Peak to Peak
Discussion in 'Electronic Basics' started by WAZ, Aug 22, 2006.
  1. WAZ
    WAZ Guest
    When we say there is 110V AC, is that peak to peak?
    WAZ, Aug 22, 2006
    #1
    1. Advertisements
  2. WAZ
    BobG Guest
    There is no such thing as 'peak to peak'... the voltage is a
    function.... is only has one value at any instant in time... it goes up
    to 110 V average or rms in 1/120th of a sec, then goes nagative the
    next half cycle. The peak is about 170V (rms x sqrt(2))
    BobG, Aug 22, 2006
    #2
    1. Advertisements
  3. WAZ
    chuck Guest
    The 110 VAC (or 125 VAC) is the rms
    value of the 60 Hz sine wave.
    ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
    http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
    ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
    chuck, Aug 22, 2006
    #3
  4. WAZ
    Eeyore Guest
    No.
    It's RMS.
    Graham
    Eeyore, Aug 22, 2006
    #4
  5. WAZ
    Eeyore Guest
    Yes there is.
    Graham
    #5
  6. WAZ
    Bob Myers Guest
    "BobG" <> wrote in message
    news:...
    Of course there's such a thing as "peak to peak" voltage; it's
    very often used to describe the maximum expected total
    "envelope" or "swing" of a given AC voltage or signal. It's
    generally not much of a concern, though, in electrical power
    discussions.
    The "110 VAC" (or 117 VAC or 230 or whatever number
    you encounter), though, is an "RMS" (root-mean-square)
    value, which is 0.707 of the peak voltage for a sinusoid.
    This is the voltage definition most commonly encountered in the
    electrical power field, as it is the "effective" voltage (i.e., the
    one you would use in power calculations for resistive loads -
    for instance, a 100 V (RMS) AC supply results in the same
    power consumed (and heating provided) by a given resistive
    heating element as would a 100 V DC supply, all else being
    equal.
    Bob M.
    Bob Myers, Aug 22, 2006
    #6
  7. WAZ
    BobG Guest
    Eeyore wrote:
    > Yes there is.
    I bet you can't measure it instantaneously.
    BobG, Aug 22, 2006
    #7
  8. WAZ
    Danne Guest
    "Eeyore" <> skrev i
    meddelandet news:...
    > No.
    > It's RMS.
    > Graham
    Yes, 110V AC is in RMS (110 Vrms). 110V AC is about 311 Vpp (peak to
    peak).
    Danne
    Danne, Aug 22, 2006
    #8
  9. WAZ
    PeteS Guest
    BobG wrote:
    > Eeyore wrote:
    > > Yes there is.
    Sure I can - just wait for 2 adjacent separate dv/dt = 0 instantaneous
    events and take the difference ;)
    [ok, that's cheating]
    Cheers
    PeteS
    PeteS, Aug 22, 2006
    #9
  10. WAZ
    Don Bowey Guest
    On 8/22/06 11:52 AM, in article
    , "BobG"
    <> wrote:
    > Eeyore wrote:
    >> Yes there is.
    I bet you I can. Now, put your money where your mouth is. Make it worth
    while, but affordable by you.
    Don
    Don Bowey, Aug 22, 2006
    #10
  11. WAZ
    Eeyore Guest
    BobG wrote:
    > Eeyore wrote:
    > > Yes there is.
    I'd like to see you measure anything truly "instantaneously" !
    Graham
    #11
  12. WAZ
    BobG Guest
    You sound like a betting man. I'll give you one reading. You agree that
    the voltage has only one voltage at any instant? So you can't do it
    unless you find the positive peak over a whole cycle, and the negative
    peak over a whole cycle. Sort of a job for some signal processing, or a
    couple of diodes and caps, or something that will average over 1/60th
    of a sec. That aint instantaneous is it?
    BobG, Aug 22, 2006
    #12
  13. WAZ
    Eeyore Guest
    Have you heard of something called the second derivative ? As in d2V/dt2 ?
    Graham
    Eeyore, Aug 23, 2006
    #13
  14. BobG wrote:
    > Eeyore wrote:
    > > Yes there is.
    Sure I can, with an oscilloscope.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
    Michael A. Terrell, Aug 23, 2006
    #14
    110 VAC RMS = 311.08 V P-P
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
    #15
  16. WAZ
    BobG Guest
    Nah. If its digital, and I give you one measurement, you get a dot. If
    its analog, and I give you one sweep, an instantaneous measurement is
    any height of the trace from zero to the trace. So you could measure
    the positive or negative peak at that instant, and hope or guess that
    the other peak would be symmetrical, but you've lost the bet because it
    would take you two measurements at two instants in time to measure two
    peak voltages. I win.
    BobG, Aug 23, 2006
    #16
  17. WAZ
    Phil Allison Guest
    news:...
    ** Groper MENACE ALERT !!
    ** Says a complete fool demonstrating his MASSIVE ignorance.
    > the voltage is a function.... is only has one value at any instant in
    > time...
    ** Yawn - just like ANY varying quantity.
    Ascribing magnitude to a steady AC voltage IS the issue - fuckhead.
    There are 4 ways:
    1. Average rectified value.
    2. RMS value.
    3. Peak value.
    4. Peak to peak value.
    The last is useful where the wave is asymmetrical or remains one polarity -
    ie the ripple voltage on a filter cap.
    ........ Phil
    Phil Allison, Aug 23, 2006
    #17
  18. WAZ
    ehsjr Guest
    I don't think so. First it was you who stuffed
    instantaneous into the discussion. Peak to peak
    is obviously not instantaneous. Still, lets go
    with your "instantaneous", and your single measurement.
    Install a peak detector circuit, then take a single
    measurement. At the instant you take the measurement,
    the cap holding the detected peaks ( + and - ) will
    hold the peak to peak value. You lose - not that that
    is important. What's important is below.
    Peak to peak is understood to be the difference between
    the highest peak and the lowest peak.
    http://www.facstaff.bucknell.edu/mastascu/eLessonsHTML/Signal/Signal2.htm#PeakToPeak
    Lets not confuse the issue by saying peak to peak doesn't
    exist and specifying bullshit "instantaneous" measurements
    where a scope shows one dot or a DMM or analog meter wouldn't
    have sufficient time to respond, let alone show a true reading.
    Ed
    ehsjr, Aug 23, 2006
    #18
  19. WAZ
    BobG Guest
    You should win a prize for being an ambassador of goodwill from down
    under. Have you ever been told that your brusk obscene language and
    outbursts at strangers makes you seem deranged? No one has ever told
    you that? I bet your coworkers are terrified that you might explode in
    an apoplectic spasm of tourettes tics if someone says 'Good morning Mr
    Allison'. I think the manual of personality disorders might have a
    chapter on Phil Allison syndrome. Pop a cork Phil!
    BobG, Aug 23, 2006
    #19
  20. WAZ
    Phil Allison Guest
    "BobG" = a complete fool demonstrating his MASSIVE ignorance.
    ** **** off - ASD freak.
    ....... Phil
    #20
    1. Advertisements
Similar Threads
  1. Joe
    Peak Load Voltage and DC Circuits
    Joe, May 18, 2004, in forum: Electronic Basics
    1,447
    John Popelish
    May 18, 2004
  2. Peter
    Peak current to charge a capacitor
    Peter, Aug 2, 2004, in forum: Electronic Basics
    8
    1,005
    Jonathan Kirwan
    Aug 4, 2004
  3. Teddy
    Peak to peak noise detection circuit
    Teddy, Apr 27, 2004, in forum: Electronic Design
    3
    1,198
  4. 5hinka
    measure peak to peak voltage?? how
    5hinka, Sep 21, 2004, in forum: Electronic Design
    18
    2,636
  5. Harry Dellamano
    What is Peak to Peak?
    Harry Dellamano, Feb 3, 2005, in forum: Electronic Design
    7
    2,320
    Tony Williams
    Feb 8, 2005
Loading...
