Powdered Ferrite???
Discussion in 'Electronic Basics' started by Radio Man, Nov 2, 2004.
  1. Radio Man
    Radio Man Guest
    Where in the U.S. can i purchase powdered ferrite in
    order to make very large ferrite rod antennas?
    #1
    1. Advertisements
    Are you talking about production quantities or just a few?
    How many thousand pounds a month?
    The stuff isn't very hard to make from the raw oxides with a kiln.
    John Popelish
    John Popelish, Nov 2, 2004
    #2
    1. Advertisements
  3. Radio Man
    Radio Man Guest
    What i want to do is fill the inside of various lengths of pvc pipe with
    a mixture of powdered ferrite & epoxy glue. The company "Stormwise"
    sells the above already made but the items are expensive. John Popelish"
    <> wrote in message news:...
    > John Popelish
    #3
    I don't know offhand if you can even buy it retail due to
    the health issues involved in working with certain ferrites.
    Do you care about its specific B/H properties? Why not
    just salvage a shitload of ferrite cores from say "dead" AM
    radios and grind them up yourself? A small ball mill is
    about as hard to put together as a small cement mixer. In
    fact, you can use a cement mixer and a bunch of ball
    bearings (you do have to bust up the cores a bit first).
    Mark L. Fergerson
    Mark Fergerson, Nov 3, 2004
    #4
  5. Bob Masta
    Bob Masta Guest
    On Tue, 02 Nov 2004 08:43:36 -0500, John Popelish <>
    John, any pointers or links on how to do this? (I have
    a small kiln.) Is there some ceramic binder involved,
    or is the oxide sintered directly? I assume this requires
    a black magnetic iron oxide, not the red stuff?
    Just curious, no immediate needs.
    Thanks!
    Bob Masta
    dqatechATdaqartaDOTcom
    D A Q A R T A
    Data AcQuisition And Real-Time Analysis
    www.daqarta.com
    Bob Masta, Nov 3, 2004
    #5
    Fine. So what is the answer?
    John Popelish
    John Popelish, Nov 3, 2004
    #6
    I would have to dig into my records for the exact recipe, but I
    remember making nickel zinc ferrite by ball milling red iron oxide,
    green nickel oxide and white zinc oxide, together, and firing the
    powder in a pottery kiln in ceramic crucibles. The sintered powder
    was black and a lot coarser than the starting powder and had measured
    magnetic properties very similar to commercial nickel zinc ferrite.
    After a second ball milling and screening I used it in an epoxy matrix
    as a non contact temperature sensor (utilizing the curie temperature
    of the material and an inductive pickup).
    I still have some of it.
    John Popelish
    #7
  8. John Popelish <> wrote:
    >> with a mixture of powdered ferrite & epoxy glue. The company
    Is there really a need for epoxy glue here?
    Shouldn't it work just as well if those pvc pipes are packed full with a
    powder of ferrite material?
    Roger J.
    Roger Johansson, Nov 3, 2004
    #8
  9. How about buying a bunch of large pot cores of the material you want and
    stack them together.
    Mike
    "Radio Man" <> wrote in message
    news:eek:qHhd.4718$RA4.455@trnddc06...
    Mike Knowlton, Nov 4, 2004
    #9
  10. Clarence
    Clarence Guest
    "Mike Knowlton" <> wrote in message
    news:njpid.63533$...
    > Mike
    I thought of that, but he seems bent on grinding them up, or rolling his own.
    BTW, TV deflection yokes have large chunks of Ferrite. If your operating at
    low enough frequencies.
    Clarence, Nov 4, 2004
    #10
    1. Advertisements
Similar Threads
  1. Radio Man
    Powdered Ferrite???
    Radio Man, Nov 2, 2004, in forum: General Electronics
    544
  2. Dummy
    9
    1,769
    JeffM
    Sep 24, 2003
  3. Dummy
    Ferrite bead on LM1084 adjustable regulator
    Dummy, Nov 20, 2003, in forum: Electronic Basics
    8
    903
    Dummy
    Nov 23, 2003
  4. Ethan
    Home made powdered iron cores
    Ethan, Feb 11, 2004, in forum: Electronic Design
    12
    4,960
    CBarn24050
    Feb 13, 2004
  5. Radio Man
    Powdered Ferrite???
    Radio Man, Nov 2, 2004, in forum: Beginner Electronics
    365
    Radio Man
    Nov 2, 2004
Loading...
Share This Page
