PAL's and GAL's
Discussion in 'Electronic Basics' started by jozamm@gmail.com, Mar 30, 2006.
  1. Guest
    Hi ppl,
    I need to program sevetal PAL's and GAL's in an educational enviroment.
    I will be using a hobbyist programmer to do the programming as i do not
    need any large volumes.
    What software is available to enter the logic equations and compile to
    the fuse file? Does any schematic entry software exist which one can
    enter the schemtic and compule to the fuse map?
    Any sort of help on PAL's and GAL's would be greatly appeciated.
    Joseph Zammit
    Malta
    , Mar 30, 2006
    #1
    1. Advertisements
  2. Joel Kolstad
    Joel Kolstad Guest
    <> wrote in message
    news:...
    I suggest you visit www.latticesemi.com. They're one of the few programmable
    logic vendors around who still makes GALs (aka "SPLDs," for "simple
    programmable logic devices"); most other vendors (Altera, Xilinx, etc.) start
    out with CPLDs (complex PLDs), which are just larger & fancier. All the PLD
    vendors have a free version of their software which will work with their
    smaller devices (and "smaller" is still millions of gates!)
    Some of the software may still support schematic entry, but truth be told,
    you're largely much wasting your time using it. PLD design these days is done
    using hardware description languages such as Verilog and VHDL; your time is
    much better spent learning them. (Somewhat ironically, though, most design
    tools now support a graphical means of assigning schematic symbols to HDL
    code, and the tool they generates the code that merely connects signals
    between the various bits of code!)
    I'd suggest you do a little Googling for "programmable logic tutorial" or
    similar. Get a demo board with a CPLD on it and play around; many demo boards
    are <$50 and you can re-program the CPLD to your heart's content using, e.g.,
    a PC's parallel port connection.
    > Joseph Zammit
    > Malta
    Hmm... Malta, huh? OK, getting a demo board might be a little harder. I'd
    volunteer to send you one I had (it contained a Xilinx 9572, I believe), but
    unfortunately I tossed it out years ago. If you ask nicely there's a good
    chance someone around here will have one they're willing to part with, though.
    BTW, another good newsgroup for these kinds of queries is comp.arch.fpga
    (which is what CPLDs turn into when they lose their AND-OR array fixation and
    turn into a sea of a bazillion little look-up tables).
    ---Joel Kolstad
    Joel Kolstad, Mar 30, 2006
    #2
    1. Advertisements
  3. Paul Burke
    Paul Burke Guest
    What level education is it (school or university)? If the latter, I'd
    take the plunge and go straight for one of the free HDL development
    systems. Perhaps for beginners, Verilog would be easier than VHDL which
    is quirky to say the least. And there are loads of examples available on
    opencores.org. For the device, perhaps Xilinx Coolrunner, which are a
    bit small at the affordable level.
    One disadvantage of this route is that the tools are baroque, and it
    seems that the developers don't talk to each other. Students could spend
    as much time getting the tools to behave as they do learning about the
    devices and logic.
    If you really want the simplicity of FPGAs, something like CUPL or OPAL
    could be used. They used to be free, but I doubt their availability from
    manufactureres now. If you want to go down this route, mail me and I can
    send you OPALjr or one of the early Lattice schematic based ones (though
    licensing might be a problem for the latter). You can use GAL or PALCE
    devices- the fuse map is the same.
    Paul Burke
    Paul Burke, Mar 30, 2006
    #3
  4. wrote:
    > Hi ppl,
    You do not mention the packages, but DIP20/24 pin SPLDs are available from:
    ATMEL : ATF16V8BQL, ATF22V10QCQZ, ATF750CL
    http://www.atmel.com/dyn/products/param_table.asp?family_id=653&OrderBy=part_no&Direction=ASC
    Software: WinCUPL, smallish in size, compiles Boolean Equations.
    If you have problems programming those, the next step is
    PLCC44, and the ATF1502ASL are JTAG-ISP and 5V,with
    low cost JTAG cables available.
    Lattice: GAL and ispGAL variants, tend to have high Icc at
    5V variants.
    Their lead-free coverage is thin at the SPLD end.
    Software: Part of their larger FPGA offering, so it is a large
    download.
    Anachip PEEL series
    http://www.anachip.com/eng/product/pld.php
    Software : WinPLACE, smallish in size, Boolean equation entry.
    Older SW : PALASM still exists in some corners of the net, but the
    supported devices list is now ancient.
    Schematics: Not really worth it, with 8/10/32 macrocells,
    a text editor is probably the fastest entry - and you'll need
    one anyway to view the report logs.
    Programming: If you can find a commercial programmer, most of
    those support VECTOR test of programmed PLDs.
    -jg
    Jim Granville, Mar 30, 2006
    #4
  5. Deefoo
    Deefoo Guest
    "Jim Granville" <> wrote in message
    news:...
    > wrote:
    > > Hi ppl,
    > 5V variants.
    > download.
    > Anachip PEEL series
    > -jg
    I recently dug out PALASM to modify a GAL and it still works fine with my
    Lattice GALs (22V10D). It will only run under real DOS though. Here it is:
    http://www.engr.uky.edu/~melham01/ee481/software.htm
    --DF
    Deefoo, Mar 30, 2006
    #5
    > devices and logic.
    > manufactureres now.
    CUPL is still available, for free, as
    Atmel WinCUPL
    http://www.atmel.com/dyn/products/tools_card.asp?tool_id=2759
    which also includes the command line versions.
    CUPL is ideally suited to the GAL/PAL level the OP mentioned -
    where you code at the macrocell level.
    I'd forgotten about OPALjr :)
    -jg
    #6
  7. Didi
    Didi Guest
    Back in 1988/9 it was CUPL which made me write my first logic
    compiler (not available for windows etc.). It cost me a day to figure
    out why my 16V8 would not work until I discovered CUPL was not
    taking into account the output polarity of the feedback signals (did
    it right only as long as they were active high...). Fortunately,
    those were the days when the JTAG fusemap was listed in the
    datasheets so I could see what was going wrong and move
    forward.
    They may have fixed that since - I never touched it again afterwards.
    Perhaps still usable as a teaching tool, having access to the lower
    level data may be a great advantage in that respect. And well, if
    someone has to discover some bug yet again while learning, this
    will actually be advantageous, too....
    Dimiter
    Dimiter Popoff Transgalactic Instruments
    http://www.tgi-sci.com
    > > devices and logic.
    > > manufactureres now.
    > Atmel WinCUPL
    > -jg
    Didi, Mar 30, 2006
    #7
  8. Guest
    Hi
    Thanks for all the information. The only interest is more academic as i
    want to use them for demonsration purposes since i teach a vocational
    engineering course i do not only need to explain the use but even to
    show these devices working. I cant use VHDL or Verilog because the
    level is pitched too high for my students.
    The reason wanting schematic entry is for my students to visualize what
    is happening rather then the luxury of schematic entry for itself.
    Joseph
    , Mar 30, 2006
    #8
  9. Guest
    > wrote:
    <snip>
    > Anachip PEEL series
    I used that for years. The PA7024 was a drop-in replacment for the
    22V10 work-horse, but with enough buried cells and extra routing to be
    a lot more flexible. On at least one occasion I was able to rescue a
    board where the designer had failed to tolerance the timing inside
    their 22V10 by dropping in a PA7024 replacement and using most of the
    extra cells as delay elements.
    The PA7024 isn't exactly up to realising "system on a chip"
    applications but you can do a surprising amount of stuff with the logic
    it gives you.
    These days, I'd look for programmalbe logic parts that support
    in-system programming (ISP). I really like the Coolrunner parts
    (originally Philips, now Xilinx) but most places where I've worked have
    gone for Lattice parts for their low end programmable logic.
    Bill Sloman, Nijmegen
    , Mar 30, 2006
    #9
  10. wrote:
    > Hi
    Most of the tools can create a series of TXT files, that show the
    morphing that takes place, and you can always draw covering drawings.
    CUPL outputs a .DOC file, that shows the final equations, and some
    intermediate ones that show the pre-parser and macro expansion results.
    If you use the smaller CPLDs that also use a fitter, that also creates
    a TXT report file, that shows how the logic finally mapped to the
    silicon.
    As a tiny example:
    ~~~~~~~~~~~~~~~~ CUPL .PLD source ~~~~~~~~~~~~~~~~~~~~~~
    This is the Table, or simple ROM syntax - this is a 7 segment display.
    TABLE GCtr => [D4A,D4B,D4C,D4D,D4E,D4F,D4G] {
    Ca_ => Dri0; /* 0 */
    Cb_ => Dri1; /* 1 */
    Cc_ => Dri2; /* 2 */
    Cd_ => Dri3; /* 3 */
    Ce_ => Dri4; /* 4 */
    Cf_ => Dri5; /* 5 */
    Cg_ => Dri6; /* 6 */
    Ch_ => Dri7; /* 7 */
    ~~~~~~~~~~~~~~~~ CUPL .DOC report ~~~~~~~~~~~~~~~~~~~~~~
    D4A => !GCtr0 & GCtr1 & GCtr2
    # GCtr0 & !GCtr1 & !GCtr2
    D4B => GCtr0 & GCtr2
    D4C => GCtr0 & GCtr1 & !GCtr2
    D4D => !GCtr0 & GCtr2
    D4E => !GCtr0 & !GCtr1 & GCtr2
    # !GCtr0 & GCtr1
    # GCtr0 & GCtr1 & GCtr2
    D4F => !GCtr0 & !GCtr1 & GCtr2
    # GCtr0 & !GCtr2
    # !GCtr0 & GCtr1 & !GCtr2
    D4G => !GCtr1
    ~~~~~~~~~~~~~~~~ Atmel Fitter .FIT report ~~~~~~~~~~~~~~~~~~~~~~
    Same as above, but note the D4E has optimized by flipping the logic.
    D4A = ((!GCtr0.Q & GCtr1.Q & GCtr2.Q)
    # (GCtr0.Q & !GCtr1.Q & !GCtr2.Q));
    D4B = (GCtr0.Q & GCtr2.Q);
    D4C = (GCtr0.Q & GCtr1.Q & !GCtr2.Q);
    D4D = ((GCtr0.Q & !GCtr2.Q & !GCtr1.Q)
    # (!GCtr0.Q & GCtr2.Q));
    !D4E = ((GCtr0.Q & GCtr1.Q & !GCtr2.Q)
    # (!GCtr0.Q & !GCtr1.Q & !GCtr2.Q)
    # (GCtr0.Q & !GCtr1.Q & GCtr2.Q));
    D4F = ((!GCtr2.Q & GCtr1.Q)
    # (!GCtr0.Q & GCtr2.Q & !GCtr1.Q)
    # (GCtr0.Q & !GCtr2.Q));
    D4G = !GCtr1.Q;
    #10
  11. Paul Burke
    Paul Burke Guest
    > want to use them for demonsration purposes...
    Well done for introducing your students to this. Far better than the
    sterile "implement the following requirements using 2 input NAND gates"
    that is still all too common.
    How about using one of the equation input packages, but giving the
    students the task of producing the equations from the schematic?
    Paul Burke
    #11
  12. John  Larkin
    John Larkin Guest
    On 29 Mar 2006 22:02:06 -0800, "" <>
    wrote:
    >Hi ppl,
    >Joseph Zammit
    >Malta
    The ICT Place software is (I think) free
    http://www.ictpld.com/ftp/an7.pdf
    but you will need a programmer of some sort.
    I'm currently doing a PEEL 22CV10 design (blast from the past! There's
    nothing like having 10 macrocells to make you really reduce a design)
    and I'm using the older Dos-based APEEL software ("if you have a
    system with two floppy disks...") which is just simple PALASYM/ABEL
    syntax text entry of logic equations.
    There's probably some copies of PALASYM floating around (I must have
    one somewhere in the archives, I guess) for programming the genuine
    oldies, the PAL16L8's and such.
    John
    John Larkin, Mar 30, 2006
    #12
  13. Joel Kolstad
    Joel Kolstad Guest
    <> wrote in message
    news:...
    I have a hard time believing that your students can be smart enough to
    correctly implement designs using schematic capture but not using Verilog or
    VHDL. Not to mention what's already been said about industry using HDLs, so
    there's questionable benefit to spending time teaching people obsolete
    technology.
    Unless you restrict your students to only using AND gates & OR gates,
    flip-flops and perhaps an inverter on the input & output, this isn't going to
    happen. All the old schematic packages already had most sophisticated
    functions such as counters, shift registers, etc. built up for you to use (in
    fact, some tools had complete libraries of almost all the 74xx logic ICs!).
    Some tools would let you "drill down" and see the "primitive" logic elements
    used to implement the functions, though.
    ---Joel
    #13
  14. On 29 Mar 2006 22:02:06 -0800, "" <>
    wrote:
    ><snip>
    ><snip>
    I've looked over the responses and do not yet see a direct answer to
    the question of allowing a schematic entry of logic leading to a fuse
    map output, with a free tool.
    I would guess that if you could find a package that supports schematic
    entry (such as perhaps Altium Designer) and also supports GALs and
    PALs (don't know about Altium on this score), that you'd get there.
    But that's _very_ expensive to consider. What else might there be?
    Seems simple enough to do after the schematic entry graphical part of
    it is done -- and that itself can be kept relatively simple.
    An idea -- not sure if it would help. But it would be possible to use
    Linear Tech's LTSpice (SWCADIII) to do the schematic entry part of the
    job. It's free to anyone. It isn't difficult to create the symbols
    that would be used for teaching and the schematic is saved in ASCII
    form. I've already written the software to parse that ASCII source
    into an internal form that may be usable for generating the logic
    equations which could then be input to CUPL, I suppose. Would this
    fit the need?
    Jon
    Jonathan Kirwan, Mar 30, 2006
    #14
  15. samiam
    samiam Guest
    I have got a copy of CUPL (4.x? I think) I can send you if you are
    writing logic equations for 16x8 and 22v10 and such
    samiam, Mar 30, 2006
    #15
    > wrote:
    >><snip>
    >><snip>
    Another alternative is to use this :
    http://www.tech-chat.de/download.html
    That's a very nice piece of SW, by Andreas Weber, that allows
    ASCII type schematics to paste into any source file.
    So if we have a block that benefits from a drawing, we
    use this, and paste it into the source.
    Sure, it is not SCH -> 'PLD opcodes', but it is SCH
    augmenting PLD source.
    Altium have CUPL as one of their flows.
    > fit the need?
    ISTR cupl had a package called Liaison (?), and it did this SCH-EQN
    step [ mostly..:) ] - you need a special library suite, so the symbols
    can map onto PLD structures.
    We tried this, years ago now, and yes, it can be made to work.
    The problems we found are, the features you loose in a SCH flow.
    ** There are no conditional defines in a SCH package
    ** Adding notes on "this workes better than that", is cumbersome
    ** Paste of SIM and FIT output into the source, is also cumbersome
    ** CUPL has multiple flows, this only works on BOOLEAN EQN Entry
    ** TABLE form of code is not accessible
    ** SEQUENCE {} State engine code is also not accessible
    ** Creating of simulation files is not supported.
    ** Waveform style comments ?
    ** Editing is quite slow
    ** CUPL allows control of what collapses, and what does not.
    ** CUPL can export Fitter control, via PROPERTY statements.
    Not sure how a SCH flow would manage those - attributes (more work) ?
    Whilst with a good programmer's text editor ( we avoid CUPLs default
    'vanilla' editor ), all of the above is very simple.
    -jg
    #16
  17. Nico Coesel
    Nico Coesel Guest
    "Joel Kolstad" <> wrote:
    ><> wrote in message
    >news:...
    Look for Palasm.
    Its good to use both schematics and VHDL in an FPGA design. Schematics
    show how the design structured and you can include small timing
    diagrams. In VHDL/Verilog code it is easier to describe complex logic
    functions (like a state machine) which are total spaghetti in a
    schematic.
    If you write everyting in VHDL/Verilog you'll need to make a separate
    picture which shows how everything is connected if you want someone to
    be able to alter your design.
    Reply to nico@nctdevpuntnl (punt=.)
    Bedrijven en winkels vindt U op www.adresboekje.nl
    Nico Coesel, Mar 30, 2006
    #17
  18. Joel Kolstad
    Joel Kolstad Guest
    Hi Nico,
    "Nico Coesel" <> wrote in message
    news:...
    Yes, I agree with you. The point I was trying to make -- pretty poorly given
    how I worded it -- was that these days a schematic symbol such as an AND gate
    gets mapped to some VHDL or Verilog code, which then gets synthesized down to
    primitives & placed/routed. Whereas historically the AND gate was, itself, a
    primitive.
    #18
  19. On Fri, 31 Mar 2006 08:02:00 +1200, Jim Granville
    >> wrote:
    >>><snip>
    >>><snip>
    Actually, I think you missed understanding me. Maybe not, but the
    above looks to me like that. Probably my fault.
    The only reason I mentioned "ASCII" was technical, not visual. I am
    thinking about the possibility of using LTSpice as a free and
    graphical and supported schematic capture tool. No ASCII here. I
    mean, an easy to use tool for laying out the logic and editing it. The
    ASCII part is about the save files -- which aren't supposed to be read
    by humans even though they are ASCII. I was proposing the idea of
    reading those save files and automatically generating the input source
    to CUPL from that.
    None of this has anything at all to do with Weber's tool (or my tool
    which supplements his by using LTSpice for a similar purpose.)
    The point is that they aren't free... or cheap.
    >> fit the need?
    Which is what I'm imagining LTSpice for, if I gather you correctly.
    Now to the interesting part.
    Okay, this *could* be handled with specially annotated TEXT in
    LTSpice, I suppose. I'm no expert on this application space, so I'm
    ignorant about how this might work well in a schematic capture
    situation and I'm also ignorant about the teaching situation which may
    or may not need this feature. But I don't imagine it poses a serious
    problem, from my vague understanding of you.
    What do you mean by the above? I just don't follow, at all.
    I'm ignorant of this. Can you help me or point me somewhere? (I
    suppose I can search -- and will -- but I wouldn't object to a pointer
    or comment from you about it.)
    I was mentioning CUPL only because I saw references. Could be PALASM
    or other tool input source, as well, I imagine. Whatever is needed by
    the teacher is all I'm thinking of.
    Might be okay for teaching. We aren't talking about a complete tool
    here, though I wouldn't be averse to suggestions about how schematic
    capture could be made to work smoothly with a variety of such compiler
    input source formats and features.
    Same comment.
    Did the teacher mention that?
    And why not point out which free tools might achieve that, too? If
    any. No reason why those input file formats couldn't be supported --
    or is there?
    Got me.
    In LTSpice? I'm fine with it.
    Again, I suppose I need to be smarter about CUPL. I'm not, right now.
    So my ignorance allows me to see this as "no problem, yet." The
    question is, can a schematic capture program like LTSpice, tethered
    together with a command line tool that knows how to read the save
    files and parse them correctly, be used in conjunction with other
    standard tools to make a completed and useful package for teaching?
    I'm still thinking so. But I'm ignorant. So I'll read with
    attention.
    I get you. So you are arguing hard against the use of any graphical
    schematic entry method for the students. But the instructor has
    already said this is desirable for his use. I'm willing to go with
    that assurance.
    Jon
    #19
  20. Joel Kolstad
    Joel Kolstad Guest
    "Jonathan Kirwan" <> wrote in message
    news:...
    > So [someone else is] arguing hard against the use of any graphical
    > that assurance.
    #20
    1. Advertisements
Similar Threads
  1. flobber
    How to convert VCR from PAL BG/DK to PAL/I ?
    flobber, Dec 23, 2005, in forum: General Electronics
    1,946
    Arfa Daily
    Dec 23, 2005
  2. Guest
    GAL,PAL,PLD, CPLD,FPGA
    Guest, Aug 20, 2004, in forum: Electronic Components
    5
    1,844
    Guest
    Aug 21, 2004
  3. PAL's and GAL's
    , Mar 30, 2006, in forum: Electronic Design
    31
    1,335
    Jim Granville
    Apr 2, 2006
  4. Eike Lantzsch, ZP6CGE
    PAL-N, PAL-Nc
    Eike Lantzsch, ZP6CGE, Nov 26, 2004, in forum: Electronic Repair
    2,539
    Glenn Gundlach
    Nov 28, 2004
  5. Guest
    Guest, Aug 20, 2004, in forum: Hobby Electronics
    5
    1,082
    Guest
    Aug 21, 2004
Loading...
