Re: Adjusting convergence on Sony Trinitron monitor
Discussion in 'Electronic Repair' started by David Nebenzahl, Feb 28, 2010.
  1. On 2/27/2010 9:48 PM Michael Shell spake thus:
    > On Sat, 27 Feb 2010 20:25:26 -0800
    > David Nebenzahl <> wrote:
    >> Well, I tried cleaning the dust out of my Dell-branded Trinitron tube.
    >> In so doing I seem to have knocked the convergence out of whack, even
    >> though I was really careful vacuuming around the CRT.
    >> There's an on-screen convergence control, but even with it cranked all
    >> the way over (to 100/100 for the horizontal control, 76 for the
    >> vertical), there are still highly visible "ghosts" on screen.
    > Try demagnetizing it first, especially if your monitor has a built-in
    > degaussing button. The next step is to degauss with an external
    > demagnitizer. There are TV degaussing coils for this (check Ebay), but
    > you might be able to make do with something like a bulk tape eraser
    > if you already have one.
    No bulk eraser, but I do have a couple of tape head demagnetizers;
    wonder if they'd do any good. But the monitor has a built-in degausser
    anyhow.
    > Color convergence problems will show up as red, blue or green outlines
    > and/or duplicate images - like when the colors don't align on newspaper
    > comic sections. If the ghosts you see are not in different colors,
    > then it is not a convergence problem. The focus control is often very
    > easy to unintentionally turn although a misadjusted focus control
    > generally causes blurriness rather than ghosts.
    It's definitely a convergence problem. I can see the colors shifting
    when I adjust the on-screen convergence control, but not far enough to
    eliminate the ghosts (which are definitely in different colors). The
    focus is fine.
    You were wrong, and I'm man enough to admit it.
    - a Usenet "apology"
    #1
    1. Advertisements
  2. > There's an on-screen convergence control, but even with it
    > cranked all the way over (to 100/100 for the horizontal control,
    > 76 for the vertical), there are still highly visible "ghosts" on screen.
    My ViewSonic with a Diamondtron CRT also has two on-screen convergence
    controls. However, I suspect they're for tweaking. There are almost
    certianly other convergence controls within the monitor. You probably kocked
    one loose (so to speak) during cleaing.
    William Sommerwerck, Feb 28, 2010
    #2
    1. Advertisements
  3. "David Nebenzahl" <> wrote in message
    news:4b8a0cd8$0$2363$...
    > No bulk eraser, but I do have a couple of tape head demagnetizers; wonder
    > if they'd do any good. But the monitor has a built-in degausser anyhow.
    > It's definitely a convergence problem. I can see the colors shifting when
    > eliminate the ghosts (which are definitely in different colors). The focus
    > is fine.
    If it does relate to degaussing, the built-in coil, while not strong enough
    to fix it on one or two tries, might get the job done over the course of
    time, which is to say, a certain number of degauss cycles. Sony CRT's can be
    damaged by conventional hand held coils, though in practice I've not seen
    this happen. I think that particular caution only applied to their larger
    CRT's.
    Mark Z.
    Mark Zacharias, Feb 28, 2010
    #3
  4. Baron
    Baron Guest
    Mark Zacharias Inscribed thus:
    >>>> tube. In so doing I seem to have knocked the convergence out of
    >>>> whack, even though I was really careful vacuuming around the CRT.
    >>>> all the way over (to 100/100 for the horizontal control, 76 for the
    >>> built-in degaussing button. The next step is to degauss with an
    >>> external demagnitizer. There are TV degaussing coils for this (check
    >>> Ebay), but you might be able to make do with something like a bulk
    >>> tape eraser if you already have one.
    >> degausser anyhow.
    >>> outlines and/or duplicate images - like when the colors don't align
    >>> on newspaper comic sections. If the ghosts you see are not in
    >>> different colors, then it is not a convergence problem. The focus
    >>> control is often very easy to unintentionally turn although a
    >>> misadjusted focus control generally causes blurriness rather than
    >>> ghosts.
    >> to eliminate the ghosts (which are definitely in different colors).
    >> The focus is fine.
    > enough to fix it on one or two tries, might get the job done over the
    > course of time, which is to say, a certain number of degauss cycles.
    > Sony CRT's can be damaged by conventional hand held coils, though in
    > practice I've not seen this happen. I think that particular caution
    > only applied to their larger CRT's.
    > Mark Z.
    Simply rotating the screen 15 - 20 degrees is enough to cause colour
    patches to come and go in the corners on my Trinitron tubed iiyama.
    The Trinitron tubes seem to be very sensitive to any magnetic
    disturbance.
    Best Regards:
    Baron.
    Baron, Feb 28, 2010
    #4
    1. Advertisements
Similar Threads
  1. Looking for help
    Help: Adjusting brightness on IBM (Sony) monitor
    Looking for help, Apr 8, 2004, in forum: Electronic Repair
    690
    Ian D
    Apr 9, 2004
  2. Looking for help
    Help Adjusting brightness on IBM (Sony) monitor
    Looking for help, May 1, 2004, in forum: Electronic Repair
    4
    853
    Andy Cuffe
    May 4, 2004
  3. 427Cobra
    3
    537
    427Cobra
    Sep 3, 2004
  4. Steve
    Adjusting monitor focus: Sun/Sony GDM-5010 PT
    Steve, Aug 17, 2005, in forum: Electronic Repair
    5
    566
    Remove _ for valid address
    Aug 21, 2005
  5. Jason D.
    776
    Jim Land
    Oct 31, 2006
Loading...
Share This Page
