Noisy cooling fan Moulinex microwave
Discussion in 'Electronic Repair' started by Adrian Glaubitz, Apr 9, 2009.
  1. Hi,
    a friend of mine has an older microwave oven (Moulinex Y87 Optimo Duo)
    whose cooling fan has started to be very noisy and vibrating. I have
    checked the European parts distributor EURAS already and they list the
    fan as NLA.
    Anyone knows here, what kind of cooling fan these ovens usually employ
    so I might look for a cheap replacement fan (voltage, power consumption)
    ? My friend has moved to Norway, he just graduated and thus doesn't
    have the money to buy a new microwave oven, especially in Norway
    (expensive) :).
    I am in Germany and could buy one for him, so if anyone could give me a
    hint what to look for, I'd highly appreciate it. In the meantime, he is
    going to disassemble the oven to inspect the fan.
    Regards,
    Adrian
    #1
    1. Advertisements
  2. Adrian Glaubitz
    hr(bob) Guest
    On Apr 9, 12:34 pm, Meat Plow <> wrote:
    > On Thu, 09 Apr 2009 19:08:06 +0200, Adrian Glaubitz
    > <-berlin.de>wrote:
    > >Hi,
    > >fan as NLA.
    > >(expensive) :).
    > >Regards,
    > >Adrian
    > One source I use in USA is
    > http://www.emotorpro.com/fasco-electric-motors.aspx?gclid=CJKPzv-p5Jk....
    > Fasco makes small fractional HP ac motors but you need the
    > specifications both electrical and physical.- Hide quoted text -
    > - Show quoted text -
    Why not lubricate the fan bearings? Much easier and cheaper than
    replacing the whole fan. Sometimes slightly bending the sheet metal
    holding the sleeve bearings will also solve the problem, along with
    lubrication.
    hr(bob) , Apr 10, 2009
    #2
    1. Advertisements
  3. Hi!
    > Optimo Duo) whose cooling fan has started to be very noisy
    > and vibrating.
    If the fan still runs, there is a good chance you can fix it. It will
    be vibrating for one reason:
    1. It's loose.
    2. A blade is broken.
    3. The bearings are cheap, dry or both.
    1 and 3 are the easiest ones to fix. You can tighten the fan or oil
    the bearings.
    Reason 2 will require some fabrication or reattachment of the broken
    blade, as well as a solution to whatever made it break. It will also
    involve rebalancing the fan if you find that it runs noisily after
    repair, and to prevent excessive wear on the bearings.
    Most of the motors are fairly simple AC powered shaded pole units. A
    truly dead microwave oven could provide a replacement if one is
    required. As long as the operating voltage is correct, and you can
    figure out a way to mount the new motor, there should be no problem.
    William
    William R. Walsh, Apr 10, 2009
    #3
  4. Hi William,
    > 1. It's loose.
    > the bearings.
    > William
    Thanks for the comprehensive information. We're now just having another
    problem first: the fan is hardly accessible, he said he would have to
    disassemble the *whole* oven to access it, not very service-friendly. I
    don't know then whether he will actually do it or live with the problem
    until he can afford a new one. I keep trying to convince my friend.
    Thanks alot,
    Adrian
    Adrian Glaubitz, Apr 11, 2009
    #4
    1. Advertisements
Similar Threads
  1. ytreboe
    Temperature depending cooling fan in car
    ytreboe, Jan 4, 2004, in forum: Electronic Basics
    6
    630
  2. Holl
    Noisy Cpu Fan
    Holl, Nov 29, 2003, in forum: Electronic Repair
    26
    803
    WEBPA
    Dec 12, 2003
  3. Robert B.
    Vibrating and noisy ceiling fan...
    Robert B., Jun 15, 2009, in forum: Electrical Engineering
    4
    5,423
    Ainzo
    Feb 27, 2010
  4. David Farber
    ATX power supply fan noisy.
    David Farber, Apr 28, 2010, in forum: Electronic Repair
    30
    2,942
    Mike Tomlinson
    May 4, 2010
  5. (PeteCresswell)
    Microwave Oven: Noisy, shuts down sometimes?
    (PeteCresswell), Sep 30, 2010, in forum: Electronic Repair
    11
    650
    Meat Plow
    Oct 2, 2010
Loading...
