PWM Control IC Problem (SG3525)
Discussion in 'Electronic Repair' started by alphamnemonic, Jul 2, 2008.
  1. Hi Everybody
    This chip normally puts out square pulses. In the power supply I am
    working on (http://www.laserfaq.org/sam/150rcsch.pdf) it is putting
    out a sawtooth wave. I am testing it in 'standby mode', in which Q4 is
    off and R33 is in control of the duty cycle. Replacing the IC1 has no
    effect. Does anyone have any ideas?
    #1
    1. Advertisements
  2. Guest
    On Jul 2, 3:35 pm, alphamnemonic <> wrote:
    > Hi Everybody
    Where are you seeing sawtooths? Pin 13?
    --- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
    | Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
    Important: Anything sent to the email address in the message header
    above is
    ignored unless my full name AND either lasers or electronics is
    included in the
    subject line. Or, you can contact me via the Feedback Form in the
    FAQs.
    , Jul 3, 2008
    #2
    1. Advertisements
  3. On Jul 2, 6:20 pm, Steve <> wrote:
    > wrote in news:16ea6110-be19-4a21-aecc-
    > >> Hi Everybody
    > > --- sam | Sci.Electronics.Repair FAQ:http://www.repairfaq.org/
    > >  Repair | Main Table of Contents:http://www.repairfaq.org/REPAIR/
    > > +Lasers | Sam's Laser FAQ:http://www.repairfaq.org/sam/lasersam.htm
    > >         | Mirror Sites:http://www.repairfaq.org/REPAIR/F_mirror..html
    > > above is
    > > included in the
    > > FAQs.
    > That is my question. Why do you have output A and output B (pin 11 and 14)
    > grounded?
    > Also, pin 13 is VC in for the transistor collectors. Why do you have this
    > connected as an output?- Hide quoted text -
    > - Show quoted text -
    Yes the sawtooth is on pin 13. Pin 13 is being used as an output and
    pins 11 and 14 are grounded because the chip is being used in single-
    ended supply mode (see http://www.datasheetcatalog.org/datasheet/motorola/SG3525AN.pdf
    p.6 for an example of this configuration). I can see why you find that
    strange--I did too!
    alphamnemonic, Jul 3, 2008
    #3
  4. On Jul 3, 6:09 pm, Steve <> wrote:
    > alphamnemonic <> wrote innews::
    > >> >> Hi Everybody
    > >> >> am working on (http://www.laserfaq.org/sam/150rcsch.pdf) it is
    > >> >> putting out a sawtooth wave. I am testing it in 'standby mode', in
    > >> >> which Q4 is off and R33 is in control of the duty cycle. Replacing
    > >> >> the IC1 has no effect. Does anyone have any ideas?
    > > .html
    > >> > above is
    > >> > included in the
    > >> > FAQs.
    > >> and 14
    > >> grounded?
    > >> this connected as an output?- Hide quoted text -
    > >http://www.datasheetcatalog.org/datasheet/motorola/SG3525AN.pdfp.6
    > > strange--I did too!
    > I'd avoid the funky setup you have. In my opinion I'd connect pin 13 and 15
    > together and use either output A or B.
    > I'm not sure what Q4 is doing, I've never seen it used this way, but you
    > must know more than me since you designed this elaborte circuit.
    > Keep us posted at what you do to resolve the problem.- Hide quoted text -
    It's not my design. I am trying to repair a commercial unit. I will
    keep you posted.
    alphamnemonic, Jul 4, 2008
    #4
  5. Guest
    > > >> >> Hi Everybody
    > > > .html
    > > >> > above is
    > > >> > included in the
    > > >> > FAQs.
    > > >> and 14
    > > >> grounded?
    > > > strange--I did too!
    > keep you posted.
    First, I've never scoped pin 13 so don't know for sure what should be
    there.
    But, my guess is that one of the 3 transistors is not behaving
    properly.and you're
    seeing one of the caps charging.
    above is
    included in the
    FAQs.
    , Jul 5, 2008
    #5
  6. On Jul 7, 6:09 pm, Steve <> wrote:
    > Steve <> wrote innews:Xns9AD0CDEF8F97Fnobodynobodycom@216.196.97.136:
    > > news:ba29f199-331f-48c1-ab96-28c3a81d42d8
    > @i18g2000prn.googlegroups.com:
    > >>> >> Hi Everybody
    > >>> >> in which Q4 is off and R33 is in control of the duty cycle.
    > >>> >> Replacing the IC1 has no effect. Does anyone have any ideas?
    > >>> > Where are you seeing sawtooths? �Pin 13?
    > >>> > �Repair | Main Table of Contents:http://www.repairfaq.org/REPAIR/
    > >>> > FAQ:http://www.repairfaq.org/sam/lasersam.htm� � � � | Mirror
    > >> .html
    > >>> > header above is
    > >>> > included in the
    > >>> > subject line. �Or, you can contact me via the Feedback Formin the
    > >>> > FAQs.
    > >>> and 14
    > >>> grounded?
    > >> strange--I did too!
    > > and 15 together and use either output A or B.
    > > you must know more than me since you designed this elaborte circuit.
    > I have been looking at the circuit and the datasheet.
    > I'm willing to bet the schematic is drawn wrong. It doesn't make any
    > sense to have pin 13 driving the base of a transistor.- Hide quoted text -
    The schematic is drawn correctly. This mode of operation is described
    on p.6 of the datasheet (link is given in my post from July 3). I
    removed the board and re-soldered R1 and R2, and the supply is now
    working properly again. A rather boring fix, but if it works long term
    I won't complain... If anyone else is having trouble with this supply,
    I can send you waveforms captured with FlukeView from the working
    unit. Thanks for the suggestions everyone.
    alphamnemonic, Jul 14, 2008
    #6
    > > 6.196.97.136:
    > >> >>> >> Hi Everybody
    > >> >>> >> I am working on (http://www.laserfaq.org/sam/150rcsch.pdf) it
    > >> >>> >> is putting out a sawtooth wave. I am testing it in 'standby
    > >> >>> >> mode', in which Q4 is off and R33 is in control of the duty
    > >> >>> >> cycle. Replacing the IC1 has no effect. Does anyone have any
    > >> >>> >> ideas?
    > > EPAIR/
    > >> >>> > FAQ:http://www.repairfaq.org/sam/lasersam.htm��
    > > � � | Mirror
    > >> >> .html
    > >> >>> > header above is
    > >> >>> > included in the
    > >  in the
    > >> >>> > FAQs.
    > >> >>> 11 and 14
    > >> >>> grounded?
    > >> >>> have this connected as an output?- Hide quoted text -
    > >> >> and pins 11 and 14 are grounded because the chip is being used in
    > >> >> single- ended supply mode (see
    > >> >> strange--I did too!
    > >> > 13 and 15 together and use either output A or B.
    > >> > but you must know more than me since you designed this elaborte
    > >> > circuit.
    > >> text
    > I'd like to see them. Do you have them in a format you can easily email?-Hide quoted text -
    Yes: .rtf
    alphamnemonic, Jul 16, 2008
    #7
    > >> innews:e7294911-213d-4734-b0cd-
    > >> > 6.196.97.136:
    > >> >> >>> > wrote:
    > >> >> >>> >> Hi Everybody
    > >> >> >>> >> supply I am working on
    > >> >> >>> >> any ideas?
    > >> >> >>> > FAQ:http://www.repairfaq.org/�Repair | Main Table of
    > > g/R
    > >> > EPAIR/
    > >> > � � | Mirror
    > >> >> >> .html
    > >> >> >>> > header above is
    > >> >> >>> > is included in the
    > > orm
    > >> >  in the
    > >> >> >>> > FAQs.
    > >> >> >>> (pin 11 and 14
    > >> >> >>> grounded?
    > >> >> >>> you have this connected as an output?- Hide quoted text -
    > >> >> >> output and pins 11 and 14 are grounded because the chip is
    > >> >> >> being used in single- ended supply mode (see
    > >> >> >>6
    > >> >> >> that strange--I did too!
    > >> >> > pin 13 and 15 together and use either output A or B.
    > >> >> > circuit.
    > >> >> any sense to have pin 13 driving the base of a transistor.- Hide
    > >> >> quoted text
    > >> > described on p.6 of the datasheet (link is given in my post from
    > >> > July 3). I removed the board and re-soldered R1 and R2, and the
    > >> > supply is now working properly again. A rather boring fix, but if
    > >> > it works long term I won't complain... If anyone else is having
    > >> > trouble with this supply, I can send you waveforms captured with
    > >> > FlukeView from the working unit. Thanks for the suggestions
    > >> > everyone.
    > >> email?-
    > >  Hide quoted text -
    > > Yes: .rtf
    > I phrased that incorrectly.
    > I meant can you post them on here for downloading or on a site?
    > Thanks- Hide quoted text -
    > - Show quoted text -- Hide quoted text -
    I don't have a website, but I will post them here if you tell me how.
    alphamnemonic, Jul 17, 2008
    #8
  9. On Jul 17, 11:08 am, "Michael A. Terrell" <>
    wrote:
    >    This isn't a binary newsgroup, and you can't post pictures through
    > Google Groups.
    >    Sign up for a free photo hosting service and post the link to the
    > pictures.
    > --http://improve-usenet.org/index.html
    > If you have broadband, your ISP may have a NNTP news server included in
    > your account:http://www.usenettools.net/ISP.htm
    > Sporadic E is the Earth's aluminum foil beanie for the 'global warming'
    > sheep.
    The pics are up at http://sites.google.com/site/scientificelectronicsrepair/
    #9
    1. Advertisements
Similar Threads
  1. parkc23
    PWM with SG3525
    parkc23, Aug 13, 2004, in forum: Electronic Basics
    2,565
    CFoley1064
    Aug 14, 2004
  2. parkc23
    PWM with SG3525
    parkc23, Aug 13, 2004, in forum: Electronic Design
    8
    3,663
    parkc23
    Aug 16, 2004
  3. Pooh Bear
    Should I use a SG3525 ?
    Pooh Bear, Nov 16, 2004, in forum: Electronic Design
    16
    4,063
    Terry Given
    Dec 1, 2004
  4. Mauri
    PWM-FF vs PWM-QR control IC
    Mauri, Apr 10, 2005, in forum: Electronic Design
    949
  5. jeffrun
    Sg3525 pwm motor control ir comp
    jeffrun, Oct 8, 2007, in forum: General Electronics Chat
    1,891
    jeffrun
    Oct 8, 2007
Loading...
