Panasonic KX-TC1210ALS Cordless Phone - Dead Handset
Discussion in 'Hobby Electronics' started by Dave, Feb 17, 2004.
  1. Dave
    Dave Guest
    The handset is completely dead. Battery is OK and charges OK. I've cleaned
    the buttons but no change. Phone appears to have volts on various points
    but I haven't got any circuit info.
    Any clues?
    Dave.
    Dave, Feb 17, 2004
    #1
    1. Advertisements
  2. "Dave" <> wrote in message news:<zrxYb.64137$>...
    > Any clues?
    > Dave.
    Is that one of the models with a randomly chosen code to talk to the
    base? If the code gets out of whack the phone appears dead. You have
    to place it in the cradle for 15 seconds, remove it and try again, it
    can take a couple of goes.
    Also try taking the phone out of the cradle whilst the phone is
    ringing. That way you shouldn't have to press any buttons.
    Well thats a couple of ideas.
    Mark
    Mark van der Eynden, Feb 18, 2004
    #2
    1. Advertisements
  3. Dave
    Dave Guest
    "Mark van der Eynden" <> wrote in message
    news:...
    cleaned
    points
    > > Any clues?
    > > Dave.
    > Mark
    I've also got one of those phones that does that. But, it lights up and
    eventually beeps when the code is scrambled.
    This dead phone shows absolutely no sign of life. Think it's supposed to
    display time and CND on the handset but it does absoulutely zilch no matter
    what I do.
    Dave.
    Dave, Feb 18, 2004
    #3
  4. #HISH
    #HISH Guest
    This is (I believe) a common problem in panasonic's.
    Its caused by the failure of the filter capacitors in the PS which gives a
    noisy supply and prevents the auto programming of the code.
    I cant remember the specific cap but if you search the net you should be
    able to track it down.
    Cheers
    Wayne
    news:GIBYb.64353$...
    > news:...
    > cleaned
    > points
    > > > Any clues?
    > > > Dave.
    > > Mark
    matter
    > what I do.
    > Dave.
    #HISH, Feb 19, 2004
    #4
  5. Hi,
    The fault you are talking will not stop handset from turning on. It will
    only prevet it communicating with base.
    I would very strongly suspect battery. If you have a power supply, use it
    instead of battery. Also, closely examine the PCB -- people drop phones and
    it may have a tiny crack. Usualy cracks appear near mounting holes.
    Rudolf
    "#HISH" <> wrote in message
    news:403506bb$0$22528$...
    > Cheers
    > Wayne
    > > news:...
    > > cleaned
    > > points
    > > > > Any clues?
    > > > > Dave.
    > > > Mark
    to
    > matter
    > > what I do.
    > > Dave.
    Rudolf Ladyzhenskii, Feb 20, 2004
    #5
  6. #HISH
    #HISH Guest
    I see the problem. I neglected to read the first post -Right you are
    Wayne
    "Rudolf Ladyzhenskii" <> wrote in
    message news:HOdZb.67372$...
    > Hi,
    and
    > Rudolf
    a
    > > Cheers
    > > Wayne
    > > > news:...
    I've
    > > > cleaned
    > > > points
    > > > > > Any clues?
    > > > > > Dave.
    it
    > > > > Mark
    and
    > to
    > > matter
    > > > what I do.
    > > > Dave.
    #HISH, Feb 20, 2004
    #6
    1. Advertisements
Similar Threads
  1. Joe Brower
    Need new handset for Panasonic KX-TG2257 cordless phone
    Joe Brower, Nov 5, 2003, in forum: Electronic Repair
    990
    Joe Brower
    Nov 6, 2003
  2. Mike
    877
  3. Just Allan
    850
    Bart Bervoets
    Jul 18, 2005
  4. panasonic cordless phone dead?
    , Nov 15, 2007, in forum: Electronic Repair
    629
  5. Clueless in Seattle
    Low Volume - Panasonic Cordless Phone Handset
    Clueless in Seattle, Nov 13, 2008, in forum: Electronic Repair
    2,546
    Clueless in Seattle
    Nov 14, 2008
Loading...
