R/C car wont go in reverse
Discussion in 'Electronic Repair' started by Leonard Caillouet, May 8, 2005.
  1. It is broken. Take it to your local fix-it shop that does repairs on RC
    cars. Maybe you could download a manual for it with detailed instructions
    on how to take it apart and fix every conceivable problem that might occur
    with it. Perhaps your local parts distributor or RCpartsRUS had the part in
    stock.
    Seriously, try not walking into walls. The dizziness should go away soon
    and you will be able to move the lever in the reverse direction again.
    Leonard
    <> wrote in message
    news:...
    > After hitting a wall, my car will now only go forward and turn but no
    > longer goes in reverse. The reverse lamps don't light up anymore
    > either.
    > Any thoughts?
    #1
    1. Advertisements
  2. Leonard Caillouet
    Guest
    either.
    Any thoughts?
    , May 8, 2005
    #2
    1. Advertisements
  3. Leonard Caillouet
    Colin Dawson Guest
    Any change of some more information about the car? Is it something bought
    off the shelf? Secondhand?
    Does the car have seperate speed controller, reciever and servos? If so,
    what are makes and models are they?
    It might be something as simple as a setting's needs to be reset.
    <> wrote in message
    news:...
    > either.
    > Any thoughts?
    Colin Dawson, May 8, 2005
    #3
  4. Leonard Caillouet
    James Sweet Guest
    <> wrote in message
    news:...
    > either.
    > Any thoughts?
    You haven't told us enough information to be useful, what sort of RC car? Is
    the speed controller electronic or mechanical? How's the inside of the car
    look?
    James Sweet, May 8, 2005
    #4
  5. Leonard Caillouet
    JR North Guest
    Penalty mode for reckless driving.
    JR
    > either.
    > Any thoughts?
    Home Page: http://www.seanet.com/~jasonrnorth
    JR North, May 9, 2005
    #5
  6. Leonard Caillouet
    Franc Zabkar Guest
    On 8 May 2005 05:17:53 -0700, put finger to
    keyboard and composed:
    >either.
    The fwd/rev motor is usually driven by 4 transistors in a H-bridge
    configuration. Assuming there are no physical breakages, I'd say one
    or both of those transistors is faulty.
    - Franc Zabkar
    Please remove one 's' from my address when replying by email.
    Franc Zabkar, May 9, 2005
    #6
    1. Advertisements
Similar Threads
  1. Dan
    Car radio will not play when car is cold
    Dan, Feb 13, 2004, in forum: Electronic Repair
    1,574
    Bill Janssen
    Feb 13, 2004
  2. D from BC
    Car More Dead from Boosting a Dead Car Battery
    D from BC, Dec 21, 2006, in forum: Electronic Design
    17
    1,629
    Ancient_Hacker
    Jan 3, 2007
  3. billcalley
    12
    956
  4. Is
    CAR REVERSE SENSORS?
    Is, Jul 7, 2003, in forum: Hobby Electronics
    618
    Phil Allison
    Jul 8, 2003
  5. eman
    464
Loading...
