Query about Bitwise operations
Discussion in 'Microcontrollers and Programming' started by alsaf, Nov 14, 2011.
  1. alsaf
    alsaf
    Oct 2, 2011
    12
    I had come heard of Bitwise but I didn't really understood it until recently when I had being learning Assembly language programming. While I understood its principles and how it worked, I didn't really know what purpose it was for. From research the some purposes are bit fields/flags and arithmetic.
    I would assume, in terms of embedded programming, using bitwise operations for arithmetic purposes would be better than built-in ones when doing heavy number crunching operations but would it be beneficial or even noticeable if any occasional calculations were required?
    alsaf, Nov 14, 2011
    #1
    1. Advertisements
  2. alsaf
    6,066
    863
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    Hi alsaf,
    bitwise operations are not for arithmetic purposes, although one could use them in that way.
    There are several uses for bitwise operations. Just afe to mention:
    1) store lot of data with little memory. E.g. ona an 8 Bit computer, an 8 bit data word could be used to store the presence or absence of 8 different properties. Bit n=1 could mean property "n" is present, Bit n=0 could mean property "n" is missing. To set, clear and check single bits, you need bitwise operations. In this example you need only 1 data word instead of 8 words to store this infiormation.
    2) set, clear and check single port bits of a microcontroller. A microcontrollers I/Os are very often grouped in words of 8, 16 or 32 bits. You need bitwise operations e.g. to set a singel I/O line to high or low or to check its status.
    You will find more usefull information especially on bitwise operations in maicrocontroller manuals.
    Regards,
    Harald
    Harald Kapp, Nov 18, 2011
    #2
    1. Advertisements
  3. alsaf
    alsaf
    Oct 2, 2011
    12
    Thanks for the info Harald, much appreciated.
    alsaf, Nov 21, 2011
    #3
    1. Advertisements
Similar Threads
  1. Jim Thompson
    Motorola To Spin Off Remaining Semiconductor Operations
    Jim Thompson, Oct 12, 2003, in forum: Electronic Design
    10
    557
    Spehro Pefhany
    Oct 13, 2003
  2. Jim Thompson
    10
    689
    Spehro Pefhany
    Oct 13, 2003
  3. Rich Grise
    6
    1,230
    Gary H. Lucas
    Jun 24, 2005
  4. cafm
    Wireless BitWise Bus Arbitration
    cafm, Nov 27, 2005, in forum: Electronic Design
    512
  5. Michael Grigoni
    713
    Michael Grigoni
    May 25, 2004
Loading...
