PH meter schematic
Discussion in 'Electronic Design' started by Myauk, Nov 13, 2006.
  1. Myauk
    Myauk Guest
    I need a PH meter schematic to construct one for my father.
    Can anybody help me?
    Myauk, Nov 13, 2006
    #1
    1. Advertisements
    This is rather trivial. You need to measure the 700mV
    or so with a high impedance.
    Rene
    Ing.Buero R.Tschaggelar - http://www.ibrtses.com
    & commercial newsgroups - http://www.talkto.net
    Rene Tschaggelar, Nov 13, 2006
    #2
    1. Advertisements
  3. On 13 Nov 2006 01:09:52 -0800, in sci.electronics.design "Myauk"
    http://en.wikipedia.org/wiki/PH_meter
    martin
    martin griffith, Nov 13, 2006
    #3
  4. Guest
    , Nov 13, 2006
    #4
  5. Mike Monett
    Mike Monett Guest
    wrote:
    > http://www.ph-meter.info/pH-meter-construction
    > Borek
    > http://www.chembuddy.com
    I seem to recall a cheap homemade ph sensor mentioned in some newsgroup.
    Not as accurate as commercial units, but maybe good enough for non-critical
    applications.
    Do you have any idea how to do that?
    Regards,
    Mike Monett
    Antiviral, Antibacterial Silver Solution:
    http://silversol.freewebpage.org/index.htm
    SPICE Analysis of Crystal Oscillators:
    http://silversol.freewebpage.org/spice/xtal/clapp.htm
    Noise-Rejecting Wideband Sampler:
    http://www3.sympatico.ca/add.automation/sampler/intro.htm
    Mike Monett, Nov 24, 2006
    #5
  6. "Mike Monett" <> wrote in message
    news:Xns98853F93F78F9Noemailadr@208.49.80.251...
    > non-critical
    > applications.
    Amateur Scientist column in Scientific American?
    Homer J Simpson, Nov 24, 2006
    #6
    1. Advertisements
Similar Threads
  1. Change ac volt meter to a dc volt meter
    , Jul 3, 2005, in forum: Electronic Basics
    3
    2,843
    Roger Johansson
    Jul 3, 2005
  2. Mike Nowlen
    WTD: Boonton 260A Q-Meter Meter Movement
    Mike Nowlen, Aug 16, 2003, in forum: Electronic Equipment
    777
    Robert Baer
    Aug 17, 2003
  3. Mike Nowlen
    Mike Nowlen, Sep 4, 2003, in forum: Electronic Equipment
    836
    Robert Baer
    Sep 5, 2003
  4. Brad
    11 Meter to 10 Meter Yagi Antenna Conversion
    Brad, Jun 17, 2006, in forum: Electronic Repair
    14
    3,867
    DaveM
    Jun 20, 2006
  5. flarkblark
    Watt meter / Power meter / kWh meter
    flarkblark, Sep 11, 2003, in forum: Misc Electronics
    13
    1,546
    flarkblark
    Sep 24, 2003
Loading...
