Overheating transformer.
Discussion in 'Electronic Basics' started by TonyV, Feb 2, 2004.
  1. TonyV
    TonyV Guest
    I am using a 50W (230V - 12V) transformer to drive a 5W halogen lamp.
    It works fine but the transformer gets very hot after about 30 minutes or
    so.
    Can someone please explain to me why it overheats so quickly?
    Should I perhaps use a lower Wattage transformer?
    Thanks.
    TonyV
    South Africa
    TonyV, Feb 2, 2004
    #1
    1. Advertisements
  2. "TonyV" <> schreef in bericht
    news:...
    > so.
    > Thanks.
    > TonyV
    > South Africa
    Tony,
    Must be something wrong. Are you sure your numbers are correct? What's the
    current rating of that transformer? It should be around 4A. BTW the power
    rating of a transformer is usually given in VA, not in W. Assuming your
    numbers are correct, the only thing I can imagine is bad insulation inside
    the transformer. Does the transformer become hot when the lamp is
    disconnected but the 230V is not?
    petrus
    Outgoing mail is certified Virus Free.
    Checked by AVG anti-virus system (http://www.grisoft.com).
    Version: 6.0.572 / Virus Database: 362 - Release Date: 27-1-2004
    petrus bitbyter, Feb 2, 2004
    #2
    1. Advertisements
  3. TonyV
    Ian Stirling Guest
    > so.
    Assuming you are running the transformer at its design input voltage.
    You can economise somewhat on the transformer design if you design
    it so that it gets hot under no load.
    Is it a particularly cheap unit made for use with lights?
    Ian Stirling, Feb 2, 2004
    #3
  4. TonyV
    Guest
    "TonyV" <> wrote in message news:<>...
    > so.
    > Thanks.
    > TonyV
    > South Africa
    The more power it must pass, (watts) the bigger the transformer must
    be (to avoid it getting hot).
    The more iron (and copper) in it, the more power it can pass.
    Rob
    , Feb 3, 2004
    #4
    1. Advertisements
Similar Threads
  1. Method
    help with overheating pump
    Method, Sep 9, 2003, in forum: Electronic Basics
    4
    477
    norm d.
    Sep 13, 2003
  2. Jermin
    630
    Don Bruder
    Apr 28, 2004
  3. talisman
    Power transistor overheating
    talisman, Dec 22, 2005, in forum: Electronic Basics
    9
    1,653
    talisman
    Jan 8, 2006
  4. Don W
    7
    468
    Tim Shoppa
    Apr 24, 2006
  5. TonyV
    TonyV, Feb 2, 2004, in forum: Electronic Repair
    3
    1,163
    RubbishRat
    Feb 3, 2004
Loading...
