Re: Paragon Plus
Discussion in 'Security Alarms' started by Roger, Jun 11, 2005.
  1. Roger
    Roger Guest
    If you check the Pyronix website (www.pyronix.com) you can download Paragon
    Plus USER manual. To get the INSTALLER manual you have to have login
    priviliges. I don't believe these are given to home users. I can get you an
    installer manual, although this will not be until Monday.
    My tip would be to wait until you get the manual, then read-off and write
    down the current settings before attempting to reset the panel totally. If
    all else fails then you have a record of how the panel was originally setup.
    "BIG NIGE" <> wrote in message
    news:zVoqe.10274$...
    > If you can post an e-Mail Address I will scan and send but it will not be
    > tonight
    > Be Careful not to post your exact e-mail address alter it and give me
    > instructions on how to correct it
    > Default programming is
    > ALL PROGRAMS
    > Zone 1 = Entry/Exit (starts entry timer)
    > Zone 2 =Access ( switches off whilst entry timer is running to allow you
    > to
    > get to the keypad)
    > Zones 3,4,5,6 are ALL Immediate
    > Entry/Exit time is 30 Seconds
    > Siren time is 20 minutes before re-set & re-arm.
    > "Chris" <> wrote in message
    > news:hLoqe.18381$%...
    >> news:VCoqe.10049$:
    >> > To Default ALL the Programming
    >> > I will assume that you have located the main control unit and are not
    >> > working from a remote keypad
    >> > Remove mains power (assuming that the battery in the panel is ok then
    >> > the outside siren should NOT sound)
    >> > Loose small pozi screw at top of main control unit (do not remove
    >> > fully only unscrew enough to allow top of front to swing forward ) you
    >> > may need to get your fingernails in as they can be a bit tight. AS
    >> > you swing it forward it will become unattatched at the bottom (BE
    >> > CAREFUL THAT THE BATTERY DOES NOT FALL OUT AS YOU DO THIS) It should
    >> > be held in place with a strap but they often are not.
    >> > Disconnect the battery from the connectors (at this point the
    >> > External SIREN should sound)
    >> > Hold in buttons 1 & 4 and re-connect battery &/OR mains you should now
    >> > have default codes AND programming
    >> > news:Xpoqe.19529$...
    >> >> I dont have a PDF of the manual (which includes instructions on how
    >> >> to default the programming
    >> >> I want to avoid defaulting the programming if possible atm so that we
    >> >> can check on the programming already installed.
    >> >> To default the codes you have to default ALL programming.
    >> >> Has the Back page of your engineers manual been filled in with the
    >> >> zones, how they are programmed and the timers etc
    >> >> news:Lboqe.18263$%...
    >> >> > >> You say that you know the limited user code but not the master
    >> >> > >> code or the engineers code
    >> >> > >> I will assume that it is 5678 that you are using because the
    >> >> > >> original installer dropped a clanger and didnt change it.
    >> >> > >> as you are aware the original master code was 1234.
    >> >> > >> As they didnt seem to know what they were doing we will check to
    >> >> > >> see if
    >> >> > > the
    >> >> > >> original engineers code is still in rather than defaulting the
    >> >> > >> whole
    >> >> > > system
    >> >> > >> straight off.
    >> >> > The limted user code i have is not the default 5678. I really
    >> >> > think i need the installers manual and the method to default the
    >> >> > system, If nto can you recommend anyone local to me who can come
    >> >> > out and sort it for
    >> > me?
    >> >> > Preferably for the price of a few pints!! :)
    >> Ok i'll give it a try but how do i then re-programme the different PIR's
    >> to make the entry/exit zones, immediate activation etc. Or what is the
    >> default programme set to?
    >> If you could scan the manual or something i will give you an e-mail
    >> address to send it to.
    >> Thanks again
    >> Chris
    Roger, Jun 11, 2005
    #1
    1. Advertisements
Similar Threads
  1. Joerg
    43
    1,978
    Archimedes' Lever
    Dec 19, 2008
  2. Work
    Paragon RKP Alarm
    Work, Oct 15, 2003, in forum: Security Alarms
    6
    2,883
    BIG NIGE
    Oct 18, 2003
  3. Paragon Plus - mains spike
    , Sep 1, 2005, in forum: Security Alarms
    5
    728
    Paul Ekins
    Sep 3, 2005
  4. HappyLad
    3
    6,370
    Scottshere
    Apr 30, 2010
  5. graybabs
    Paragon Plus alarm
    graybabs, Jul 12, 2013, in forum: Datasheets, Schematics, Manuals and Parts
    600
    zenith
    Jul 16, 2013
Loading...
Share This Page
