Questions About Construction Of The Australian Mystery Crystal Set
Discussion in 'Electronic Basics' started by Dave.H, Mar 10, 2008.
  1. Dave.H
    Dave.H Guest
    I've been looking at a number of simple crystal radio designs, and
    I've found the Australian mystery crystal set, and am interested in
    building that, mainly because it's an Australian design, and I've
    heard it it's a pretty good performer. I only have 2 questions- can I
    substitute the detector for a 1N34? and what is double silk covered
    wire and do I really have use that? What's wrong with regular coil
    wire? I can only find 23 SWG, 25 SWG, and 33 SWG where I need 24 SWG,
    30 SWG.
    #1
    1. Advertisements
  2. Dave.H
    Dave.H Guest
    Re: Questions About Construction Of The Australian Mystery CrystalSet
    > 30 SWG.
    > Thanks
    > Dave
    Forgot to give the schematic
    http://www.clarion.org.au/crystalset/mystery.html
    #2
    1. Advertisements
  3. Dave.H
    Eeyore Guest
    "Dave.H" wrote:
    > what is double silk covered wire
    It's wire insulated with silk.
    Not unless you want it to be 'period authentic'.
    Graham
    Eeyore, Mar 10, 2008
    #3
  4. Dave.H
    Dave.H Guest
    On Mar 10, 11:45 am, Eeyore <>
    > Graham
    Not really, I'm building it on a metal chassis (coil mounted above,
    vertically) and don't really care about vintage looks. I can't seem to
    find wire of the right diameter, though, that's the only part I've yet
    to find.
    #4
  5. Dave.H
    Don Bowey Guest
    Re: Questions About Construction Of The Australian MysteryCrystal Set
    On 3/9/08 5:03 PM, in article
    , "Dave.H"
    > 30 SWG.
    > Thanks
    > Dave
    That's a great looking radio.
    Use 23 or 25 or whatever is handy. The significant difference between
    cotton covered and enamel covered wires is that cotton spaces the wires a
    little farther apart than will the enamel, and it will take slightly more
    cotton covered wire to lay on the same number of turns as the enamel wire.
    Bottom line is, the two coils would have slightly difference inductive
    reactance. The turns count is probably a swag anyhow, and it's the reason
    most xtal sets using wound coils, put on lots of turns with taps so the
    range of tuning can be easily changed (hint, hint).
    I don't know what a really good replacement for the 1N34 would be. I'd look
    for a Hot Carrier diode if nobody comes up with a part number. From an
    occasionally defective memory, I think the 1N82 may be one.
    Don Bowey, Mar 10, 2008
    #5
  6. Dave.H
    Phil Allison Guest
    "Donald Duck Bowey"
    ** Try reading the damn question - fuckwit.
    ........ Phil
    Phil Allison, Mar 10, 2008
    #6
  7. Dave.H
    Jamie Guest
    > 30 SWG.
    > Thanks
    > Dave
    http://www.rwonline.com/pages/s.0055/t.5708.html
    Read that, it's interesing., don't know if it'll
    help you how ever. I'm guessing that if you used enamel
    wire you would be fine for what you're doing.
    http://webpages.charter.net/jamie_5"
    Jamie, Mar 10, 2008
    #7
  8. Dave.H
    Don Bowey Guest
    Re: Questions About Construction Of The Australian MysteryCrystalSet
    On 3/9/08 6:04 PM, in article , "Phil
    Allison" <> wrote:
    > "Donald Duck Bowey"
    Sorry grampa. I'll try to do better next time.
    If you keep using those naughty words I'm going to tell on you.
    > ....... Phil
    #8
  9. Dave.H
    ehsjr Guest
    > 30 SWG.
    > Thanks
    > Dave
    You can use regular coil wire of whatever size you
    can get that is close, and the 1N34 is fine as the
    detector.
    Ed
    ehsjr, Mar 10, 2008
    #9
  10. Dave.H
    Eeyore Guest
    "Dave.H" wrote:
    > can I substitute the detector for a 1N34?
    You might do rather well with a zero bias schottky diode.
    Failing that, any germamium point-contact type (like the 1N34) would be a
    decent sub.
    Graham
    #10
  11. Dave.H
    Dave.H Guest
    On Mar 10, 5:53 pm, Eeyore <>
    > decent sub.
    > Graham
    I'll go with the 1N34. I'm also going to install a 1S5 tube as a
    second detector, switchable between the two, with a 'D' cell powering
    the filament.
    #11
  12. Dave.H
    amdx Guest
    "Dave.H" <> wrote in message
    news:...
    >> decent sub.
    >> Graham
    > second detector, switchable between the two, with a 'D' cell >powering the
    > filament.
    Hi Dave,
    I almost feel bad giving you this URL, it is so full of useful information
    that it may be a while before you have time to get anything done. See
    section 1. Out of the 29 atricles, I think 5 or 6 are about how to improve
    the diode/detector operation. Oh, and see #19, Ben discusses the 1932
    "Mystery Crystal Radio"
    http://www.bentongue.com/xtalset/xtalset.html
    Have fun, Mike
    *and what's this stuff about a D cell on a crystal radio :)
    amdx, Mar 10, 2008
    #12
  13. Dave.H
    whit3rd Guest
    > the filament.
    Gack! How about using a transistor (base -emitter of PN3904 connect
    B to coil, E to phones), and a 1k resistor from the collector to
    battery (+)?
    Battery (-) to ground.
    Or go low-tech and use a two-potato battery.
    <http://www.ehow.com/how_18637_make-potato-clock.html>
    whit3rd, Mar 10, 2008
    #13
  14. Dave.H
    Dave.H Guest
    I got the idea from one of Dave Schmarder's radios, #26
    http://www.schmarder.com/radios/crystal/26.htm
    Dave.H, Mar 11, 2008
    #14
  15. Dave.H
    amdx Guest
    news:...
    Hi Dave,
    My point was, the purists would shudder at the thought of an external
    power source on a crystal radio. Now if you extract the power from a strong
    local and use that to amplify a weak signal then your doing good work.
    Mike
    amdx, Mar 11, 2008
    #15
  16. Dave.H
    Sjouke Burry Guest
    >> Graham
    > to find.
    A metal chassis can influence performance very much,
    because metal in front of a coil acts as a shorted
    winding.
    I advise to test things without a chassis, on a non-metal
    table surface, and when it performs as intended,
    try it in your metal housing.
    I would choose a wooden or plastic box however.
    Sjouke Burry, Mar 11, 2008
    #16
  17. Dave.H
    Don Bowey Guest
    On 3/11/08 5:15 AM, in article 91512$47d674c2$18d6b40c$,
    > news:...
    > Hi Dave,
    > Mike
    The tube isn't being used as an amplifier, it's diode is used as a
    switchable option to a SS diode. The battery is for it's filament.
    Don Bowey, Mar 11, 2008
    #17
  18. Dave.H
    amdx Guest
    "Don Bowey" <> wrote in message
    news:C3FBEB75.B1D97%...
    >> news:...
    >> Hi Dave,
    >> strong
    >> Mike
    Ok then, the purists would shudder at the thought of an external
    local and use that to bias your diode then your doing good work.
    Gees Don, your acting like Phil but without the name calling :)
    Mike
    amdx, Mar 11, 2008
    #18
  19. Dave.H
    Steven Swift Guest
    "Dave.H" <> writes:
    >> 30 SWG.
    >> Thanks
    >> Dave
    Substitutes will work fine. All the other stuff is to make it look like
    a "period piece." Go to a rock shop and get some galena for the detector
    if you want to go retro.
    Steve.
    Steven D. Swift, , http://www.novatech-instr.com
    NOVATECH INSTRUMENTS, INC. P.O. Box 55997
    206.301.8986, fax 206.363.4367 Seattle, Washington 98155 USA
    Steven Swift, Mar 12, 2008
    #19
  20. Dave.H
    Don Bowey Guest
    On 3/11/08 3:51 PM, in article 47475$47d70c71$45013908$,
    >>> news:...
    >>> Hi Dave,
    >>> strong
    >>> Mike
    > Mike
    Geez Mike, why didn't you take time to see what the OP was doing?
    If you wish to really be a purist you should insist one should use a coherer
    for the detector, or a chunk of galena and a cats-whisker.
    I think it's a bit cool to have two different detectors and be able to
    switch between them, like in the good old days.
    Don Bowey, Mar 12, 2008
    #20
    1. Advertisements
Similar Threads
  1. Replies:
    6
    1,385
    Joerg
    Aug 27, 2005
  2. nitro2
    Sony mini-set PMC-DR45L line out questions
    nitro2, Sep 28, 2008, in forum: Electronic Repair
    608
    nitro2
    Oct 4, 2008
  3. dietermoreno
    47
    3,585
    dietermoreno
    May 10, 2013
  4. ecollen
    Beginner ... ferrite core coil for crystal set
    ecollen, Sep 28, 2015, in forum: Electronic Projects
    17
    430
    CDRIVE
    Sep 30, 2015
  5. ecollen
    Audio transformer for crystal set help
    ecollen, Oct 19, 2015, in forum: Electronic Projects
    26
    533
    CDRIVE
    Oct 22, 2015
Loading...
