Picture width - LG Widescreen
Discussion in 'Electronic Repair' started by Bryan Jones, Apr 4, 2004.
  1. Bryan Jones
    Bryan Jones Guest
    Anyone know how I can adjust the picture width on my LG 32inch widescreen
    tv.. is it a matter of taking the back off or is there a hidden service menu
    (its an RI-32CZ10RX)..
    Thanks in advance for any help...
    #1
    1. Advertisements
  2. Bryan Jones
    Art Guest
    Other than using the picture mode controls on the remote the settings would
    be through a setup menu with access via a Factory Setup Code. This
    information may ge found in their available service literature fron the
    company.
    "Bryan Jones" <> wrote in message
    news:ffTbc.19761$...
    > menu
    Art, Apr 4, 2004
    #2
    1. Advertisements
  3. Bryan Jones
    Bryan Jones Guest
    They don't seem too keen to give me this information. I contacted LG and
    they gave me the name of 2 local repair shops. 1 didn't want to know and the
    other wanted to charge 65ukp... I would like to avoid this if it's simply an
    adjustment required... which I guess it is...
    Does anyone know where I might find these codes? (have searched web etc...)
    "Art" <> wrote in message
    news:...
    would
    > company.
    widescreen
    > > menu
    #3
  4. Bryan Jones
    john Guest
    Bryan !
    Has this TV got a problem ,like has the width got bigger over time
    or you simply want to reduce the overall size of the width.
    Because making those types of adjustments could screw up
    the overall linearity of the picture especially if the TV has a fault.
    kip
    "Watch the return E-Mail addy its false"
    news:u3Ybc.21307$...
    the
    an
    etc...)
    > news:...
    > would
    > > company.
    > widescreen
    service
    > > > menu
    john, Apr 4, 2004
    #4
  5. Bryan Jones
    Bryan Jones Guest
    I think the picture width has always been too wide (when on 16:9)... I
    always assumed it was a mis-match between my cable box or something.. but on
    closer investigation it also happens with DVD etc..
    I guess I am loosing about an inch, or slightly less (I sometimes loose the
    first letter of a title that is left justified)..
    It's out of the 12mth warranty now!
    "john" <> wrote in message
    news:newscache$zptnvh$2x5$...
    > Bryan !
    > kip
    > the
    simply
    > an
    > etc...)
    > > news:...
    > > would
    the
    > > > company.
    > > widescreen
    > service
    > > > > menu
    #5
  6. Bryan Jones
    Chaos Master Guest
    Bryan Jones [] blew the tubes when screaming at the
    amplifier:
    Service mode for some LG TV's:
    With the TV turned on, press "MENU" in the front panel and "MENU" in the remote
    control, at the same time.
    I don't know exactly about your TV but it is worth a try.
    []s
    _____ ___ Chaos MasterĀ®
    |\/\/\| Posting from Brazil
    |/\/\/| MSN: wizard_of_yendor at hotmail.com
    ___|\/\/\| irc.brasnet.org #XLinuxNews #POA
    Chaos Master, Apr 4, 2004
    #6
  7. Bryan Jones
    john Guest
    Bryan..Try this
    Using the television's remote control:
    Turn the TV on. Hold down the [MENU] key on the remote until the menu clears
    or "Welcome to Zenith" appears then release the [MENU] key and within two
    (2) seconds hit the following five keys:
    [9], [8], [7], [6], [ENTER]
    -or-
    [9], [8], [7], [6], [DISPLAY]
    You will now have access to the service menus.
    [MENU] = Toggles between two menu pages
    [UP], [DOWN] cursor = selects the item for adjustment
    cursor = varies the value
    [POWER] = exit service mode and saves any adjustments made
    The items are appropriately captioned and the ones of interest should be
    easily spotted.
    kip​
    john, Apr 4, 2004
    #7
  8. Bryan Jones
    Bryan Jones Guest
    Thanks for both replies, my TV does not have a menu button on the front
    panel, and if I hold down the menu key the menu simply remains on the TV
    (Have held for about 50secs, I guess something would have happend sooner
    than that)...
    Anyone any other ideas to save me taking this to the repair shop?
    Thanks in advance
    Bryan
    news:newscache$ys0ovh$ul6$...
    > Bryan..Try this
    clears
    > -or-
    > easily spotted.
    > kip
    Bryan Jones, Apr 5, 2004
    #8
  9. Bryan Jones
    John DeGroof Guest
    On Sun, 4 Apr 2004 13:32:19 +0100, "Bryan Jones"
    There's either a service menu adjustment, or a pot inside, to adjust
    overscan. You should have a copy of Video Essentials handy, or
    something with an overscan pattern. You should use at least 5%
    overscan, if you don't want to see black borders on some programming.
    You should look into contacting the ISF to have a tech come to your
    house to adjust all parameters of your TV, rather than a repair shop.
    John DeGroof, Compressionist
    DVD, DAD, DVD Audio, MPEG, AC3, DTS, PCM, DSD, MLP
    John DeGroof, Apr 14, 2004
    #9
    1. Advertisements
Similar Threads
  1. Tom
    HITACHI 27CX5B Picture in Picture??
    Tom, Mar 7, 2004, in forum: Electronic Repair
    635
  2. martyn
    540
    martyn
    Jul 16, 2006
  3. Jackson
    Horizontal width of picture, RCA console
    Jackson, Jun 22, 2004, in forum: Beginner Electronics
    527
  4. Randy
    Snowy Picture on LG Plasma TV
    Randy, Jan 16, 2009, in forum: Electronic Repair
    5
    4,029
    f825_633
    Jan 20, 2009
  5. elmousa68
    Fuzzy Picture in LG Projection TV
    elmousa68, Jan 24, 2012, in forum: Electronics Repair
    3
    1,395
    (*steve*)
    Feb 11, 2012
Loading...
