Noise Isolation Filter
Discussion in 'Electronic Projects' started by mallyajiggs, May 4, 2010.
  1. mallyajiggs
    mallyajiggs
    Feb 6, 2010
    18
    Hi folks,
    Do you have any recommendations for a noise isolation filter?
    basically i want the AC current through this outlet to be free of any high frequency noise that is greater than 5 KHz , it should just attenuate any noise.. desirably i want AC current that i get be free of any noise.
    thanks
    sunil
    #1
    1. Advertisements
  2. mallyajiggs
    davenn Moderator
    9,482
    911
    Sydney, Australia
    a bit more info would be helpful ....
    is this for an audio AC circuit ? a Mains voltage 240VAC or 110VAC circuit ??
    there are plenty of mains voltage filter circuits and units available
    cheers
    davenn, May 4, 2010
    #2
    1. Advertisements
  3. mallyajiggs
    mallyajiggs
    Feb 6, 2010
    18
    Sorry.. forgot to mention that.. it for the mains ..110V AC
    #3
  4. mallyajiggs
    19,601
    1,200
    What current does this device draw, and what symptoms are you seeing (or does this device currently inject noise onto the power line)?
    If you could tell us what the mystery device is, that may be helpful too.
    (*steve*), May 5, 2010
    #4
  5. mallyajiggs
    mallyajiggs
    Feb 6, 2010
    18
    hehe.. let me de mysterify !
    I have a couple of devices attached to a circuit and i want to read the noise they inject into the power line.
    I am basically isolating a couple devices and measuring the noise they inject ,
    but i want to read only the noise they inject and do no want the existing noise to skew my readings...
    so this circuit of mine will not more than 5 Amps of current, I am not looking for a fancy noise filter, any simple one which would isolate / attenuate the existing noise emitted by other devices.
    mallyajiggs, May 5, 2010
    #5
  6. mallyajiggs
    davenn Moderator
    9,482
    911
    Sydney, Australia
    davenn, May 5, 2010
    #6
  7. mallyajiggs
    mallyajiggs
    Feb 6, 2010
    18
    Hi i did build the notch filter...,
    was looking for a more specific one than that ... anyways.. will try the suggested one , its only 6 $ !
    #7
    1. Advertisements
Similar Threads
  1. eeh
    T LP filter and RC LP filter
    eeh, Apr 1, 2005, in forum: Electronic Basics
    630
  2. Tom Becker
    PLL input filter vs. loop filter
    Tom Becker, Apr 9, 2006, in forum: Electronic Design
    44
    2,450
    Tom Becker
    Apr 19, 2006
  3. KeeperOfLogic
    Volume (decibel) Low-pass filter (NOT frequency filter)
    KeeperOfLogic, Oct 21, 2006, in forum: Electronic Basics
    9
    1,588
    Bob Masta
    Oct 22, 2006
  4. Emanuele
    3
    2,436
    budnewsaisp.com@gmail.com
    Oct 15, 2008
  5. Jasen Betts
    Re: 120V AC "Line Filter" aka Mains Filter
    Jasen Betts, May 21, 2009, in forum: Beginner Electronics
    3,478
    Jasen Betts
    May 21, 2009
Loading...
