Re: Dell W3000 Problem with Power Supply
Discussion in 'Electronic Repair' started by Franc Zabkar, Aug 9, 2008.
  1. Franc Zabkar
    Franc Zabkar Guest
    On Fri, 8 Aug 2008 22:52:43 GMT, put finger to keyboard
    and composed:
    >I thought I had repaired this Dell W3000's power supply , but
    >after about 20-30 minutes the power light goes out (no video or audio)
    >and the power light comes back on (sound and video returns for a sec.).
    >IOW, the power goes off and then back on. Over and over again with a few
    >seconds in between.
    >All the voltages appear to be correct. I'm just not sure if it's the power
    >supply or
    >logic board. I replaced the bridge Rect.(it was shorted), 20N60 Transistor
    >(shorted), Controller IC (shorted). and a couple of
    >Schottky Diodes. This could be heat related.
    >Any help or direction on this would great!!!!
    >TIA
    No specific help, but some general ideas ...
    Assuming the Schottky diodes are on the secondary side, then it might
    pay to see what's connected to those rails.
    Otherwise, if you think the uP may be shutting down the supply, then
    try to locate a PS_ON pin.
    If it's a thermal problem, then try to narrow it down with some spray
    freeze and a hair dryer.
    As a matter of course I'd check the ESR of all the electrolytic caps.
    What is the part number of the PWM controller IC? Perhaps its
    datasheet has an application circuit.
    - Franc Zabkar
    Please remove one 'i' from my address when replying by email.
    #1
    1. Advertisements
  2. Franc Zabkar
    Franc Zabkar Guest
    On Mon, 11 Aug 2008 14:46:34 GMT, put finger to
    keyboard and composed:
    >The primary side controller is a MC33262PG.
    That's a power factor correction controller:
    http://www.onsemi.com/pub_link/Collateral/MC34262-D.PDF
    There must be an additional PWM circuit to drive the chopper
    transistor for the switchmode transformer.
    >Switching MOSFET: 20N60S5
    >The secondary schottky diodes (2): DSSK60-018A 180v 2X30A ...
    Could it be that an excessive load on this particular rail is the root
    cause of your problem?
    - Franc Zabkar
    Franc Zabkar, Aug 11, 2008
    #2
    1. Advertisements
  3. Franc Zabkar
    Franc Zabkar Guest
    On Wed, 13 Aug 2008 14:59:06 GMT, put finger to
    >It also uses a least one ICE2AS01 controller IC.
    >It may have more, but I don't remember right off.
    That IC has its own internal overload protection but no external
    on/off control. I was wondering whether the PSU had some control pin
    that was being triggered by a fault condition on the logic board. I
    notice that a lot of people are having power-up problems with your
    particular model. One vendor is offering a replacement logic board as
    a solution.
    Here is the datasheet for the PWM controller IC:
    http://datasheet.digchip.com/216/216-12321-0-ICE2AS01.pdf
    - Franc Zabkar
    Franc Zabkar, Aug 13, 2008
    #3
    1. Advertisements
Similar Threads
  1. Brad Curfman
    13
    2,647
    Albert Grennock
    Sep 17, 2005
  2. mikercana1
    9
    1,045
  3. Mark
    Dell DJ Dell pocket DJ battery replacement
    Mark, Oct 27, 2007, in forum: Electronic Repair
    2,073
  4. Dell W3000 problems
    , Feb 11, 2009, in forum: Electronic Repair
    1,230
  5. William Wixon
    OT re-used re-cycled re-purposed re-paired stuff. interesting, funny
    William Wixon, Jul 31, 2009, in forum: Home Power and Microgeneration
    3
    798
    RBnDFW
    Aug 3, 2009
Loading...
