Pressure Testing HV cables
Discussion in 'Electrical Engineering' started by toby jug, Dec 26, 2003.
  1. toby jug
    toby jug Guest
    Could somebody please explain the difference between pressure testing and
    insulation resistance testing of HV cables.
    And how is the pressure testing actually done and what do the results
    actually mean ?
    i.e Leakage in mA
    Thank You
    #1
    1. Advertisements
  2. Hello Toby
    In article <4V3Hb.10999$>,
    > actually mean ?
    > i.e Leakage in mA
    > Thank You
    You do not say where you are in the world and this sometimes effects the
    answers to this type of question, but in the UK Pressure Testing implies
    applying a voltage to a cable for a short time which exceeds working voltage.
    This is usually done with dc even on ac cables, and the result of the test is
    either success or failure depending on whether the cable survives or fails.
    There will usually be a measured leakage current, but it is not regarded as
    important. It is usually done once only as a test when commissioning a cable.
    Insulation Resistance testing usually involves testing an HV cable at a lower
    voltage, and measures the insulation resistance of the cable at this
    voltagae. If done regularly and carefully with guard electrodes the readings
    can give some indication of how a cable is detiorating with age. Personally I
    would not use it because of the difficulties of ensuring all readings were
    done under the same conditions, and the data management needed to keep
    meaningful records, but it some places it may be a legal requirement.
    John
    EurIng J Rye CEng FIEE Electrical Engineering Consultant
    18 Wentworth Close Hadleigh IPSWICH IP7 5SA England
    Tel No 01473 827126 <http://web.ukonline.co.uk/jrye/index.html>
    ---< On Line using an Acorn StrongArm RiscPC >---
    Eur Ing John Rye, Dec 27, 2003
    #2
    1. Advertisements
Similar Threads
  1. merco
    Pressure Measurement type pressure sensors
    merco, Jan 30, 2006, in forum: Electronic Design
    3
    771
    Spehro Pefhany
    Jan 30, 2006
  2. mhugues
    no water pressure. pressure won't hod.
    mhugues, May 24, 2005, in forum: Electronic Repair
    650
    Rheilly Phoull
    May 24, 2005
  3. lbbss
    5
    1,116
  4. JosephKK
    HV cables (5kV rated for 200 degrees C)
    JosephKK, Sep 17, 2008, in forum: Electronic Design
    4
    403
  5. Skybuck Flying
    6
    1,864
    Skybuck Flying
    Aug 14, 2009
Loading...
