Re: How to default a simon 3 panel
Discussion in 'Security Alarms' started by Jim, Oct 30, 2006.
  1. Jim
    Jim Guest
    Hi, this works with a simon 2 and may work for a 3
    Reset Memory to the Factory Defaults
    If it becomes necessary to set all programming back
    to the factory defaults, do the following:
    1. Open the Control Panel cover.
    2. Unplug the transformer and the battery.
    3. Simultaneously press Cancel, Clock Set, and
    Minutes.
    4. Restore power to the panel with either the battery
    or the transformer while pressing these three buttons.
    5. Plug in the transformer or connect the battery.
    NOTE: If Phone Lock is on, options 04, 05, 06, 08, 09,
    12, and 13 will not reset to their defaults.
    sonitrol via HomeKB.com:
    > Hello all. Just found this site. I Just bought a house it has an adt
    simon
    > 3 panel installed.
    > I'd like to default the program. No one has the master or user code.
    > TIA
    > Message posted via HomeKB.com
    > http://www.homekb.com/Uwe/Forums.aspx/security-alarms/200610/1
    Jim, Oct 30, 2006
    #1
    1. Advertisements
  2. Mark Leuck
    Mark Leuck Guest
    "Jim" <> wrote in message
    news:...
    > Minutes.
    The Simon 3 uses Minutes+
    Mark Leuck, Oct 31, 2006
    #2
    1. Advertisements
Similar Threads
  1. Grzegorz Jakubowski
    ADC MCP3304 howto increase input voltage up to 20V (default 5V)
    Grzegorz Jakubowski, May 22, 2005, in forum: Electronic Basics
    1,299
    Chris
    May 22, 2005
  2. Fred
    Protel99SE Default designator text height
    Fred, May 23, 2005, in forum: Electronic Design
    753
    Rene Tschaggelar
    May 23, 2005
  3. Xaghra
    Samsung TV Default settings
    Xaghra, Oct 16, 2003, in forum: Electronic Repair
    3
    2,567
    Jason D.
    Oct 17, 2003
  4. Clint Sharp
    Philips Zenia Default pin?
    Clint Sharp, Sep 12, 2004, in forum: Electronic Repair
    847
    Clint Sharp
    Sep 12, 2004
  5. Chub
    default GE Simon installer code
    Chub, Mar 12, 2006, in forum: Security Alarms
    3
    6,162
    Robert L Bass
    Oct 22, 2006
Loading...
Share This Page
