power whips - what is it?
Discussion in 'Electrical Engineering' started by Artur Butryn, Sep 9, 2003.
  1. Artur Butryn
    Artur Butryn Guest
    What exactly power whips are?? Can somebody explain?
    I'm not native speaker
    Artur
    #1
    1. Advertisements
  2. Artur Butryn
    Mr. Sandman Guest
    On Tue, 9 Sep 2003 12:00:12 +0200, "Artur Butryn"
    >Artur
    There might be other definitions, but a power whip in the field is a
    cable running from a junction box too a device such as a light fixture
    or power pole coming out of the of a ceiling too feed say a cash
    register. They usually have a specialty plug that plugs into said
    device.
    Mr. Sandman, Sep 9, 2003
    #2
    1. Advertisements
  3. In other applications is a length of seal tight conduit running from a floor
    mounted PDU or panel to a bell box with receptacle. Used like this it is
    more than likely run under a raised floor in a computer room.
    E
    "Artur Butryn" <> wrote in message
    news:bjk8g6$910$...
    > Artur
    Erik Dienberg, Sep 9, 2003
    #3
  4. Artur Butryn
    Mr. Sandman Guest
    On Tue, 09 Sep 2003 16:42:32 GMT, Repeating Decimal
    <> wrote:
    >Here is an entirely different take,
    >Whips, the kind used to lash animals, including people, are impedance
    >transformers. The high mass and low speed of a whips belly gets transferred
    >to the low mass of the tip where the speed is greatly increased. Often, the
    >crack of the whip has speed exceeding that of sound.
    >The same principle applies to fly casting and tapered transmission lines.
    >Bill
    I was hoping that others would reply with creative definitions such
    as yours. Thank you for the giggle.
    Mr. Sandman, Sep 10, 2003
    #4
    1. Advertisements
Similar Threads
  1. Robert Oschler
    Battery power to replace wall power supply?
    Robert Oschler, Feb 4, 2005, in forum: General Electronics
    33
    4,076
    Robert Baer
    Feb 11, 2005
  2. Abbie
    Why 2 power transistors in my power supply ?
    Abbie, Nov 29, 2003, in forum: Electronic Basics
    13
    758
    John Popelish
    Dec 4, 2003
  3. Marcel Gonzalez
    AT Power Supply question: "Power Good" signal
    Marcel Gonzalez, Jan 5, 2004, in forum: Electronic Basics
    914
    Wayne
    Jan 6, 2004
  4. Myron Samila
    Power amps-> power consumed vs output power.
    Myron Samila, Dec 8, 2003, in forum: Misc Electronics
    3
    2,212
    Myron Samila
    Dec 10, 2003
  5. mattmro444
    CB whips instead of the standard radio antennae
    mattmro444, Aug 30, 2014, in forum: General Electronics Chat
    4
    363
    KJ6EAD
    Sep 8, 2014
Loading...
