Re: Calculating LED voltage drop
Discussion in 'Electronic Basics' started by John G, Aug 9, 2003.
  1. John G
    John G Guest
    I don't think you can calculate the voltage drop of a LED.
    It depends on the construction and comes from the LED manufacturer's data
    sheet and is determined by the construction theniques. Super bright LEDS
    have a higher forward voltage than others.
    You only need to calculate a resisance to go with a particular LED and
    supply voltage.
    Try here http://www3.telus.net/chemelec/Calculators/LED.htm
    John G
    Wot's Your Real Problem?
    "bob cannetti" <> wrote in message
    news:...
    > I am having trouble understanding how to calculate the specific
    > voltage drop of an LED. Can anyone clarify this for me? Thanks so
    > much.
    John G, Aug 9, 2003
    #1
    1. Advertisements
  2. bob cannetti
    bob cannetti Guest
    Does the "Voltage Drop" of an LED vary directly with the amount of
    current going thru it? If not, what are the common voltage drops for
    different LED's?
    thanks, bob.
    "Kevin Aylward" <> wrote in message news:<Ap1Za.12776$>...
    > You can, but its a bit tricky. There is a formular for the Vsup.D.R.
    > circuit here
    > http://www.anasoft.co.uk/EE/widlarlambert/widlarlambert.html
    > > data sheet and is determined by the construction theniques. Super
    > > bright LEDS have a higher forward voltage than others.
    > Yes. But its one generic formula.
    > Id = Is.exp(Vd/Vt.N)
    > Vd is the diode voltage, N a constant (~1-5 for leds), Vt is the thermal
    > voltage.
    > Kevin Aylward
    > SuperSpice, a very affordable Mixed-Mode
    > Windows Simulator with Schematic Capture,
    > Waveform Display, FFT's and Filter Design.
    bob cannetti, Aug 10, 2003
    #2
    1. Advertisements
  3. >
    >> circuit here
    >> thermal voltage.
    Well, yes, thats what the above equation means.
    Vd = vt.N.ln(Id/Is)
    > different LED's?
    However, because of the log variation, it doesn't vary very much. If the
    current changes by a factor of 10:1, the voltage only changes by 60mv.
    Typical led voltages are 2-3 volts at their specified operating current.
    Kevin Aylward
    Kevin Aylward, Aug 10, 2003
    #3
  4. cpemma
    cpemma Guest
    > different LED's?
    > thanks, bob.
    You'll find Vf : If curves in the Kingbright datasheets
    http://www.kingbright.com/product/h...on=english&file=detailcategory&PriCategory=13,
    or at any other led maker's.
    A typical blue will drop about 3.4v @ 2.5mA, 3.7v @ 10mA and 4.2v @ 30mA.
    White and some pure green are in the same ballpark, red, orange, yellow,
    amber and other greens are around 1.8v @ 5mA up to 2.2v @30mA.
    It does vary with the exact chemistry, so check the datasheet for accuracy.
    cpemma, Aug 10, 2003
    #4
    1. Advertisements
Similar Threads
  1. Archimedes
    Calculating the Voltage Drop of the LM386
    Archimedes, Mar 30, 2008, in forum: Electronic Basics
    9
    1,156
    Phil Allison
    Mar 31, 2008
  2. Robert Murphy
    High voltage drop LED on computer MB
    Robert Murphy, Mar 16, 2005, in forum: Hobby Electronics
    643
    Robert Murphy
    Mar 17, 2005
  3. GarethAdams
    LED voltage drop
    GarethAdams, Mar 22, 2009, in forum: Electronic Basics
    8
    2,528
    GarethAdams
    Mar 25, 2009
  4. Wayne.
    Current/Voltage drop when LED blinks
    Wayne., Jul 16, 2009, in forum: Hobby Electronics
    7
    1,408
    Bob Larter
    Jul 22, 2009
  5. onpiopah
    Basic voltage drop question across LED
    onpiopah, Jul 10, 2013, in forum: General Electronics Chat
    272
    (*steve*)
    Jul 11, 2013
Loading...
