on the 741 OpAmp
Discussion in 'General Electronics Chat' started by mbyamukama, Apr 9, 2011.
  1. mbyamukama
    mbyamukama
    Apr 5, 2011
    8
    Hello All. I know that the output (amplified) of a practical amplifier cannot go beyind that of its power supply. I need to know if an input of 12V to a 741 with a supply voltage of 5V will damage the opAmp or if I will just get my 5V out without any trouble. I have a circuit in which the input to the opAmp is overridden (from -370mV to 12V), and I just want a stable +3V ouput from it. On that note, kindly inform on how I can ALWAYS have a positive voltage at the output of the opAmp. It is currently connected in an inverting configuration.
    #1
    1. Advertisements
  2. mbyamukama
    20,119
    1,345
    Check the absolute maximums section in the specs for the 741. It will tell you *exactly* how far you can push it.
    Read Note 4 on page 3 or 4 of this in conjunction with the absolute maximum ratings..
    (*steve*), Apr 9, 2011
    #2
    1. Advertisements
  3. mbyamukama
    mbyamukama
    Apr 5, 2011
    8
    Thanks steve. Just please inform on how I can ensure a STABLE POSITIVE voltage at the output
    #3
  4. mbyamukama
    20,119
    1,345
    If you reference the output voltage to the most negative supply rail then it will always be positive. I suspect that is not what you want however.
    If the input is positive and you want a positive output (with respect to your 0v rail) then you need a non-inverting amplifier.
    I'm not sure what you mean by "stable". The output voltage will vary with the input voltage. If it doesn't, then there's no point in having the input at all.
    (*steve*), Apr 10, 2011
    #4
    1. Advertisements
Similar Threads
  1. Ankur
    741 OPAMP voltage supply ?
    Ankur, Feb 26, 2004, in forum: General Electronics
    4
    590
  2. Frank
    7
    847
    Terry Given
    May 22, 2004
  3. MRW
    11
    1,148
    Jon Slaughter
    Feb 2, 2007
  4. George Herold
    "A new opamp's here, a new opamp's here!"
    George Herold, Feb 5, 2013, in forum: Electronic Design
    12
    959
    josephkk
    Feb 9, 2013
  5. citro250
    Designing Schematics for inverting 741 OPAMP
    citro250, Jan 21, 2014, in forum: Electronics Homework Help
    4
    610
    (*steve*)
    Jan 21, 2014
Loading...
