RCA TV turning off automatically
Discussion in 'General Electronics Chat' started by comogritas, Jan 27, 2011.
  1. comogritas
    comogritas
    Jan 26, 2011
    I have a RCA TV Model F32650 that turns off automatically as soon as it is power on with the remote or manually. Do not have a clue as to what is causing it. I hoping, I can get some ideas as to what is the part that might be causing the TV to do this. Then go to an electronic part store buy the part and have my son put the part in (weld it, attach it, bolted, etc) Any suggestions will be greatly appreciated. Thank You
    #1
    1. Advertisements
  2. davenn
    davenn Moderator
    9,318
    867
    Sydney, Australia
    any fuses would be a good place to start
    If you have some GOOD technical ability then with a multimeter you would be able to check for some of the low voltage rails and see if they are correct.
    the causes could be many... fuses, capacitors, line output transformer, horizontal drive transistor....
    if you or your son dont have experience servicing TV's, then you need to consider the cost of a replacement compared to the cost of getting that one repaired by a qualified service centre :)
    davenn, Jan 27, 2011
    #2
    1. Advertisements
  3. shrtrnd
    shrtrnd VIP Member
    Jan 15, 2010
    2,696
    215
    Arizona
    You probably have a cirucit problem.
    But one experience I had, was the on-off push/button on the TV itself, sticking 'IN'.
    The plastic push-button itself had become wobbly on the switch shaft, and the plastic
    housing of the TV chassis, was sometimes keeping the push-button from completely
    disengaging (to allow the set to turn 'on').
    Just something to check.
    shrtrnd, Jan 28, 2011
    #3
  4. sall
    sall
    Jan 29, 2010
    51
    Marietta, Ohio
    I have cheap APEX 19" flat screen that had the same issues. I did a little research and came across a fix. There was bloated and failed 1000uf capacitor. Removed and replaced and fires up good now.
    Open it up and have a look around. Here is where mine was at fault:
    [​IMG]
    Hope this may help!
    This may help as well and is model specific..
    http://www.videokarma.org/archive/index.php/t-205389.html
    sall, Jan 29, 2011
    #4
  5. davenn
    davenn Moderator
    9,318
    867
    Sydney, Australia
    did you replace only one or both of those caps either side of the choke ?
    BOTH of them have bulging tops :)
    davenn, Mar 7, 2011
    #5
    1. Advertisements
Similar Threads
  1. Ann Onymous
    Sony TV powers off automatically after few secs
    Ann Onymous, Jan 29, 2004, in forum: Electronic Repair
    1,842
    RubbishRat
    Jan 29, 2004
  2. Matt
    RCA TV turning off and on
    Matt, Mar 5, 2004, in forum: Electronic Repair
    6
    1,045
    wolfhedd
    Mar 6, 2004
  3. netwebcenter
    kenwood amp automatically shuts off
    netwebcenter, Aug 15, 2005, in forum: Electronic Repair
    881
    Donald
    Aug 16, 2005
  4. computer
    3
    864
    Puckdropper
    Dec 23, 2005
  5. AFBear
    RCA P46924 cycles off and on automatically
    AFBear, Feb 18, 2006, in forum: Electronic Repair
    449
Loading...
