PSpice and LTSpice
Discussion in 'Electronic Design' started by petrus bitbyter, Jan 4, 2010.
  1. Lately I got a PSpice listing that differs wildly from the LTSpice listings
    used by LTSpice. Anyone knows a way to convert from PSpice to LTSpice?
    petrus bitbyter
    #1
    1. Advertisements
  2. "Jim Thompson" </Snicker>
    schreef in bericht news:...
    > On Mon, 4 Jan 2010 23:33:54 +0100, "petrus bitbyter"
    >>listings
    >>petrus bitbyter
    > Post a sample. Shouldn't be any _significant_ difference... maybe
    > polynomial versus behavioral ??
    > ...Jim Thompson
    > | James E.Thompson, CTO | mens |
    > | Analog Innovations, Inc. | et |
    > | Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
    > | Phoenix, Arizona 85048 Skype: Contacts Only | |
    > | Voice:(480)460-2350 Fax: Available upon request | Brass Rat |
    > | E-mail Icon at http://www.analog-innovations.com | 1962 |
    > I love to cook with wine. Sometimes I even put it in the food.
    I add two listings that show the differences very clear.
    The first is a listing of the circuit involved. A three pole Sallen-Key low
    pass filter. I need it to filter the harmonics from a PWM-based sinewave
    generator. So far I see too much remnants of the sample frequency - in the
    19-20kHz range - on the o'scope. My LTSpice program does not recognize it.
    The second you will recognize easily. It's a LTSpice listing of a very
    different circuit laying around here. Guess I got it from this NG.
    * Netlist generated by ActiveLP
    * --- Active Low-Pass Filter ----
    * Filter Topologie: Sallen-Key
    * Filter Type: Butterworth
    * Filter Order: 3
    * -3 dB-Frequency: 300 Hz
    V1 O0 0 AC 1 0 PULSE(0 1 0 33.333u 33.333u 33.333m)
    * Ideal Circuit using Voltage controlled Voltage Sources
    RI1A O0 BI1 112.88
    CI1A BI1 0 4.7u
    EI1 OI1 0 BI1 0 1
    RI2A OI1 AI2 78.805
    RI2B AI2 BI2 162.34
    CI2A BI2 0 2.2u
    CI2B AI2 OI2 10u
    EI2 OI2 0 BI2 0 1
    ..graph OI2 curveLabel="Output Stage 2 Ideal" nowarn=true ylog=auto
    * Simulation Control
    ..TRAN 0 66.667m 0 33.333u
    ..AC DEC 1k 3 3k
    Version 4
    SHEET 1 2100 1172
    WIRE 848 -416 752 -416
    WIRE 1040 -416 928 -416
    WIRE 752 -304 752 -416
    WIRE 848 -304 752 -304
    WIRE 1040 -304 1040 -416
    WIRE 1040 -304 912 -304
    WIRE 1104 -304 1040 -304
    WIRE 1152 -304 1104 -304
    WIRE 752 -272 752 -304
    WIRE 752 -160 752 -208
    FLAG 752 -160 0
    FLAG 1104 -304 out
    SYMBOL Digital\\schmtinv 848 -368 R0
    WINDOW 3 30 111 Left 0
    WINDOW 123 34 145 Left 0
    SYMATTR InstName A1
    SYMATTR Value vhigh=5 vlow=0 trise=25n
    SYMATTR Value2 tripdt=5n vt=2.5 vh=.9
    SYMBOL cap 736 -272 R0
    SYMATTR InstName C2
    SYMATTR Value 100n ic=0
    SYMBOL Misc\\EuropeanResistor 832 -400 R270
    WINDOW 0 27 56 VTop 0
    WINDOW 3 5 56 VBottom 0
    SYMATTR InstName R1
    SYMATTR Value 100k
    TEXT 536 -392 Left 0 !.tran 0 200m 0 uic
    petrus bitbyter
    petrus bitbyter, Jan 5, 2010
    #2
    1. Advertisements
  3. petrus bitbyter
    Ian Bell Guest
    >>> listings
    >>> petrus bitbyter
    >> ...Jim Thompson
    > * Filter Order: 3
    > RI1A O0 BI1 112.88
    > CI1A BI1 0 4.7u
    > EI1 OI1 0 BI1 0 1
    > RI2A OI1 AI2 78.805
    > RI2B AI2 BI2 162.34
    > CI2A BI2 0 2.2u
    > CI2B AI2 OI2 10u
    > EI2 OI2 0 BI2 0 1
    > .AC DEC 1k 3 3k
    > Version 4
    > SHEET 1 2100 1172
    > FLAG 752 -160 0
    > FLAG 1104 -304 out
    > SYMATTR InstName A1
    > SYMATTR InstName C2
    > SYMATTR InstName R1
    > SYMATTR Value 100k
    > petrus bitbyter
    If you are looking for compatibility between these two programs at the
    schematic level you will be sadly disappointed. You simply need to draw
    the circuit in LTSpice then simulate it.
    Cheers
    Ian
    Ian Bell, Jan 5, 2010
    #3
  4. petrus bitbyter
    qrk Guest
    >petrus bitbyter
    LTspice is very compatible with PSpice netlists. When you do a
    File>Open in LTspice, be sure you select Netlists as the file type.
    To make life easier, take the PSpice netlist and draw a schematic from
    it in LTspice. It's such a small circuit that you should be able to do
    this in 10 minutes.
    Mark
    qrk, Jan 5, 2010
    #4
  5. "petrus bitbyter" <> schrieb im
    Newsbeitrag news:4b4310ea$0$7031$4all.nl...
    >>>listings
    >>>petrus bitbyter
    >> ...Jim Thompson
    > low pass filter. I need it to filter the harmonics from a PWM-based
    > sinewave generator. So far I see too much remnants of the sample
    > frequency - in the 19-20kHz range - on the o'scope. My LTSpice program
    > * Filter Order: 3
    > RI1A O0 BI1 112.88
    > CI1A BI1 0 4.7u
    > EI1 OI1 0 BI1 0 1
    > RI2A OI1 AI2 78.805
    > RI2B AI2 BI2 162.34
    > CI2A BI2 0 2.2u
    > CI2B AI2 OI2 10u
    > EI2 OI2 0 BI2 0 1
    > .AC DEC 1k 3 3k
    Hello Petrus,
    You could directly run the netlist if you comment the .AC and the .Graph
    line.
    Below is this netlist file "test4.cir". It's ready to be used with LTspice.
    * Filter Order: 3
    RI1A O0 BI1 112.88
    CI1A BI1 0 4.7u
    EI1 OI1 0 BI1 0 1
    RI2A OI1 AI2 78.805
    RI2B AI2 BI2 162.34
    CI2A BI2 0 2.2u
    CI2B AI2 OI2 10u
    EI2 OI2 0 BI2 0 1
    *.graph OI2 curveLabel="Output Stage 2 Ideal" nowarn=true ylog=auto
    *.AC DEC 1k 3 3k
    I have additionally made a schematic of this netlist.
    It is 100% equivalent to the original netlist.
    Schematic file "test4a.asc".
    Best regards,
    Helmut
    Version 4
    SHEET 1 1308 680
    WIRE 768 -16 592 -16
    WIRE 912 -16 832 -16
    WIRE 32 80 0 80
    WIRE 80 80 32 80
    WIRE 224 80 160 80
    WIRE 240 80 224 80
    WIRE 336 80 240 80
    WIRE 400 80 384 80
    WIRE 448 80 400 80
    WIRE 560 80 528 80
    WIRE 592 80 592 -16
    WIRE 592 80 560 80
    WIRE 640 80 592 80
    WIRE 752 80 720 80
    WIRE 768 80 752 80
    WIRE 864 80 768 80
    WIRE 912 80 912 -16
    WIRE 976 80 912 80
    WIRE 0 144 0 80
    WIRE 240 144 240 80
    WIRE 384 144 384 80
    WIRE 912 144 912 80
    WIRE 336 160 336 80
    WIRE 864 160 864 80
    WIRE 768 176 768 80
    WIRE 0 288 0 224
    WIRE 240 288 240 208
    WIRE 240 288 0 288
    WIRE 336 288 336 208
    WIRE 336 288 240 288
    WIRE 384 288 384 224
    WIRE 384 288 336 288
    WIRE 768 288 768 240
    WIRE 768 288 384 288
    WIRE 864 288 864 208
    WIRE 864 288 768 288
    WIRE 912 288 912 224
    WIRE 912 288 864 288
    WIRE 0 304 0 288
    FLAG 32 80 O0
    FLAG 224 80 BI1
    FLAG 0 304 0
    FLAG 400 80 OI1
    FLAG 560 80 AI2
    FLAG 752 80 BI2
    FLAG 976 80 OI2
    IOPIN 976 80 Out
    SYMBOL voltage 0 128 R0
    WINDOW 3 -34 220 Left 0
    WINDOW 123 -32 246 Left 0
    WINDOW 39 0 0 Left 0
    SYMATTR InstName V1
    SYMATTR Value PULSE(0 1 0 33.333u 33.333u 33.333m 100m)
    SYMATTR Value2 AC 1
    SYMBOL res 64 96 R270
    WINDOW 0 32 56 VTop 0
    WINDOW 3 0 56 VBottom 0
    SYMATTR InstName RI1A
    SYMATTR Value 112.88
    SYMBOL cap 224 144 R0
    SYMATTR InstName CI1A
    SYMATTR Value 4.7µ
    SYMBOL e 384 128 R0
    SYMATTR InstName EI1
    SYMATTR Value 1
    SYMBOL res 432 96 R270
    SYMATTR InstName RI2A
    SYMATTR Value 78.805
    SYMBOL res 624 96 R270
    SYMATTR InstName RI2B
    SYMATTR Value 162.34
    SYMBOL cap 752 176 R0
    SYMATTR InstName CI2A
    SYMATTR Value 2.2µ
    SYMBOL e 912 128 R0
    SYMATTR InstName EI2
    SYMATTR Value 1
    SYMBOL cap 768 0 R270
    WINDOW 0 32 32 VTop 0
    WINDOW 3 0 32 VBottom 0
    SYMATTR InstName CI2B
    SYMATTR Value 10µ
    TEXT 0 -40 Left 0 !.TRAN 0 66.667m 0 33.333u
    TEXT 0 -80 Left 0 ;.AC DEC 1k 3 3k
    Helmut Sennewald, Jan 5, 2010
    #5
  6. Hi Jim,
    > Above is a NETLIST.
    > Below is a SCHEMATIC.
    > Also, I am SURE that there is some way to import a netlist into
    > LTspice _without_ having to translate it to a schematic.
    > LTspice users?
    I'm not a SPICE expert but this is very easy. Insert a Text as Spice
    directive in the plain schematic and then run the simulation as is. In this
    example the line
    should be eliminated with a semicolon in the beginning. Also you have to
    decide whether you want to simulate .Tran or .AC
    May be there is a more elegant way to do but this one is simple to use
    Marte
    Marte Schwarz, Jan 6, 2010
    #6
    1. Advertisements
Similar Threads
  1. Larry Brasfield
    LTspice / SwitcherCAD III and Bridge Rectifier question
    Larry Brasfield, Mar 16, 2005, in forum: Electronic Basics
    5
    1,722
    John Popelish
    Mar 17, 2005
  2. nanotech1
    2,412
    Bob Eldred
    Apr 27, 2005
  3. Ben Bradley
    Pspice to LTSpice/SwitcherCad schematic conversion?
    Ben Bradley, Apr 30, 2005, in forum: Electronic Design
    6
    8,164
    Jim Thompson
    May 2, 2005
  4. qasimmuz
    Pspice error "The Pspice COM wrapper has occured"
    qasimmuz, Feb 6, 2013, in forum: Datasheets, Schematics, Manuals and Parts
    1,331
    qasimmuz
    Feb 6, 2013
  5. chopnhack
    14
    654
    Arouse1973
    Jun 16, 2015
Loading...
