Re: Fuse label colors
Discussion in 'Electrical Engineering' started by TimPerry, Oct 4, 2006.
  1. TimPerry
    TimPerry Guest
    Administrator Carl wrote:
    > Can some one help me out, Im trying to figure out what the color of
    > the fuse labels mean.
    > example cartrige fuse 15 amps and under has a navy blue label
    > above 15 amps is a green label
    > 600 volt fuse is a red label
    > edison base plug fuse 15 amps and under has blue color
    > 20 amp plug fuse has orange color
    > 25 amps to 30 amps has green color
    > Does anyone know anything further about fuses. Thanks
    current is color blind. just read the values.
    #1
    1. Advertisements
  2. TimPerry
    Guest
    On Wed, 4 Oct 2006 10:21:21 -0400, "TimPerry"
    Bussman does talk about color coding their fuses a few times on the
    web site but I got tired of looking before I found the color code
    chart. I know there does seem to be a plan..
    , Oct 4, 2006
    #2
    1. Advertisements
  3. TimPerry
    TimPerry Guest
    color coding makes sense on parts that are so small the numbers would be
    tiny and parts that heat (like resisters) where the marking may burn.
    it also makes sense for automotive type fuses to be colored. the average
    user can more easily replace a red fuse with a red fuse and get it right.
    on large fuses there is plenty of room to indicate current, voltage, and
    type with no ambiguity.
    TimPerry, Oct 5, 2006
    #3
  4. TimPerry
    Guest
    On Thu, 5 Oct 2006 00:39:31 -0400, "TimPerry"
    Bussman implies that less than qualified people may be installing
    fuses and it is easier to replace a red one with a red one.
    I think it is a similar intent to the type S adapters in plug fuse
    panels.
    , Oct 5, 2006
    #4
    1. Advertisements
Similar Threads
  1. BrianAlex
    5
    1,007
    hr(bob)
    Jan 6, 2009
  2. William Wixon
    OT re-used re-cycled re-purposed re-paired stuff. interesting, funny
    William Wixon, Jul 31, 2009, in forum: Home Power and Microgeneration
    3
    826
    RBnDFW
    Aug 3, 2009
  3. GreenTea
    Simple 50mA fuse, but not using a Fuse.
    GreenTea, Sep 1, 2010, in forum: Circuit Help
    24
    2,750
    (*steve*)
    Sep 19, 2010
  4. GeetarGal
    Can I replace a glass fuse with a ceramic fuse?
    GeetarGal, Mar 5, 2014, in forum: Electronics Repair
    4
    5,283
    Arouse1973
    Jun 28, 2015
  5. Riffdex
    Blown Fuse = No Fuse?
    Riffdex, Oct 15, 2014, in forum: Circuit Help
    419
    KrisBlueNZ
    Oct 15, 2014
Loading...
