power and tiebreakers
Discussion in 'Electronic Design' started by David Williams, May 7, 2008.
  1. Hello,
    Can anyone give me information on the purpose of a tiebreaker
    that is found in switchgear power distribution?
    This is more of an electrical than electronic question but
    I could not find an electricicity newsgroup.
    Meaning, in a typical building, you have power that comes
    from the street and goes into switchgear, then a transformer, then
    a feeder panel that has a tiebreaker switch there.
    As I understand it, if you have two feeders into a system,
    and one feeder fails, the tiebreaker switch opens up so that
    bad/faulty electricity from the bad feed cannot flow through the sysem
    until it is safe. That is about all I know.
    Anybody have any resources I can read on this?
    David
    #1
    1. Advertisements
  2. David Williams
    JeffM Guest
    The majority of Usenet is archived and is quite searchable.
    http://groups.google.com/groups/search?q=switchgear+electrical+-jobs
    JeffM, May 7, 2008
    #2
    1. Advertisements
  3. David Williams
    mpm Guest
    > > Hello,
    > > until it is safe. �That is about all I know.
    > > Thanks,
    > > David
    > A tie breaker (bus tie breaker) or switch is used to connect busses
    > together that are normally fed from independent sources. This is usually
    > done when performing maintenance on one of the sources so it can be
    > taken off line and the loads on its bus may be powered through the tie
    > breaker.
    > There are also some situations in which busses may be paralleled in
    > normal operation (tie breaker and both feeds closed), but it is
    > necessary to provide a means to disconnect one of the busses from the
    > other in the event of a fault.
    > Paul Hovnanian �
    > Procrastinators: The leaders for tomorrow.- Hide quoted text -
    > - Show quoted text -
    Ch-4 (TV) in Miami went off the air for about an hour once because
    someone had the bright idea to tie the UPS in separate from the
    generator.
    Utility power goes out, runs on UPS. (20 minutes run time reserve)
    Generator won't start. UPS dies.
    Generator finally started (after some effort), BUT the UPS would not
    release the tie until it recharged.
    Long story short: Main, UPS and Generator - and there the station was
    sitting in the dark.
    Unbelievable.
    mpm, May 7, 2008
    #3
  4. David Williams
    legg Guest
    On Wed, 7 May 2008 12:23:58 -0700 (PDT), mpm <>
    >generator.
    >Unbelievable.
    If you've got a dead syatem, there has to be a manual procedure and
    hardware present to allow manual over-ride of the dead hardware.
    When a UPS is configured, it's important to determine who's on first.
    RL
    legg, May 8, 2008
    #4
  5. David Williams
    mpm Guest
    On May 7, 3:39�pm, "Michael A. Terrell" <>
    wrote:
    > � �In Miami? �I believe it. �Aren't all the electricians members of the
    > IBEW?
    Hey Mike!
    I could probably come up with some smart-ass acronym for "IBEW" that
    includs all the relevant racial (latin/cuban/south american) slurs,
    but I'm afraid my Spanish is just too rusty... :)
    Although perhaps no longer contained to just South Florida, when
    exactly does "Immigration" become an "Invasion"? -mpm
    mpm, May 8, 2008
    #5
  6. On May 8, 9:02 am, "Michael A. Terrell" <>
    wrote:
    > > > IBEW?
    > > Hey Mike!
    >    My problem with the IBEW and Miami was all the shoddy work done on
    > fairly new homes that their members wired just before Hurricane Andrew.
    > The buiding inspectors who let them get by with the bad work were all
    > long gone, as well.
    A better electrical insatllation would have made the houses more
    resistant to the hurricane?
    Richard Henry, May 8, 2008
    #6
  7. David Williams
    mpm Guest
    On May 8, 12:02�pm, "Michael A. Terrell" <>
    wrote:
    I hear you loud and clear, Michael.
    But that's what you get when contractors can't read the plans because
    the plans are in English.
    For that matter, the permitting & zoning dept doesn't speak English
    either, so I guess they have no choice but to rubber stamp whatever's
    put in front of them.?
    Or possibly (and this is the truly scary alternative...) that quality
    of construction is actually considered a vast improvement over what
    they're used to "back home".
    Hell, I know an AM station in Mexico that uses modified, welded shovel
    heads for their electric disconnect. (I am not kidding!!)
    True story: I actually got "escorted" out of Dade Co. Permitting &
    Zoning once because 6 months after the hurricane, we could not get a
    simple 60-amp agricultural drop to power an emergency radio tower &
    shelter we had erected in the hours following the hurricane. They
    actually claimed the installation was "illegal" because we hadn't
    pulled a permit for the temporary electric - and they refused to even
    talk to us until that was remedied. Hello!! The department was
    closed for weeks after the storm! And the backlog was so bad
    afterwards, we couldn't get in, even when they did open up! We were
    actually doing them (and Dade Co residents) a favor by waiting.
    By that time, we had roughly 110kW of generator, and only needing
    about 30, gave the rest to the military - which promptly set up a 24-
    hour, armed command and control center right on the site. It's not
    like we were hurting....
    In fact, we were also providing antenna space on this same tower for
    Miami-Dade Fire Rescue and Dade Co. Emergency Services. Free of
    charge, I might add. But I digress..
    Anyhoo, after the rough treatment by Dade Co., and being advised we
    actually had to take the temporary tower & electric down (even though
    the original tower had not yet been reconstructed), I placed just one
    call.
    It was to US Marshall Service (who coincidentally, were tenants on the
    temporary tower seeing as it was the only one still standing!).
    The very next day, they arrived at Dade Co. P&Z and informed both the
    Chief Electrical Inspector and the P&Z Director that they had their
    choice of going to jail right then and there, or they could issue the
    temporary permit. (I guess a 3rd option would have been for Code
    Enforcement to try to get past the military...?)
    We had our permit that afternoon.
    And for the record, I don't think they were waiving those handcuffs in
    Spanish.
    (Actually, I wasn't there for all this, but I heard about it.)
    It still took another 2 months for FPL to get permanent power out
    there!!
    But now that the "invasion" is over, I'm wondering if we should have
    called INS back then instead? :) And that was in '92. Can you
    imagine how bad it must be now?
    Oh, and lest I forget....
    People do not realize just how bad a hurricane can be.
    Cat-3 and above for sure.... Evacuate!
    mpm, May 8, 2008
    #7
  8. David Williams
    JosephKK Guest
    wrote:
    >> > Hello,
    >> > until it is safe. ?That is about all I know.
    >> > Thanks,
    >> > David
    >> breaker.
    >> Paul Hovnanian ?
    >generator.
    >Unbelievable.
    A PE that could not be bothered to check the NEC should have been
    sued. See Articles 700, 701, and 702 would be a good start.
    JosephKK, May 10, 2008
    #8
  9. David Williams
    mpm Guest
    > >> > Hello,
    > >> > Thanks,
    > >> > David
    > >> breaker.
    > >> Paul Hovnanian ?
    > >generator.
    > >Unbelievable.
    > sued.  See Articles 700, 701, and  702 would be a good start.- Hide quoted text -
    The interesting thing about radio & TV broadcasting, is that many of
    the station "engineers" are not in fact P.E.'s
    I suspect this particular situation was "engineered" by someone who
    did not fully appreciate, or recognize the possibility that the UPS
    might fail to release itself until it was re-charged. The designer
    should not have relied so heavily on the UPS's disconnecting means,
    and should have installed manual override controls...
    mpm, May 11, 2008
    #9
    1. Advertisements
Similar Threads
  1. Dantanna
    Wall-Warts Power Usage and Power Supplies
    Dantanna, Mar 28, 2005, in forum: Electronic Basics
    3
    880
    Toni Ylisirniö
    Mar 30, 2005
  2. Ashish
    4
    579
    Ashish
    Aug 1, 2003
  3. Replies:
    3
    2,526
  4. overgeo
    4
    1,614
    Winfield Hill
    Jul 28, 2006
  5. Myron Samila
    Power amps-> power consumed vs output power.
    Myron Samila, Dec 8, 2003, in forum: Misc Electronics
    3
    2,184
    Myron Samila
    Dec 10, 2003
Loading...
