Panasonic F60 error
Discussion in 'Electronic Repair' started by Ken G., Sep 20, 2007.
  1. Ken G.
    Ken G. Guest
    Dont have the unit here for a model # . Its about 2 years old still in
    its box and looking new .
    DVD recorder and VCR unit . When its plugged in a row of 00000 scan in
    a row a few times then F60 . No functions respond . When a tape is
    pushed into the vcr it takes it in kind of ``jerky`` does not load tape
    Ejects `jerky`` also
    I have removed both decks and still get the same F60 .
    The power supply has none of those regulator packs . This unit has no
    amplifiers either .
    #1
    1. Advertisements
  2. Ken G.
    Ken G. Guest
    Re:############# Panasonic F60 error ###### HELP
    My posts are getting LOST
    Ken G., Sep 21, 2007
    #2
    1. Advertisements
  3. Sjouke Burry
    Sjouke Burry Guest
    Re: ############# Panasonic F60 error ###### HELP
    Well with this low content thats no problem :)
    Sjouke Burry, Sep 21, 2007
    #3
  4. Meat Plow
    Meat Plow Guest
    Re: Re:############# Panasonic F60 error ###### HELP
    Maybe you should too.
    Meat Plow, Sep 21, 2007
    #4
  5. Ken G.
    Ken G. Guest
    Panasonic F60 error HELP
    Here it is again incase the educated missed it .
    Panasonic F60 error
    DVD recorder and VCR unit . When its plugged in a row of 00000 scan in a
    row a few times then F60 . No functions respond . When a tape is pushed
    I have removed both decks and still get the same F60 . The power supply
    has none of those regulator packs . This unit has no amplifiers either .
    Sence the first post on this i looked in the manual and it does not
    cover F60 . I took the power suppy out and tested the capacitors and all
    good , no shorted zeners . This unit has no use on it . I`d like to see
    it work
    #5
  6. Ken G.
    Ken G. Guest
    meat plow said ,, maybe you should too,,
    Now can you honestly find anything in that statement that helped anyone
    in any way ?
    I wish you well .
    #6
  7. Meat Plow
    Meat Plow Guest
    > in any way ?
    > I wish you well .
    It will help people who don't want to see your repetitive posts
    and attention seeking ############# Panasonic F60 error ###### HELP
    headers.
    #7
  8. Meat Plow
    Meat Plow Guest
    Re: Panasonic F60 error HELP
    > Panasonic F60 error
    > it work
    How about getting a model number like you've been asked and we'll take it
    from there.
    #8
  9. Ken G.
    Ken G. Guest
    Meat plow
    i would rather not receive help from you . After your responces i dont
    trust you or believe you . I am in search of educated technicians
    however i wish you well .
    Thanks all who may have looked at this
    Ken G., Sep 22, 2007
    #9
  10. Meat Plow
    Meat Plow Guest
    On Fri, 21 Sep 2007 18:28:01 -0600, Ken G. wrote:
    > Meat plow
    I couldn't care less who you trust or believe or even if you live
    or die. I told you to get a model number just like others did. If you
    can't do that then kindly **** off and come back only when you learn a
    little Usenet etiquette and the art of cooperation.
    Meat Plow, Sep 22, 2007
    #10
    1. Advertisements
Similar Threads
  1. boki
    692
    Active8
    Mar 25, 2005
  2. boki
    10
    1,073
  3. WayneL
    Error 1 and error 4 on the HP 4275A
    WayneL, Apr 5, 2005, in forum: Electronic Design
    8
    2,609
    Winfield Hill
    Apr 29, 2005
  4. WayneL
    WayneL, Apr 5, 2005, in forum: Electronic Equipment
    8
    696
    Winfield Hill
    Apr 29, 2005
  5. Shawn Chen
    1,328
    Shawn Chen
    Sep 28, 2008
Loading...
Share This Page
