RCA vertical IC
Discussion in 'Electronic Repair' started by Golf, Jun 24, 2006.
  1. Golf
    Golf Guest
    I am trying to locate a replacement vertical IC for an RCA model F32665
    - chassis CTC203CH3. The IC is a TDA817. I have located a TDA8170, but
    I'm not sure if this is the same component. I have been told that some
    RCA components can only be purchased by RCA through an authorized
    service center, which I am not. Hoping someone here has some info about
    this for me. Thankyou group.
    Golf, Jun 24, 2006
    #1
    1. Advertisements
  2. Scott Lane
    Scott Lane Guest
    "Golf" <> wrote in message
    news:...
    Search for TDA817 here http://www.alldatasheet.com/ and see if you can id
    the part. They list 10 or so different types, might find it here.
    Scott Lane, Jun 24, 2006
    #2
    1. Advertisements
  3. ian field
    ian field Guest
    news:...
    The 4 numeral choice is the more likely.
    ian field, Jun 24, 2006
    #3
  4. Golf
    Golf Guest
    Thankyou for the reply, but I would like to know a more definite answer
    before purchasing the IC. Thanks again.
    Golf, Jun 25, 2006
    #4
  5. Scott Lane
    Scott Lane Guest
    news:...
    Can also go to partstore.com enter Brand and Model number and get a list of
    parts available. Look thru the list for a vertical IC. Can also look at
    similar models and look thru the parts list. Once you ID the part you can
    shop around for the lowest price, usually at electronix.com
    Scott Lane, Jun 25, 2006
    #5
  6. Scott Lane
    Scott Lane Guest
    "Scott Lane" <> wrote in message
    news:Iggng.827$...
    > news:...
    Look at the data sheet for the different TDA817x Look for one with the
    right package style, then check the pinouts and see if they match up too,
    Vcc etc.
    #6
  7. Vince
    Vince Guest
    This IC is a TDA8172 and RCA draw # is 215531
    Vince
    news:...
    Vince, Jun 25, 2006
    #7
  8. Jason D.
    Jason D. Guest
    On Sat, 24 Jun 2006 21:05:59 -0600, "Vince" <>
    wrote:
    >NNTP-Posting-Date: Sat, 24 Jun 2006 20:06:02 MST
    >Xref: news.kos.net sci.electronics.repair:391
    > Vince
    Correct IC. To others, I prefer that please don't reply if some don't
    know what this chassis is and led the poster astray.
    Cheers, Wizard
    Jason D., Jun 26, 2006
    #8
    1. Advertisements
Similar Threads
  1. Replies:
    691
    w2aew
    May 23, 2006
  2. Replies:
    6
    603
  3. Mike
    672
  4. Mike
    1,246
    Franc Zabkar
    Sep 24, 2006
  5. Rhed
    11
    13,789
    Jotto
    Nov 27, 2012
Loading...
