RCA CTC203ch1 No Vertical
Discussion in 'Electronic Repair' started by Steven, Jan 19, 2004.
  1. Steven
    Steven Guest
    Hope someone out there has any tips on this. The unit came in
    with absolutely no vertical sweep. The horizontal line has also shrunk
    in from each side by two inches. There is audio. R14509, 300-ohm, in
    the 13v+ source, runs very hot and is discolored. I replaced CR14704
    in the 13v+ source and U14501 vertical output chip. No improvement at
    all. Any help will be greatly appreciated!
    #1
    1. Advertisements
  2. Steven
    Jerry G. Guest
    Check for high ESR caps in the vertical def amp, and also in the power
    supply to start with. Defective caps are common in many of these sets.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    "Steven" <> wrote in message
    news:...
    Jerry G., Jan 20, 2004
    #2
    1. Advertisements
Similar Threads
  1. Replies:
    719
    w2aew
    May 23, 2006
  2. Steven
    RCA CTC203CH1 No Vertical
    Steven, Jan 16, 2004, in forum: Electronic Repair
    315
    woodward_electric
    Jan 17, 2004
  3. Mike
    RCA Proscan 27" TV no vertical
    Mike, Feb 11, 2004, in forum: Electronic Repair
    11
    768
  4. Mike
    693
  5. Rhed
    11
    15,511
    Jotto
    Nov 27, 2012
Loading...
