Op Amp virtual ground
Discussion in 'Electronic Basics' started by mahak, Nov 4, 2007.
  1. mahak
    mahak Guest
    This is mahak.
    can anybody tell me what is virtual ground concept.I refer to Micro
    electronics by Sedra & SMith.
    There it says Virtual Groung is because of infinite gain of amplifier.
    But if that is the case then it should be there for both inverting and
    non inverting amplifier. Please clarify.
    mahak, Nov 4, 2007
    #1
    1. Advertisements
  2. mahak wrote:
    > Hi,
    > This is mahak.
    An opamp with negative feedback connected between output and
    inverting input, tries to produce whatever output that will
    cause the inverting input voltage to match what is applied
    to the non inverting input. This is because the opamp has a
    very high differential voltage gain, so the only way the
    output will not be saturated either positive or negative is
    if the two inputs have an almost perfect match (the
    imperfection in that match providing the signal that is
    amplified by the high differential voltage gain to produce
    the finite output).
    So, when you connect the non inverting voltage to ground,
    the feedback forces the inverting input to be an almost
    perfect copy of that ground voltage. From the viewpoint of
    any signal connected to an input network to the inverting
    input, that signal acts as if the input network were
    connected to ground, even though it is just balanced there
    by gain and feedback. Pretending that the inverting node is
    grounded (virtually grounded) makes it a lot simpler than
    doing the math that includes the tiny voltages at that node
    because the amplifier gain is not actually infinite. It is
    a useful approximation.
    Of course, if you connect the non inverting input to some
    other voltage reference than zero, the inverting input is a
    virtual copy of whatever reference voltage you use, instead
    of ground.
    John Popelish, Nov 4, 2007
    #2
    1. Advertisements
  3. mahak
    BobW Guest
    "Jamie" <> wrote in message
    news:Mm8Xi.62$...
    > mahak wrote:
    >> Hi,
    >> This is mahak.
    > Hmm. I can't find that reference on the NET that you speak of.
    > In my eyes. A virtual ground is no more than a voltage
    > divider where the divided network is the ground and the outer of
    > the network are connected to the + & - of the single source of energy.
    > In this system, the common would be derived from the center divide of
    > the network.
    > I don't see where the gain of an amp comes into play here unless, they
    > are referring to the open-loop gain? That would be the (+) input
    > connected to the common/virtual ground tap point, and the (-) being the
    > input for example.
    > Taking measurements on this type of output with no input on (-) should
    > yield 0 volts. This is assuming an ideal amp.
    > biasing the (-) would result in very high gain but not infinite since in
    > theory, only ideal op-amps have that and there is no such thing as an
    > ideal op-amp or amp for that matter.
    > This seems to be a general theory question at best.
    > Maybe you read it incorrectly ?
    Whew. I feel dizzy. I think it's best that the OP stick with Popelish'
    explanation.
    BobW, Nov 4, 2007
    #3
  4. mahak
    Phil Allison Guest
    "mahak"
    ** Virtual ground refers to the situation where the " + " input of an op-amp
    is connected to circuit ground and the circuit is an inverting amplifier
    stage.
    Then the " - " input becomes a "virtual ground" since ( in all normal
    operation ) there is only the *tiniest* of AC or DC voltages on that pin.
    So, it is "virtually grounded" during operation.
    Calculations and analysis can use that simplifying assumption quite safely.
    ....... Phil
    Phil Allison, Nov 4, 2007
    #4
  5. mahak
    Eeyore Guest
    > the network.
    You do talk the most appalling tripe.
    Graham
    Eeyore, Nov 4, 2007
    #5
  6. mahak
    Eeyore Guest
    > explanation.
    Ignore Jamie's 'explanation'. He's an utter fuckwit.
    Phil Allison has explained it in a nutshell.
    Graham
    Eeyore, Nov 4, 2007
    #6
  7. mahak
    mahak Guest
    On Nov 4, 5:26 am, John Popelish <> wrote:
    > mahak wrote:
    > > Hi,
    > > This is mahak.
    > the finite output).
    > of ground.
    thanks. its convincing.
    mahak, Nov 4, 2007
    #7
  8. mahak
    Jamie Guest
    mahak wrote:
    > Hi,
    > This is mahak.
    the network.
    input for example.
    should yield 0 volts. This is assuming an ideal amp.
    in theory, only ideal op-amps have that and there is no such thing as an
    "I'm never wrong, once i thought i was, but was mistaken"
    Real Programmers Do things like this.
    http://webpages.charter.net/jamie_5
    Jamie, Nov 4, 2007
    #8
  9. mahak
    BobW Guest
    "Eeyore" <> wrote in message
    news:...
    >> explanation.
    > Graham
    Assuming Jamie had ever used an opamp then he would know what "virtual
    ground" is and how to (simply) explain it.
    It's amazing how people like Jamie will spew the limited knowledge that they
    have in an attempt to impress people. It always has the opposite effect, in
    the long run.
    Jamie just needs to go to school. If he's been to school then he needs to go
    back.
    BobW, Nov 4, 2007
    #9
  10. mahak
    Jamie Guest
    > news:Mm8Xi.62$...
    >>mahak wrote:
    >>>Hi,
    >>>This is mahak.
    >>the network.
    >>input for example.
    > explanation.
    > Bob
    Not understanding is the first sign of interest :)
    Jamie, Nov 4, 2007
    #10
  11. mahak
    me Guest
    Jamie <> wrote in
    news:e79Xi.120$:
    >Love how you left out the rest of my post as it did go on with
    >the op-amp discussion.
    > But that's typical of you any ways you lifeless turd.
    He could have said it "nicer", but you're way off.
    Your entire post is:
    The original question is in reference to an actual book often studied by
    EE's, not the NET.
    >the network.
    >input for example.
    get your eyes checked.
    No measurements are involved.
    This is a very specific (and basic) question about the operation of
    opamps. His reading skills are fine...
    ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
    http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
    ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
    me, Nov 4, 2007
    #11
  12. mahak
    Jamie Guest
    >>the network.
    > Graham
    Want to smell my shorts? I haven't changed them in a while! it
    should turn you on! I heard that turns you on!
    Jamie, Nov 4, 2007
    #12
  13. mahak
    BobW Guest
    news:LCaXi.581$...
    >> news:...
    >>>>explanation.
    >>>Graham
    >> they have in an attempt to impress people. It always has the opposite
    >> effect, in the long run.
    >> go back.
    >> Bob
    > Excuse me sir?
    I think it's time to play -- SPOT THE LOONEY!
    http://www.youtube.com/watch?v=CQmFMXkhXPY
    BobW, Nov 4, 2007
    #13
  14. mahak
    Jamie Guest
    > news:...
    >>>explanation.
    >>Graham
    > the long run.
    > back.
    > Bob
    Excuse me sir?
    or should it be jerkelator in your case?
    Limited knowledge you say? Where did get yours,
    the five and dime store?
    I think 30+ years in the field is enough.
    That also covers putting 2 son's through
    college for EE both graduating with a 4.5 grade average, both with
    dyslexia and extreme help from their father.
    The title on this group reads "BASIC" which means basic in terms
    of explanation and laymen descriptions.
    It's assholes like your self, parade around
    in public trying to impress some one.
    Facts are, you can impress those that don't know any better, but
    there are many that you will never impress with that kind of approach!
    Should I go on? or does it seem that some one might be talking about you?
    --------------- Bottom line is.. -----------------
    You'd be the wiser to keep the trap shut, you might even learn
    something to help that lacking personally you're exhibiting.
    Let me drop to your level for a moment.
    "Fucking idiot you are! 100 % Grade A snot nose jerk.
    I bet you're real popular around the boys with bull
    shit like that coming out of that urinal.
    If I didn't know any better, I think you're in bed
    with Mr. Graham, or is that Ham.
    You two were meant for each other.. "
    Now you know how you look on the other side.
    Btw..
    My employer just signed a 3 year contract with me, I'm above
    the 135k mark now. I've been with this employer for years, along
    with doing some of my own side adventures in robotics capacitor
    assemblers that you, you're self may have actually had in your hands,
    components made by automative equipment that I designed.
    Scare's the hell out of you doesn't it?
    I think if my skills were suffering, there would be some issues
    with that?
    Have a good fucking day and may your shorts and faults be many!.
    btw, I've turn down guys many times better than you in interviews
    for EE/Electronics E. Don't take it personally.
    "I'm never wrong, once I thought I was, but was mistaken"
    Jamie, Nov 4, 2007
    #14
  15. mahak
    Jamie Guest
    > news:LCaXi.581$...
    >>>news:...
    >>>>>explanation.
    >>>>Graham
    >>>go back.
    >>>Bob
    >>Excuse me sir?
    > Bob
    If that video is appealing to you, I can understand your problem.
    I might had enjoyed watching something like that when I was around 10
    or so how ever, I find that video very poorly acted out and boring to
    say the least. A very poor dictation of english humor, but then again,
    it's not much different than a couple of British posters I see here
    dumping their vile.
    Have a good day.
    Jamie, Nov 4, 2007
    #15
    1. Advertisements
Similar Threads
  1. Replies:
    649
  2. Jim Stevens
    Virtual Ground to Op Amps - Will This Work?
    Jim Stevens, Nov 17, 2012, in forum: Electronic Design
    17
    405
    josephkk
    Nov 21, 2012
  3. osterchrisi
    Connect 'virtual ground' to 'common ground'
    osterchrisi, Dec 17, 2012, in forum: Electronic Projects
    567
    osterchrisi
    Dec 17, 2012
  4. Rich K.
    Odd Circuit, OP Amp over OP Amp
    Rich K., Oct 9, 2013, in forum: Electronic Design
    15
    436
    Tim Williams
    Oct 11, 2013
  5. Russbo
    Op amp output into op amp input?
    Russbo, Oct 18, 2014, in forum: Circuit Help
    5
    398
    Russbo
    Oct 19, 2014
Loading...
