Op amp darlington current source oscillations
Discussion in 'Electronic Design' started by Justin Dobbs, Sep 14, 2004.
  1. Justin Dobbs
    Justin Dobbs Guest
    Hello!
    I have a simple linear current source circuit pictured below. The
    test
    loads are an 8 ohm wire-wound resistor and a 7-8 ohm 450 foot roll of
    hookup
    wire (tested separately).
    The purpose of the circuit is to take a PWM signal from a
    microcontroller, whose average DC value is 0.2 volts per amp desired,
    and feed the load with the desired current. I am testing the circuit
    on the bench using a separate DC power supply (with the grounds tied
    together in one spot). The transistor is actually a 2n6284 darlington
    pair, and the op amp is a dual rail-to-rail LMC6062AIM "micro power"
    op amp (in a very frustrating SOIC package). My interpretation of the
    spec sheet is that it will source up to 25 milliamps, which should be
    adequate for the darlington pair. The goal is to regulate between 0-5
    amps continuously with a 10mS rise time.
    I thought this circuit was working a few days ago. Now it seems to
    oscillate/switch on and off at 1-10 kHz depending on the lowpass
    filter I put after the first op-amp stage.
    This circuit initially had just the first op-amp stage driving the
    darlington pair though the 10-ohm resistor, with no lowpass filter,
    and the behavior was the same.
    With the large inductance (coil of wire), the current climbs to the
    desired value, then the transistor is appears to be switched off
    quickly until the current has fallen by 50%, and then the current
    begins to rise again. The current drops so quickly that the transorb
    conducts.
    With the wire-wound 8 ohm resistance, the current spikes up to the
    setpoint, then drops immediately to zero, and after a 1 millisecond
    delay, spikes again. In other words, a delta-train with no DC.
    Almost like you would expect from a fixed-frequency switchmode current
    chopper driving a resistive load.
    I want the circuit to provide smooth DC to the load. The op-amp
    appears to source enough current to turn the darlington sufficiently
    "on" to reach the current I want, but the regulation seems
    non-existent. I tried adding a 2n2222 to drive the base of the
    darlington, to make a transistor triplet, and this made the problem
    worse. The lowpass filter between the two op-amps only changes the
    frequency of this switching action. Eliminating the lowpass filter
    changes the ripple to a higher frequency (50 kHz and above). The
    behavior is the same with or without the 10 ohm resistor feeding the
    gate.
    For amusement I put a 18,000uF capacitor across the output of my power
    supply, just in case of poor regulation, but that doesn't seem to
    help. The 12 volts is straight from the (bench-top) regulated supply,
    and the 5 volts is derived from a linear regulator with a 470uF
    capacitor on its output. Putting a 220uF electrolytic across the op
    amp's .1uF tantalum bypass cap does not seem to cure the problem.
    I'm wondering whether my choice of op-amp is the problem due to its
    low output current. But the circuit seems to me like it should be at
    least stable. Although the transistor may be oversized a tad, the
    topology is simple and classic enough that it ought to work! What am
    I missing?
    Justin
    Rload=8ohm Lload
    12V |--------------/\/\/\------88888----------------------.
    5V |
    --- .1uF |
    | LMC6062AIM | |
    10k |\| __|\ | |
    ---/\/\/\----------|+\ 10k / |+\ 10ohm |C |
    | | >---/\/\/\---' | >--+--/\/\/\-----| _|_/
    | . --|-/ | .-|-/ | |E //\
    75V trans
    -- | |/| | | |/ | | /__\
    zener
    .1uF -- | | | |_______| | |
    /// | --- 10uF | |
    |___________________________________________+______|
    / 0.2 ohm
    \ 5W
    #1
    1. Advertisements
  2. Ban
    Ban Guest
    > gate.
    > I missing?
    > Thanks,
    > Justin
    > Rload=8ohm Lload
    > 5V |
    > --- .1uF |
    > | LMC6062AIM | |
    > 10k |\| __|\ | |
    > 75V trans
    > zener
    > /// | --- 10uF | |
    > / 0.2 ohm
    > \ 5W
    Take the first stage out completly and connect the feedback to the -input of
    the remaining amp. The 10k/10u will give a good stable DC voltage from the
    PWM control. Learn about opamps and try to understand how they work apart
    from cpying bits and putting them together. This is *not* software.
    ciao Ban
    Bordighera, Italy
    Ban, Sep 14, 2004
    #2
    1. Advertisements
  3. What was the purpose to have the left OpAmp running openloop ?
    It always is at either rail.
    Rene
    Ing.Buero R.Tschaggelar - http://www.ibrtses.com
    & commercial newsgroups - http://www.talkto.net
    Justin Dobbs wrote:
    [snip]
    > Rload=8ohm Lload
    > 5V |
    > --- .1uF |
    > | LMC6062AIM | |
    > 10k |\| __|\ | |
    > 75V trans
    > zener
    > /// | --- 10uF | |
    > / 0.2 ohm
    > \ 5W
    Rene Tschaggelar, Sep 14, 2004
    #3
  4. Justin Dobbs wrote...
    > The test loads are an 8 ohm wire-wound resistor and a 7-8 ohm
    > 450 foot roll of hookup wire (tested separately).
    > desired, and feed the load with the desired current. ...
    > The transistor is actually a 2n6284 darlington pair, and the
    > op amp is a dual rail-to-rail LMC6062AIM "micro power" op amp
    Go back to a single opamp section, but with a compensation path.
    .. Rload=8ohm Lload
    .. 12V |---------/\/\/\------88888-------.
    .. 5V |
    .. --- .1uF |
    .. 10k |\| | |
    ..---/\/\/\--+------|+\ 220 C |
    .. | | >--+--/\/\/\--- B _|_/
    .. | .--|-/ | E /_\
    .. .1uF --- | | --- 0.01uF +------'
    .. | | | 10k |
    .. | / 0.2 ohm
    .. | \ 5W
    - Win
    (email: use hill_at_rowland-dotties-org for now)
    Winfield Hill, Sep 14, 2004
    #4
  5. Fred Bloggs
    Fred Bloggs Guest
    You do know that with a 12V power supply, 8.2 ohms load resistance, and
    allowing 2V for the Darlington, that the maximum possible output current
    will be (12-2)/8.2= 1.2 Amps? or 1.2 x 0.2V/A= 0.24 Volts at the input,
    which you are most likely exceeding. For a 5 Amp limit, you would need
    5*8.2+2=41.2V of power supply in place of the 12V. Are you even close?
    Justin Dobbs wrote:
    > Hello!
    > test
    > hookup
    > conducts.
    > gate.
    > I missing?
    > Thanks,
    > Justin
    > Rload=8ohm Lload
    > 5V |
    > --- .1uF |
    > | LMC6062AIM | |
    > 10k |\| __|\ | |
    > 75V trans
    > zener
    > /// | --- 10uF | |
    > / 0.2 ohm
    > \ 5W
    Fred Bloggs, Sep 14, 2004
    #5
  6. Justin Dobbs
    Justin Dobbs Guest
    You conveniently cut out a key part of the original post:
    To clarify, this is what was oscillating:
    > > Rload=8ohm Lload
    > > 5V |
    > > --- .1uF |
    > > 10k |\| | |
    > > ---/\/\/\---------|+\ 10 or 0 |C |
    > > | | >-----------------/\/\/\-------------| _|_/
    > > | . --|-/ |E //\
    > > -- | |/| | /__\
    > > .1uF -- | | | |
    > > / 0.2 ohm
    > > \ 5W
    #6
  7. Jim Thompson
    Jim Thompson Guest
    >> > Rload=8ohm Lload
    >> > 5V |
    >> > --- .1uF |
    >> > 10k |\| | |
    >> > | . --|-/ |E //\
    >> > -- | |/| | /__\
    >> > .1uF -- | | | |
    >> > / 0.2 ohm
    >> > \ 5W
    Connect anode of zener to ground and see if the oscillation stops.
    ...Jim Thompson
    | James E.Thompson, P.E. | mens |
    | Analog Innovations, Inc. | et |
    | Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
    | Phoenix, Arizona Voice:(480)460-2350 | |
    | E-mail Address at Website Fax:(480)460-2142 | Brass Rat |
    | http://www.analog-innovations.com | 1962 |
    I love to cook with wine. Sometimes I even put it in the food.
    Jim Thompson, Sep 14, 2004
    #7
  8. Justin Dobbs
    Justin Dobbs Guest
    Whoops, I wasn't clear about that at all. The supply will be a 12
    volt battery which might range from 11 to 15 volts depending on state
    of charge and external charging.
    Ultimately I wish to swing 0-5 amps. The 8 ohms is a large roll of
    wire that I am using as a test inductance; I do not want to test with
    the real solenoid (a proportional fuel control valve), since the coil
    will quickly overheat without cooling measures in place. This means I
    will probably fine tune the circuit once I have the real load set up,
    but I am trying to achieve stability with some load (any load)
    initially.
    I have tried other test load combinations (using wire-wound resistors)
    to yield anywhere from 2 to 8 ohms. The real load will be a 2.6 ohm
    solenoid coil that I wish to drive proportionately. This yields a
    fully on current between 4 and 5 ohms.
    Sorry about the confusion!
    Justin
    Fred Bloggs <> wrote in message news:<>...
    > Justin Dobbs wrote:
    > > Hello!
    > > test
    > > hookup
    > > conducts.
    > > gate.
    > > I missing?
    > > Thanks,
    > > Justin
    > > Rload=8ohm Lload
    > > 5V |
    > > --- .1uF |
    > > | LMC6062AIM | |
    > > 10k |\| __|\ | |
    > > 75V trans
    > > zener
    > > /// | --- 10uF | |
    > > / 0.2 ohm
    > > \ 5W
    #8
    1. Advertisements
Similar Threads
  1. mark risher
    Sink or Source from Darlington Array?
    mark risher, Feb 24, 2004, in forum: Electronic Basics
    5
    3,285
    Ian Bell
    Feb 25, 2004
  2. FS
    OP Amp Oscillations/Feedback
    FS, Sep 13, 2004, in forum: Electronic Basics
    9
    710
  3. Replies:
    26
    998
    Ge0rge Marutz
    Jul 29, 2005
  4. dani
    darlington current source bi polar
    dani, Apr 14, 2004, in forum: Electronic Design
    529
  5. Patrick Chung
    Darlington pair is two stage current amplifier
    Patrick Chung, Oct 1, 2013, in forum: Electronic Design
    243
Loading...
Share This Page
