Re: Panasonic Shaver NiMH battery
Discussion in 'Electronic Repair' started by nanu, Nov 24, 2003.
  1. nanu
    nanu Guest
    Hello Group,
    I have a Panasonic ES8066 Linear Shaver with a set of NiMH
    batteries that are getting weak. My question is: can I buy exact
    replacement batteries to fit in this thing or do I have to buy some
    tabbed batteries and solder posts on to them to make it fit in the
    odd-ball holders that are in this razor. If someone has the p/n's of
    these batteries I'd appreciate it. Regards.
    After re-reading my post I realize some things need
    clarification. I've opened up this shaver (surprisingly easy
    considering it is waterproof, just remove 2 screws, pull on the base
    of the shaver and you're in) and found 2 AA size batteries that are
    marked NiMH Panasonic. These cells are typical AA except that they
    have single contact pins welded on each end. They look like
    fluorescent tube pins but maybe a little smaller than one of the pins
    on a typical 40 watt fluorescent tube.
    It was interesting to see the inductive charging transformer
    secondary inside the razor. This shaver has no exterior electrical
    connections for the charger, it just sits in its' inductive charging
    base. Panasonic does not provide any information on this battery, they
    want you to send the shaver to a Panasonic repair facility for battery
    replacement. I would love to know what the p/n and source info for
    these batteries are. Thanks.
    nanu, Nov 24, 2003
    #1
    1. Advertisements
  2. On Mon, 24 Nov 2003 01:49:27 GMT, nanu <> wrote:
    >Hello Group,
    Since they are standard sized AA NiMh any recent 1600mAh and over
    consumer should work just as well. Like Li-ion, NiMh can be
    charged-discharged at any point.
    Overcharging should be avoided for longest cell life but unlike
    Li-ion is not dangerous unless at a very high rate which that
    shaver charger cannot provide of course. It is unlikely that a
    consumer product used the very latest high capacity cells so
    1600mAh AAs should ensure no overcharge. If they gets warm it's
    overcharging. Better still, can the charge current be measured?
    H. Dziardziel, Nov 25, 2003
    #2
    1. Advertisements
  3. DaveC
    DaveC Guest
    On Sun, 23 Nov 2003 17:49:27 -0800, nanu wrote
    (in message <>):
    Do a 'net search for NIMH and 18650.
    DaveC
    This is an invalid return address
    Please reply in the news group
    DaveC, Nov 25, 2003
    #3
    1. Advertisements
Similar Threads
  1. nanu
    nanu, Nov 23, 2003, in forum: Electronic Repair
    2,237
    Jerry G.
    Nov 23, 2003
  2. DaveC
    14
    9,333
  3. nanu
    825
    news.rcn.com
    Jul 3, 2006
  4. b
    GRUNDIG SHAVER - battery problem?
    b, Nov 11, 2007, in forum: Electronic Repair
    7
    722
  5. shiekh
    New batteries for a Panasonic shaver
    shiekh, Dec 9, 2011, in forum: Electronics Repair
    1,063
    shiekh
    Dec 9, 2011
Loading...
Share This Page
