Re: using ac fuses in dc circuits
Discussion in 'Hobby Electronics' started by Phil Allison, Aug 14, 2009.
  1. Phil Allison
    Phil Allison Guest
    "lentildude"
    >I have come across some cheap ac ceramic fuses 50 amp, 100 amp and
    > wonder if is safe to use in one of my solar projects. Have a 12v
    > 200ah battery and 1000w inverter. I heard as a rule of thumb you can
    > use AC fuses at half the rating if used in DC...
    ** Half of WHICH rating ??
    ..... Phil
    #1
    1. Advertisements
  2. Phil Allison
    Phil Allison Guest
    "lentildude"
    ** Quit top posting - it is really DUMB !!
    I just found this on the net, seems ok to use them in DC;
    " The difference between an applied AC voltage or is DC voltage to a
    fuse; The fuse-links are on principle suitable for use at alternating
    and direct voltage. The breaking capacity at direct-voltage is however
    considerably lower than the one at alternating voltage. The
    performance of the fuse-link at direct-voltage mainly depends on the
    size of the time-constant = L/R of the load circuit.
    Glass body fuses seem to have a DC voltage rating half that of a
    maximum AC voltage rating [in general]. While Ceramic cases appear to
    have the same maximum voltage rating regardless of the operating
    voltage, AC or DC.
    http://www.interfacebus.com/fuse-operation-ac-dc-voltages.html "
    ** Tells you almost nothing.
    The fuse "rating" being talked about is the fuse's " maximum breaking
    capacity " in amps - the only way to know that is look up the maker's
    published data !!!
    The number will vary with the actual circuit voltage and also depends on
    whether the voltage is AC or DC.
    Mostly, makers just specify the breaking capacity as so many amps at 250
    volts AC - usually the figure for 12 volts DC is the same.
    Your problem is that you have no idea what breaking capacity is needed -
    cos it relates to the worst case scenario FAULT current and not the normal
    running current level.
    ...... Phil
    #2
    1. Advertisements
  3. Phil Allison
    Eeyore Guest
    I you don't understand the subject, don't rely on the net.
    Graham
    due to the hugely increased level of spam please make the obvious adjustment
    to my email address
    Eeyore, Aug 14, 2009
    #3
    1. Advertisements
Similar Threads
  1. Replies:
    541
    Jasen Betts
    Aug 4, 2007
  2. AC-DC and DC-AC converter design
    , Feb 1, 2004, in forum: Misc Electronics
    365
  3. Andrew Gabriel
    Fuses and branch circuits
    Andrew Gabriel, Aug 22, 2006, in forum: Electrical Engineering
    373
  4. William Wixon
    OT re-used re-cycled re-purposed re-paired stuff. interesting, funny
    William Wixon, Jul 31, 2009, in forum: Home Power and Microgeneration
    3
    861
    RBnDFW
    Aug 3, 2009
  5. vCraZz
    dc-dc step up circuits in series?
    vCraZz, Jun 12, 2011, in forum: General Electronics Chat
    11
    899
    vCraZz
    Jun 14, 2011
Loading...
