Re: Problems with DSC Power632/PC1555RKZ System
Discussion in 'Security Alarms' started by Frank Olson, Aug 19, 2005.
  1. Frank Olson
    Frank Olson Guest
    "nospam4me" <> wrote in message
    news:4ldNe.9773$...
    > My house came with a DSC Power632 using PC1555RZK keypads and is causing
    > trouble. I had lost power during the hurricanes last year and the battery
    > was drained. I took the battery out and kept the system running without
    > backup battery for a while. Then, something happened and now one keypad
    > has system light constantly on and it beeps ~2 times a minute. The other
    > keypad has all the numbers lit up, no indicator light lit, and does not
    > beep. The one with the system light only responds to *+5 or 7 to decrease
    > the tone of the beeps and the other keypad does not respond to anything.
    > Any idea from this description what the problem is?
    > Unfortunately the paperwork that came with the house is not helpful. Are
    > there fuses or circuitboard batteries that need to be changed?
    > I would like to understand if the board is damaged or if I am just missing
    > some information to reset the system. I put in a new battery, but it did
    > not fix the problem.
    > While I know many would encourage calling a service to do it (like the
    > only instruction in the users guide), I cannot do that right now. We had
    > called a company out to fix other hurricane damage and they sent out a guy
    > with mental problems that really scared my wife. She doesn't want us to
    > bring anyone else out to work on the house, so I have to either fix or
    > replace this myself. Any help would be appreciated.
    > Thanks,
    > Steve
    > Part Number on the board: 1555MX-50-300UL
    Power the board down. Check to make sure all the terminal connections are
    tight (particularly the keypads). You should have two black, two red, two
    yellow and two greens all terminated to the appropriate locations listed on
    the board. Drop the keypads and make sure all the wires are hooked up and
    the terminal screws are tight as well.
    After you've done this, power the system back up. Make sure you obtain a
    new 12 volt 5 AH battery (or 7.5 AH if the can's big enough) and connect it
    to the approriate red and black wires.
    Good luck!!!
    #1
    1. Advertisements
Similar Threads
  1. Ray Pata
    3,739
    Frank Olson
    Jul 10, 2003
  2. Bernard
    problems with DSC 864 and DLS 2002 software
    Bernard, Dec 27, 2003, in forum: Security Alarms
    31
    3,305
    Bernard
    Dec 29, 2003
  3. Steve
    Upgrade problems from DSC1550 to Power632
    Steve, Oct 4, 2004, in forum: Security Alarms
    381
    alarman
    Oct 4, 2004
  4. Brandon
    Programming Power632 for ContactID reporting
    Brandon, Jan 29, 2006, in forum: Security Alarms
    14
    860
    Mark Leuck
    Feb 1, 2006
  5. alp
    dsc 5501 and dsc 5500 keypads
    alp, Apr 24, 2007, in forum: Security Alarms
    6
    1,715
    Tommy
    Apr 25, 2007
Loading...
Share This Page
