Power Mosfets vs SCRs
Discussion in 'Electronic Design' started by gyansorova@gmail.com, Jun 9, 2007.
  1. Guest
    What's the highest current an SCR can handle versus a Power Mosfet? I
    assume SCRs are still way out in front but are Mosfets faster?
    W.King
    , Jun 9, 2007
    #1
    1. Advertisements
  2. D from BC Guest
    >W.King
    Let's say an SCR and a Mosfet are in TO-220 packages.
    I'll say mosfet handles more current.
    (SCR Vsat vs Mos Rdson)
    As for speed contest...
    I dunno...
    But I'll guess mosfet again due to a push for advancements in
    efficient smps's..
    D from BC
    D from BC, Jun 9, 2007
    #2
    1. Advertisements
  3. Wimpie Guest
    > W.King
    Hi King,
    SCR are available in the high kA range, >1000V, Mosfets are available
    in the several 100 A range, There is also an IGBT that is also
    available in the kA range (of course not in standard semiconductor
    cases like TO 220, 247, etc). check www.eupec.com (part of
    infineon).
    When it comes to speed, the MOSFET is the fastest followed by the
    IGBT. Both MOSFET and IGBT can be turned of during conduction, the SCR
    will only turn off when the current drops below a certain value (hold-
    current).
    When it comes to high voltage application >600V, the IGBT outperforms
    the MOSFET (conduction losses in MOSFET are mostly higher because of
    high RDSon).
    Whether to use and SCR, IGBT or MOSFET depends on your application.
    Here also commercial aspects will count.
    When you do a search with both MOSFET, IGBT, thyristor and
    "comparison", you will probably find documents that will help you to
    make the right choice.
    Best regards,
    Wim
    Wimpie, Jun 9, 2007
    #3
    1. Advertisements
Similar Threads
  1. Replies:
    7
    1,496
    Frithiof Andreas Jensen
    Jul 24, 2007
  2. MR COFFEE
    14
    1,309
    Jasen Betts
    Aug 5, 2007
  3. MR COFFEE
    14
    1,528
    Jasen Betts
    Aug 5, 2007
  4. Paul E. Schoen
    Varistor across two SCRs
    Paul E. Schoen, Aug 18, 2007, in forum: Electronic Design
    18
    811
    Paul E. Schoen
    Aug 21, 2007
  5. KW
    Hockey puck SCRs
    KW, Dec 12, 2007, in forum: Electronic Basics
    1,582
Loading...
