't get any power out cause
    the filament ain't hot yet. With enough mass inside the oven, it
    averages out pretty well. For a single frozen hamburger at 1100W, not
    so much.
    Yes, you can buy a microwave with fine-grained setting of continuous
    power at most any retailer...for 3X the price.
    They have to keep the filament hot while reducing the power. Much more
    complicated and not a commodity item >> much higher price.
    They used to make browning plates with some kind of susceptor in the bottom.
    Seems the only place you get 'em today is from TV infomercials at
    high prices or on ebay at antique prices.
    I do have a microwavable trivet that claims to be made from granite.
    Gets hot alright, but it's encased in plastic and not well coupled
    to whatever you put on it. A couple of experiments suggest that
    while it does divert significant power, it will probably overheat
    trying to do what I want.
    A cup of water solves the problem, but it's not very elegant.
    There's considerable range of microwave absorbency. I was hoping to find
    some kind of commonly available ceramic, like floor tile, that
    would work. That's why I asked for input.
    Wonder what Home Depot would think if I packed tile samples
    into the employee lounge and stuffed 'em into the microwave?
    mike, Jan 19, 2011
    #4
  5. On 1/18/2011 5:55 PM mike spake thus:
    >>> taking a long time to heat my coffee. So, I went out and bought a
    >>> 1100W one. Big mistake. It works fine on coffee, but WAY
    >>> overcooks small stuff. Yes, it has a power level setting, but the
    >>> on-time is 15 seconds and they modulate the off-time. I tried to
    >>> heat a frozen hamburger patty. It boils the liquid around the
    >>> outside for 15 seconds, but the inside is still frozen. This
    >>> really messes up the cheese stuck to it. If I leave it in the
    [snip]
    >>> Suggestions?
    > Amazing!!!
    > How about RTFOP?
    Mr. Terrell apparently shoots from the hip and never apologizes.
    Comment on quaint Usenet customs, from Usenet:
    To me, the *plonk...* reminds me of the old man at the public hearing
    who stands to make his point, then removes his hearing aid as a sign
    that he is not going to hear any rebuttals.
    David Nebenzahl, Jan 19, 2011
    #5
  6. In article <ih536g$rco$-september.org>,
    Mike-
    Does the new microwave have a Defrost option? If so, does it also cook
    for 15 seconds at full power?
    I had a small microwave back in the 70s that had a low power setting.
    My memory is a little hazy, but I think the low power setting switched a
    capacitor in series with the high voltage transformer primary. It acted
    as a ballast to reduce magnetron voltage.
    Fred
    Fred McKenzie, Jan 19, 2011
    #6
  7. mike
    PeterD Guest
    On Tue, 18 Jan 2011 20:35:49 -0500, "Michael A. Terrell"
    >> Big mistake.
    >> Suggestions?
    Or use the defrost cycle!
    PeterD, Jan 19, 2011
    #7
  8. >> Can you return the oven? You can use the argument
    >> that it's not fit for its intended purpose. Which it isn't.
    > the fault of the seller.
    If your description is correct, the oven is grossly misdesigned. You do not
    implement variable power by turning the magenetron on for 15 seconds, then
    letting it sit for a minute! I've /never/ seen a microwave oven that works
    that way. My home GE works fine, as do all those I've seen where I've
    worked.
    It
    > so much.
    I've never heard of varying a magnetron's power by adjusting its filament
    voltage! I've always ASS+U+MEd there was some way of turning the tube on and
    off by varying an electrode voltage. (Simply pulsing the anode voltage would
    produce variable output.)
    William Sommerwerck, Jan 19, 2011
    #8
  9. > Bacon, eggs, burger were some examples.
    A microwave oven is ideal for bacon, because all it needs is a thorough
    heating. Which is all a microwave oven does... It doesn't actully /cook/
    anything.
    #9
  10. mike
    Lab1 Guest
    Many new microwaves have and auto-defrost function (also usually an
    auto-reheat) that measures the humidity while firing the magnetron for
    short bursts. It runs this cyclically for a preset time based on your
    food selection and weight while it calculates the actual time it should
    take to defrost the food. Then it usually beeps once and finally runs
    the defrost cycle that it calculated.
    I find this works quite well once you get the hang of it.
    -Scott
    Lab1, Jan 19, 2011
    #10
  11. > All of the bog-standard microwave ovens that I've owned have worked
    exactly
    > like that - and it was fine when they were the 'standard' 600 or 650 watts
    > of a few years ago. However, now they are all 850 / 900 / 1000 watts, it's
    a
    > crap system of power control. The one I have at the moment, does exactly
    as
    > the poster's does when set to say 60% power. It's like 15 seconds on at
    full
    > chat, followed by 20 seconds at full off. 60% is what's needed for heating
    a
    > can of soup in a reasonable time to a reasonable temperature. And it's ok
    if
    > it's just a full liquid soup like say tomato. But as soon as you try to do
    > it with anything like perhaps vegetable, 15 seconds of microwaves at 850
    > watts, is enough to start exploding the peas or beans or barley grains,
    all
    > over the inside of the rotten thing. 600 watts didn't used to do this. If
    > you go to the next step down - ie 40% power - it takes forever to get the
    > bulk liquid of the soup up to an edible temperature.
    Fascinating. (In the correct Spock sense... "Fascinating I reserve for the
    unexpected.")
    I have a high-power GE microwave oven cum exhaust hood. Many foods -- such
    as soup or oatmeal -- must be heated at half power (give or take), or you
    get localized boiling, sometimes very quickly. I've never seen this happen
    with reduced power. The oven always acts as if the magnetron is being
    rapidly pulsed.
    May I publicly apologize for believing that manufacturers ever use the least
    bit of common sense when designing products?
    #11
  12. "Arfa Daily" <> wrote in message
    news:7qEZo.371$2...
    > "William Sommerwerck" <> wrote in message
    > news:ih6qji$7hl$-september.org...
    >> anything.
    > I seem to remember that we had this discussion once before some
    > years back. It depends on how you define the word "cook". Using the
    > traditional definition of 'preparing food by use of heat' I would contend
    > that this is exactly what a microwave oven does - or am I missing
    > something ... ? If I am, then what *is* cooking that a conventional
    > oven does differently ?
    Your perfectly logical definition seems sufficiently generic to include
    microwave ovens. In practice, "cooking" refers to either immersing
    the-thing-to-be-prepared in a cavity full of hot air...
    "Yeah, Sommerwerck -- yer mouth."
    ....(baking, roasting) or applying heat directly to it (frying) or from a
    nearby source (broiling, grilling). Microwave "cooking" does none of
    these -- it simply heats the-thing-to-be-prepared from the inside.
    Oddly, the Wikipedia article claims that microwave cooking heats food more
    evenly than any other method, when, in fact, it heats from the outside in,
    as does every other cooking method, and can be extremely uneven, if part of
    the dish is sitting in a standing-wave node.
    #12
  13. William Sommerwerck, Jan 19, 2011
    #13
  14. mike
    PeterD Guest
    On Wed, 19 Jan 2011 05:57:24 -0800, "William Sommerwerck"
    >anything.
    let's face it, most cooking is just heating.
    #14
  15. mike
    PeterD Guest
    On Wed, 19 Jan 2011 05:55:03 -0800, "William Sommerwerck"
    >worked.
    Huh? Virtually all the ones I've seen do just that: run a 10 to 15
    second on/off time cycle. The magnetron is turned on with a relay, so
    rapid cycling just begs to blow that relay.
    #15
  16. >> If your description is correct, the oven is grossly misdesigned.
    >> You do not implement variable power by turning the magenetron
    >> on for 15 seconds, then letting it sit for a minute! I've /never/ seen
    >> a microwave oven that works that way. My home GE works fine...
    I could easily test this with frozen bagels. Do you want me to? I'm not much
    in the mood.
    #16
  17. mike
    Jeff Layman Guest
    On 19/01/2011 06:39, Dave Platt wrote:
    > In article<ih5hng$bfu$-september.org>,
    >> so much.
    >> complicated and not a commodity item>> much higher price.
    > Not that much higher these days, I think. The Toshiba "inverter"
    > microwave ovens have a variable power level of this general sort, and
    > they're commodity items to the extent of being buyable at Costco and
    > probably other big-box stores. They're somewhat more expensive than
    > ovens fixed-power magnetrons, but not all that much.
    > However... I had one, and it died within a couple of years in home
    > use. Our previous microwave had lasted for a couple of decades. I'm
    > not sure whether this was an odd failure in this unit, or was
    > characteristic of Toshiba inverter microwaves in general, or just an
    > result of the "race to the bottom, in price and in quality" which
    > seems to be affecting the whole consumer-electronics business these
    > days.
    > I bought a fixed-power-output commercial-service Amana as a
    > replacement, in the hopes that it'll last rather longer than the
    > Toshiba did.
    My Panasonic has an inverter. Works OK, and and an energy meter
    confirmed that it doesn't just cycle from full power to off when running
    at lower power levels.
    But it does tempt you to experiment. Even though the guidebook warns
    against trying to "boil" a perfectly cooked egg in its shell, I thought
    it worth trying using lower power levels. The first egg was perfect,
    using a rather complicated cooking schedule. The second was very soft -
    barely cooked. The third I'd rather forget, but it took a long time to
    clean the oven, and SWMBO wasn't amused as she was standing almost next
    to the door when it was blown open. It also took me some time to repair
    the safety lock...
    Jeff
    Jeff Layman, Jan 19, 2011
    #17
  18. On 1/19/2011 9:24 AM William Sommerwerck spake thus:
    .... which should give further pause to those who claim that Wikipedia is
    full of good, accurate information ...
    #18
  19. mike
    mike Guest
    >>>> Big mistake.
    >>>> Suggestions?
    >> Amazing!!!
    >> How about RTFOP?
    > Then stick a damn glass of water in the oven to adsorb some of the
    > energy.
    You're just DETERMINED NOT TO READ the original posting...where I
    mentioned that too.
    Although, I'd not considered adsorption as a relevant process.
    mike, Jan 19, 2011
    #19
  20. "David Nebenzahl" <> wrote in message
    news:4d374867$0$2362$...
    more
    in,
    of
    It is. No one is claiming it's always absolutely perfect.
    #20
    1. Advertisements
Similar Threads
  1. Peter Rossiter
    Microwave oven - reducing power
    Peter Rossiter, Apr 4, 2004, in forum: Electronic Equipment
    5
    576
    Peter Rossiter
    Apr 5, 2004
  2. Soyrunner
    Samsung Microwave & GE Microwave oven
    Soyrunner, Sep 20, 2004, in forum: Electronic Repair
    5
    2,169
    Sam Goldwasser
    Mar 15, 2005
  3. William E Miller
    † Any suppliers of LCD glass pins?
    William E Miller, Mar 25, 2007, in forum: Electronic Components
    3
    557
  4. Replies:
    569
  5. gijoe985
    428
    OLIVE2222
    Dec 11, 2011
Loading...
