Positive or negative tip: how to tell?
Discussion in 'Electronic Basics' started by nobobo, Dec 3, 2004.
  1. nobobo
    nobobo Guest
    I have an old Sanyo cassette recorder, model M 1540A. Can find no
    information on what polarity of tip it uses. Only know that it's 6.0
    Volt. No markings on outside of case to show what it is. Sanyo website
    and customer service has no information and websearches come up empty.
    I have opened the unit. It takes 4 "C" cell batteries. The circuit
    board is old and isn't labeled. I can't tell how the AC adaptor jack
    is wired to the board. A label on the outside says to use AC Adaptor
    6CV120 or 6CV121.
    I have two adaptors I am considering using with it, both positive tip.
    One is a class 2 transformer that outputs 6V DC and 300mA. The other
    (much bigger)is labeled AC Adaptor and outputs 6V DC and 2000mA.
    Any ideas?
    nobobo, Dec 3, 2004
    #1
    1. Advertisements
  2. nobobo
    Bob Myers Guest
    "nobobo" <> wrote in message
    news:...
    > 6CV120 or 6CV121.
    Check to see which end of the battery stack connects
    to the PCB "ground" or common (generally, this will
    be fairly easy to find on the PCB). The "tip" will
    almost certainly be the OTHER end.
    Bob M.
    > Any ideas?
    Bob Myers, Dec 4, 2004
    #2
    1. Advertisements
  3. nobobo
    Ban Guest
    > 6CV120 or 6CV121.
    > Any ideas?
    With your ohmmeter put one side to the battery negative connection and check
    out which of the adaptors poles has continuity with it (possibly the
    outside). Then you can insert the plug without modifications. You can then
    try either supply.
    ciao Ban
    Bordighera, Italy
    Ban, Dec 4, 2004
    #3
  4. nobobo
    Mike Guest
    Don't connect the meter when set to measure ohms to a power source! Make
    sure you're measuring volts instead of ohms.
    Mike
    "Ban" <> wrote in message
    news:lQasd.455226$...
    > > 6CV120 or 6CV121.
    > > Any ideas?
    check
    > try either supply.
    > ciao Ban
    > Bordighera, Italy
    Mike, Dec 4, 2004
    #4
  5. nobobo
    Ban Guest
    > Make sure you're measuring volts instead of ohms.
    > Mike
    Read again what I wrote and do not confuse the original poster please.
    Ban
    Ban, Dec 4, 2004
    #5
  6. nobobo
    John Fields Guest
    >> Mike
    >Ban
    It would probably have confused the original poster less (and possibly
    prevented him from damaging his meter or blowing a fuse, or
    whatever...) if you'd have advised him to remove the batteries before
    doing any continuity testing, don't you think?
    John Fields
    John Fields, Dec 4, 2004
    #6
  7. nobobo
    Ban Guest
    >>> Mike
    >> please. Ban
    How can you reach the terminal with the batteries inside? And I want to see
    the guy that has working batteries in a years-old gadget?
    ciao Ban
    Bordighera, Italy
    Ban, Dec 4, 2004
    #7
  8. nobobo
    John Fields Guest
    >>>> Mike
    >>> please. Ban
    How do you know he can't? Usually it's pretty easy, you just stick
    the probe in there.
    > And I want to see the guy that has working batteries in a years-old gadget?
    See "Me-JF.tif" on abse. ;)
    John Fields
    #8
  9. nobobo
    DAW Guest
    Idiots, both of you.
    "John Fields" <> wrote in message
    news:...
    >>>>> Mike
    >>>> please. Ban
    > the probe in there.
    >> gadget?
    > John Fields
    DAW, Dec 5, 2004
    #9
  10. nobobo
    John Fields Guest
    Ha,ha, you're wrong.
    Ban isn't an idiot.
    >news:...
    >>>>>> Mike
    >>>>> please. Ban
    >> the probe in there.
    >>> gadget?
    >> John Fields
    John Fields
    John Fields, Dec 5, 2004
    #10
    1. Advertisements
Similar Threads
  1. Horace
    Positive and negative voltage regulators
    Horace, Feb 18, 2004, in forum: Electronic Basics
    6
    2,567
    Jamie
    Feb 18, 2004
  2. davidd31415
    positive and negative 12 V dc from a +12V dc signal?
    davidd31415, Jun 10, 2005, in forum: Electronic Basics
    3
    1,349
    Bob Monsen
    Jun 10, 2005
  3. Replies:
    11
    2,481
    jasen
    Jul 21, 2006
  4. joeyla
    Power Supply Negative/Positive
    joeyla, Jul 12, 2004, in forum: Electronic Design
    9
    1,230
  5. Anders
    19
    2,309
    Fred Bartoli
    Oct 21, 2004
Loading...
