Poked a small hole in the rubber sub woofer surround
Discussion in 'Electronic Repair' started by Casca, Jan 15, 2004.
  1. Casca
    Casca Guest
    While screwing my new subwoofer into it's cabinet, I poked a hole/tore
    the rubbery speaker with the screwdriver. The sub still works fine
    and doesn't seem to be causing any issues. Anyone know of a good way
    to repair the hole?
    Thanks to all who answer.
    Casca, Jan 15, 2004
    #1
    1. Advertisements
  2. Casca
    Bill Bolle Guest
    > to repair the hole?
    Try vinyl cement. Some supply houses have speaker repair cements.
    Any cement that stays pliable should work.
    Bill
    Bill Bolle, Jan 15, 2004
    #2
    1. Advertisements
  3. Casca <> wrote in
    news:p:
    > to repair the hole?
    I repaired the surrounds on a couple of speakers with rubber cement. I
    would align the broken bits and hold them in position until the glue got
    tacky. It doesn't last forever, but ....
    Eric Cartman's Evil Twin, Jan 15, 2004
    #3
  4. Casca
    gothika Guest
    On Thu, 15 Jan 2004 03:38:13 GMT, Casca <> wrote:
    Rubber cement is good as was posted.
    I've also used silicone and if you can get your hands on some, there's
    cold set butyl rubber cement. Some industrial rubber houses carry it.
    If you use silicone try and get the most pliant/softest you can find.
    Stay away from the liquis silicone used to seal windshield gaskets as
    it starts out as a runny liqiud but harderns rock hard.
    The cheaper brands of clear all purpose silicone usually used for
    light/cold gasket work will do fine. Also aquarium silicone.
    Just use a small artists/craft brush and some fine gauze.
    Take a small patch of the gauze, just enough to overlapp to the edges
    of the hole and give it a light coat of silicone.
    Then press it to the hole via the rear of the surround.
    Then put a light coat on the front of the hole.
    Let dry for several hours.
    I've even used this type of silcone to coat the entire surround to
    seal it from rot.
    It can change the loading characteristics of the woofer, but so far
    all I've noticed in mine was a tendency for the woofer to develop a
    tighter bass.
    >to repair the hole?
    gothika, Jan 15, 2004
    #4
  5. Casca
    Guest
    On Wed, 14 Jan 2004 22:16:07 -0600, Bill Bolle <>
    >> to repair the hole?
    >Bill
    Just be careful that the solvents in vinyl cement may dissolve some of
    the cheap foam surrounds
    , Jan 15, 2004
    #5
  6. Casca
    Ken G. Guest
    Is the surround real rubber ? or is it that gray foam . I have seen
    alot of glued rubber car woofers and none of the glues used lasted ..
    wont adhear to the rubber .
    IF it is a very small puncture i would push any rubber bits back in
    place to make the hole as flat as possible then apply a very small 2
    drops or so of superglue just enough to get into the cracks and not all
    over the place .
    super glue holds rubber very well but it dries hard thats why only use a
    little .
    If the puncture or hole is big then superglue is not the answer .
    Ken G., Jan 15, 2004
    #6
  7. Casca
    putty Guest
    just use silicone sealant. Next.
    putty, Jan 15, 2004
    #7
  8. Casca
    JURB6006 Guest
    For this, a hole in the actual rubber foam crap or whatever it is, I agree with
    those who say to use silicone.
    However, when the foam gets separated from the basket or the cone, hot glue is
    alot better. Generally I have the speaker running at a low level and move the
    cone around to be sure it's in the right position. Just tack it with a drop or
    two, then turn it up a bit, if it doesn't rub, seal up the rest.
    In <u>your</u> case however, use the silicone, VERY sparingly, and just fill
    the hole, DO NOT smear it all over the place.
    And DO fix it, the air blowing through that hole will cause premature failure
    of the foam surround
    JURB
    JURB6006, Jan 15, 2004
    #8
  9. Casca
    Jerry G. Guest
    There are specialized cements that are pliable and made for speakers. I
    have had great success with contact cement. GC is one of the manufactures of
    contact cement used in the electronics industry. If you call around to some
    of the electronics suppliers I am sure you will find something. It is best
    to fix it, to maintain the speaker's performance.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    "Casca" <> wrote in message
    news:p...
    to repair the hole?
    Jerry G., Jan 15, 2004
    #9
  10. Casca
    Casca Guest
    Guys,
    Thanks so much for all of your suggestions. Great responses indeed.
    Since silicone was the most popular answer, I am going to go with
    that. I found some 100% aquarium silicon at Home Depot so I'll be
    applying it this weekend.
    As for the woofer, it is a brand new replacement sub I was putting in
    it's new home (speaker cabinet). My damned screwdriver slipped and
    poked a hole in the rubbery/foam gray surround. Its actually not a
    hole so much as it is a tear somewhat in the shape of an X. The tears
    are probably a quarer inch or less. The dont even go across the width
    of the foam. I should be ok using the silicone.
    Thanks again.
    >to repair the hole?
    Casca, Jan 16, 2004
    #10
  11. Casca
    Jack Guest
    Goodyear rubber cement
    news:p...
    > to repair the hole?
    Jack, Jan 16, 2004
    #11
  12. Casca
    Ken G. Guest
    Ok sence we now know its foam not rubber you should be using fabric glue
    Rubber cement will dry out & crack in time Silcone glue has acids in it
    that will eventually eat at the foam .
    You can listen to these quick fix garage repair guys or do it right ....
    your call .
    Ken G., Jan 16, 2004
    #12
  13. Casca
    Casca Guest
    Any suggestions on how to apply the glue.
    On Fri, 16 Jan 2004 08:18:24 -0700 (MST), (Ken G.)
    >your call .
    Casca, Jan 17, 2004
    #13
  14. Casca
    dragon Guest
    In article <>,
    says...
    > Thanks
    > >your call .
    I worked for a speaker repair and radio repair shop and if the hole is
    not to big use a dab of finger nail polish. It works for pin holes and
    such.
    Kenny
    dragon, Jan 18, 2004
    #14
  15. Casca
    gothika Guest
    wrote:
    I'm not a "quick fix garage repair guy".
    I built custom sound systems for home and theatre application for
    nearly four decades.
    Go do your research on released volitile compounds in silicone sealant
    like I have and you'd know that aquarium silicone sealant is a near
    "no acid" compound. It's food grade silicone which means no or less
    than 1% VOCS released during cure or during static life. IT HAS to be
    safe or else it''d kill the fish.
    THERE are cold set rubber solutions for sealing/repairing damaged foam
    and rubberized cloth surrounds if one's willing to spend the money.
    You have to be in the speaker building/repair industry before they'll
    sell them to you and then the minumim purchase is for a gallon can,
    usually costing between 70 and 150 bucks depending on whether you buy
    the name brand top grade or the cheap no name stuff made in the
    pacific rim.
    In the old days we'd recone/recoil speakers for custom applications.
    I have more than a passing familiarity with all of the materials that
    go into building a speaker from the core out to the frame.
    Low grade non volitile silicone is a good fix for most of todays foam
    surround speakers. Considering that most of even the better name
    speakers are built with the cheapest materials with a life expectancy
    of 2-4 years of normal use any possible degradation in the foam from
    silicone outgassing is the least of one's concern. You'll get more
    harmful compounds from regular household carpet or even the glue used
    to bind the mdf that makes up the speaker cabinet.
    I have a number of large woofers that I rubberized the foam surround
    on that are still going strong after several years.
    I have cone failure more often than surround breakdown.
    >your call .
    gothika, Jan 19, 2004
    #15
    1. Advertisements
Similar Threads
  1. Peter Huggon
    Sub Woofer
    Peter Huggon, Apr 17, 2004, in forum: General Electronics
    645
    Nirodac
    Apr 27, 2004
  2. Jean
    Sub woofer
    Jean, Jan 18, 2004, in forum: Electronic Equipment
    607
    gothika
    Jan 22, 2004
  3. heckubiss
    blown fuse in sub-woofer
    heckubiss, Aug 17, 2003, in forum: Electronic Repair
    8
    1,211
    Gary Lightfoot
    Aug 20, 2003
  4. fone.freaky
    8
    779
  5. Gerald Newton
    One hole straps - hole up or hole down?
    Gerald Newton, Oct 12, 2004, in forum: Electrical Engineering
    4
    1,040
    abuse
    Oct 17, 2004
Loading...
