Panasonic Tau Won't Turn On
Discussion in 'Electronic Repair' started by jmail@fleming.tv, Jul 11, 2006.
  1. Guest
    Hello,
    I purchased a Panasonic Tau CT-32HC43 about 2.5 years ago. The set has
    generally worked great, but suddenly this afternoon it will not turn
    on. My wife tried to turn the set on and saw it begin to turn on, but
    then suddenly it went off and it hasn't turned on since.
    I've tried unplugging it for a few minutes and plugging it back in as I
    have found some suggest online, but that hasn't seemed to help. The
    Panasonic support office is closed (early), but in any case I'm sure
    they will just tell me to take it to the nearest service center which
    will be a pain due to the size of the unit.
    Has anybody experienced anything like this with this particular model
    who has an easy fix?
    Thanks in advance for any help.
    John Fleming
    , Jul 11, 2006
    #1
    1. Advertisements
  2. Zakes Guest
    Try checking the power supply if you know how to troubleshoot it. Did
    you check your fuse if it is not burnt?
    Zakes, Jul 11, 2006
    #2
    1. Advertisements
  3. JANA Guest
    The common cause is power supply and scan amp failures in these sets. You
    will have to take it for service, unless you are experienced and have the
    set-up to troubleshoot and service the set.
    JANA
    _____
    <> wrote in message
    news:...
    Hello,
    John Fleming
    JANA, Jul 11, 2006
    #3
  4. Guest
    Thanks for the help everyone. Well, I was hoping to avoid it, but it
    looks like I'll be calling the service center.
    Thanks!
    John
    > JANA
    > _____
    > <> wrote in message
    > news:...
    > Hello,
    > John Fleming
    , Jul 12, 2006
    #4
  5. John Guest
    Just to wrap this thread up, I had a service technician take a look and
    all that was needed was a new fuse. He checked the unit out and
    couldn't find the cause.
    Hopefully it won't happen again. Thanks for the help.
    John
    > Thanks!
    > John
    > > JANA
    > > _____
    > > <> wrote in message
    > > news:...
    > > Hello,
    > > John Fleming
    John, Jul 14, 2006
    #5
  6. Guest
    John
    I have the same problem. Any idea where the fuse is located?
    Mike
    > John
    > > Thanks!
    > > John
    > > > JANA
    > > > _____
    > > > <> wrote in message
    > > > news:...
    > > > Hello,
    > > > John Fleming
    , Jul 17, 2006
    #6
  7. dan Guest
    The fuse is on or near the PS. I had the same problem on my Tau
    recently. I tried but failed to repair it, thinking it was a PS
    problem. The fuse was not burnt out. It ended up costing $330 at the
    shop to replace various ICs, diode(s) and the flyback transformer.
    These sets won't turn themselves on if they sense a fault in a circuit.
    dan
    > Thanks
    > Mike
    dan, Jul 17, 2006
    #7
    1. Advertisements
Similar Threads
  1. John Miller
    Magnavox TV won't turn off, then won't turn on
    John Miller, Apr 17, 2004, in forum: Electronic Repair
    3
    1,847
    John Miller
    Apr 17, 2004
  2. g will
    Panasonic TV won't turn on...
    g will, Jun 10, 2005, in forum: Electronic Repair
    514
    g will
    Jun 10, 2005
  3. dahbrown
    Panasonic TC-51M02A Won't Turn On
    dahbrown, Feb 11, 2006, in forum: Electronic Repair
    417
    dahbrown
    Feb 11, 2006
  4. Pat
    967
    Sofie
    Sep 8, 2006
  5. tasteslikehome
    Panasonic CT32SX31 won't turn on
    tasteslikehome, Dec 23, 2009, in forum: Electronics Repair
    443
    tasteslikehome
    Dec 23, 2009
Loading...
