Re: Testing Low Oil Sensor on Honda GX Engine
Discussion in 'Home Power and Microgeneration' started by scott, May 13, 2005.
  1. scott
    scott Guest
    "Ulysses" <> wrote in
    news::
    > My generator with a Honda GX270 engine suddenly stopped running. My
    > first thought was that it was low on oil. I checked it and it seemed
    > to be within the acceptable level but filled it to full. Didn't help.
    > I took out the spark plug and grounded it and the spark looked weak
    > and intermittant. I tried switching the ON/OFF switch a few times and
    > jiggled the wires but no noticeable improvement. I checked to see if
    > anything was grounding out but could find nothing. I tried
    > disconnecting the wires to the ON/OFF switch and the low oil sensor
    > but no luck.
    > There is a small (1 inch square) metal box that is connected to the
    > ON/OFF switch and the low oil sensor. Is this the electronic ignition
    > module? I looked in my Hayne's Small Engine Repair manual but it
    > didn't show such a thing. It also mentioned the existance of low oil
    > sensors but had no info for the Honda engines. The owner's manual
    > that came with the engine doesn't even suggest checking the oil if the
    > engine won't start!
    > Is there a way to test the low oil sensor or bypass it temporarily to
    > check it? Is there a way to test the ignition module? The ignition
    > coil does not appear to be damaged in any way and is not loose or
    > obviously out of adjustment but I'm going to try to check it with an
    > ohmmeter.
    > The engine was running normally and suddenly stopped. I started it
    > again and it ran for a few minutes and then suddenly stopped again.
    > It acts like it has a loose connection or something but I can't find
    > any.
    > Any suggestions?
    > Thanks.
    The small metal box is a signal conditioner for the shutoff sensor in the
    crankcase, it is probably just a scr that once is triggered, latches to
    make sure that the engine dies and also lowers the load on the reed switch
    in the sensor so it won't be damaged when vibration causes the switch to
    repeatedly open and close, damaging it and causing loss of protection. I
    work in a mower shop, we used to see reel type mowers that the customer
    told us would cut out at each turn for weeks as the switch was repeatedly
    triggered by slosh .Later on, this was the engine that died from lack of
    oil when the sensor failed.
    To test the ignition separately from the sensor and all other parts, just
    disconnect the small gauge wire from the coil that hooks to the stop switch
    and the sensor. It is very simple, they just ground the ignition primary
    (small) wire to kill the engine.
    You are probably just seeing normal operation when oil gets low. When
    the engine starts, oil is sprayed by the oil slinger all through the
    engine, and what is om the crankcase walls lowers the level a small amount,
    shutting off the engine. Engine dies, oil runs back to bottom. switch
    opens, and it will restart.
    Full oil level is top of the threads, about to run out. I havbe seen
    engines that will die at three threads below full (threads inside the oil
    fill hole).
    Proper spark should be white or blue when viewed indoors as in a garage
    out of direct sun, and should jump at least a 3/8" gap- take a old plug, cu
    off the ground electrode and you have a tester, the spark should jump from
    the center electrode to the outside and you should be even able to hear a
    good strong spark. Weak, erratic and yellow colored spark indicates a
    problem.
    Good luck
    Scott
    scott, May 13, 2005
    #1
    1. Advertisements
Similar Threads
  1. Shaine
    619
    Shaine
    Jan 27, 2007
  2. Andy Hunt
    Peak oil/oil crash
    Andy Hunt, Jan 4, 2004, in forum: Home Power and Microgeneration
    27
    914
    Arnold Walker
    Feb 12, 2004
  3. Re: Testing Low Oil Sensor on Honda GX Engine
    , May 13, 2005, in forum: Home Power and Microgeneration
    2,405
    scott
    May 14, 2005
  4. sno
    Peak oil/oil prices.....???
    sno, Apr 19, 2008, in forum: Home Power and Microgeneration
    522
    Roland Mösl
    Apr 20, 2008
  5. Stephany Alexander
    Purchasing a Honda 2200 watt generator -- low prices?
    Stephany Alexander, Mar 3, 2011, in forum: Electronic Basics
    1,252
    Tom Biasi
    Mar 4, 2011
Loading...
