Old IC Datasheet
Discussion in 'Electronic Design' started by a.yaman@gmail.com, Jul 26, 2006.
  1. Guest
    Hey everybody,
    I was wondering if anyone can help me find the datasheet for the
    MCM5003AL (by Motorola) or point me to any place where I might be able
    to find it, whether a book or online or by any other method.
    Thank you
    , Jul 26, 2006
    #1
    1. Advertisements
  2. Tilmann Reh Guest
    According to <http://www.datasheets.org.uk/specsheet.php?part=MCM5003AL>
    this is a 64x8 Bit bipolar PROM in a DIP24 package.
    From the density, this must have been in the 70s... I don't have such
    old memory data books at hand; even my old Fairchild bipolar memory data
    book of 1980 starts with 1Kx8...
    It's also unlikely you'll get anything online. However, maybe you can
    get some information about a pin compatible device of another maker, if
    you just need the pinout details and some basic specs for error tracking.
    Tilmann
    http://www.autometer.de - Elektronik nach Maß.
    Tilmann Reh, Jul 26, 2006
    #2
    1. Advertisements
  3. Guest
    > Tilmann
    I tried looking for a pin compatible device but unfortunately the
    closest I came to it was the 74S475 which is not exactly pin
    compatible. I just need the pinout of the IC to be able to map it to
    another newer more available one.
    , Jul 26, 2006
    #3
  4. Guest
    > > Tilmann
    I got the pinout for the chip from an old version of DATA PAL but some
    of the labels don't make much sense. There's a pin that says "H" and
    it's in the place of the GND so I guess it's a ground. But there are
    two pins that say G2, does anyone have any idea what that means?
    , Jul 27, 2006
    #4
  5. Tilmann Reh Guest
    Look at the circuit the device was in: is that pin connected to ground?
    > But there are
    The label G is often used for global enable lines.
    Maybe that device has several (maybe different) enable (or chip select)
    inputs? (like the 74138, for example - one active low, two active high.)
    You should check where these pins are connected to. Maybe they are
    simply tied to constant voltages (VCC or GND).
    Tilmann
    Tilmann Reh, Jul 27, 2006
    #5
  6. schrieb:
    > Hey everybody,
    > Thank you
    Please look at
    http://www.datasheet4u.com/
    Yesterday I asked for the part, today they had it!
    Martin
    Martin Siegwarth, Jul 28, 2006
    #6
  7. Tilmann Reh Guest
    Martin Siegwarth schrieb:
    > Please look at
    Wow - that's good service.
    Now it's also clear that G1 and G2 are ground pins, which are also used
    for programming the fuse matrix (at least G2, from the maximum voltages
    specs).
    Tilmann
    Tilmann Reh, Jul 28, 2006
    #7
  8. YD Guest
    On 26 Jul 2006 04:18:58 -0700, wrote:
    >Hey everybody,
    >Thank you
    http://www.datasheetarchive.com is the one I most frequently use.
    - YD.
    Remove HAT if replying by mail.
    YD, Jul 28, 2006
    #8
    1. Advertisements
Similar Threads
  1. jay
    6
    957
    Joerg
    Apr 18, 2004
  2. tommiy
    Datasheet for old Roxkwell CPU
    tommiy, Jan 1, 2004, in forum: Electronic Components
    6
    696
    tommiy
    Jan 5, 2004
  3. Bo-Lennart
    S: Datasheet for MK5002N (an old MOSTEK IC)
    Bo-Lennart, May 31, 2004, in forum: Electronic Components
    3
    673
    soussi
    Jun 21, 2004
  4. Replies:
    2,769
  5. Berninia
    Audio Amplifier CCT5801 no datasheet - unable to find datasheet - help appreciated
    Berninia, Nov 21, 2015, in forum: Datasheets, Schematics, Manuals and Parts
    6
    567
    Berninia
    Nov 22, 2015
Loading...
