portable generator - repair/replace stator
Discussion in 'Electronic Repair' started by Jack Patteeuw, Jun 25, 2007.
  1. I'm looking at buying a Devilbiss GB5000 portable generator. Seller
    says says it need a new stator for about $250. Does any place
    repair/rewind stators for small generators or is this strictly a remove
    and replace part?
    He says rotor and other parts are good (who knows ???)
    What would cause the stator to fail in the first place ?
    #1
    1. Advertisements
  2. Jack Patteeuw
    Meat Plow Guest
    > and replace part?
    Some have DIY stators but you may be opening up a can of worms here.
    Meat Plow, Jun 25, 2007
    #2
    1. Advertisements
  3. Jack Patteeuw
    Mike Berger Guest
    Typically arcing, extreme vibration, or exposure to severe
    environmental conditions sufficient to break down the
    insulation.
    > and replace part?
    Mike Berger, Jun 25, 2007
    #3
  4. Jack Patteeuw
    Charles Guest
    "Jack Patteeuw" <> wrote in message
    news:lMLfi.26980$...
    > I'm looking at buying a Devilbiss GB5000 portable generator. Seller says
    > says it need a new stator for about $250. Does any place repair/rewind
    > stators for small generators or is this strictly a remove and replace
    > part?
    Often, heat breaks down the insulation on the magnet wire.
    I'd be cautious about buying this unit.
    Charles, Jun 25, 2007
    #4
  5. Jack Patteeuw
    James Sweet Guest
    > part?
    The stator is probably fine, the Devilbiss generator I repaired for someone
    had a bad capacitor, the thing was a poorly made piece of junk though.
    James Sweet, Jun 26, 2007
    #5
    1. Advertisements
Similar Threads
  1. N Cook
    Rewinding a motor stator
    N Cook, Jun 14, 2007, in forum: Electronic Repair
    14
    1,444
    N Cook
    Jun 17, 2007
  2. Jamie Morken
    axial flux planar stator
    Jamie Morken, Nov 25, 2007, in forum: Electronic Design
    5
    945
    Jamie Morken
    Nov 26, 2007
  3. Ron van Sommeren
    16.5mm outrunner stator group buy (&parts)
    Ron van Sommeren, May 27, 2006, in forum: Electrical Engineering
    463
    Ron van Sommeren
    May 27, 2006
  4. mozza
    steps for replacing generator rotor, stator, capacitor
    mozza, Jul 8, 2008, in forum: Home Power and Microgeneration
    2,915
    Ulysses
    Jul 8, 2008
  5. Replies:
    3
    4,382
    Danno
    Sep 27, 2004
Loading...
