Nicad vs Nimh batteries in portable phones
Discussion in 'Electronic Repair' started by LB@notmine.com, Oct 9, 2004.
  1. Guest
    Just had to replace the batteries in a pair of Vtech phones (model
    20-2481).
    Old were nicad. New are Nimh. Differences? Best way to charge, how
    often?
    Figure some of the kind folks in here will have knowledge.
    TIA
    LB
    , Oct 9, 2004
    #1
    1. Advertisements
  2. << Just had to replace the batteries in a pair of Vtech phones (model
    20-2481).
    often? >>
    LB-
    I replaced NiCd with NiMH on another phone about six months ago, and it seems
    to be holding up well. The voltage of both types is nearly identical. Since
    the cross-reference indicated the new battery was correct for my phone, I have
    to assume that the built-in charger will work.
    In my phone, the NiMH battery has greater capacity. If completely run down, it
    would most likely take proportionately longer to fully charge in the old
    charger, but that charge would supply a longer operating time than the original
    NiCd battery would.
    Just use yours like you did before, and it should be fine. If it didn't run
    down before, it should be less likely to run down now.
    Fred
    Fred McKenzie, Oct 9, 2004
    #2
    1. Advertisements
  3. Jerry G.
    Jerry G. Guest
    Use the new batteries as normal. The new Nimh type should have less of a
    memory problem, and may last longer.
    Jerry G.
    <> wrote in message news:...
    20-2481).
    often?
    TIA
    LB
    Jerry G., Oct 10, 2004
    #3
  4. Guest
    >20-2481).
    >often?
    >TIA
    >LB
    Since the charging circuit is designed for NiCad, it might cause
    problems with the MiMh battery. I think the problem comes in on the
    trickle charge, after the battery has been fully charged. Generally
    the rule is, you can charge a nicad on a NiMh charger, but not the
    other way around. But hey, if it works, it works.
    Link to more than you wanted to know about rechargeable batteries.
    http://www.buchmann.ca/
    , Oct 10, 2004
    #4
  5. RMD
    RMD Guest
    LB,
    You better hope the phone charger is designed to deal with NiMH
    batteries. You can get a charger fire with NiMH batteries on the
    trickle charge that NiCad batteries will cope with. NiMH batteries
    mustn't have a continuous residual trickle charge.
    I'd definitely not leave the phone charging overnight, when it might
    be charged excessively.
    Ross
    >20-2481).
    >often?
    >TIA
    >LB
    (To get email address ROT 13)
    RMD, Oct 11, 2004
    #5
  6. gothika
    gothika Guest
    On Mon, 11 Oct 2004 04:22:42 GMT, (RMD) wrote:
    >LB,
    >Ross
    You must be thinking about Lion batteries.
    NiMH tolerate overcharging pretty much the same as Nicads.
    A trickle charge is no more harmful to NiMH than it is to Nicads.
    I converted all my cordless phones to NiMH a couple of years ago and
    they're doing just fine.
    Even my charger(Ray-O-Vac PS3) charges BOTH Nicads and NiMH.
    Virtually ALL charging systems in cordless phones ramp the charge rate
    down as the battery tops off so the OP should be fine with NiMH.
    >>20-2481).
    >>often?
    >>TIA
    >>LB
    gothika, Oct 11, 2004
    #6
    1. Advertisements
Similar Threads
  1. KellyClarksonTV
    NiCad and NIMH
    KellyClarksonTV, Jun 4, 2004, in forum: General Electronics
    3
    633
    WDino
    Jun 7, 2004
  2. Mark
    charging NIMH and NICAD batteries
    Mark, Jul 18, 2003, in forum: Electronic Design
    741
    R.Legg
    Jul 18, 2003
  3. Elmer Bataitis
    European Phones and US phones
    Elmer Bataitis, Jul 16, 2003, in forum: Electronic Repair
    4
    782
    Jerry Greenberg
    Jul 17, 2003
  4. inetquestion
    nimh replacement batteries for nicad cordless drill
    inetquestion, Mar 20, 2008, in forum: Electronic Design
    12
    1,871
    Phil Hobbs
    Mar 20, 2008
  5. SimonP
    Can a Nicad charger be used for NiMH batteries?
    SimonP, Sep 13, 2009, in forum: General Electronics Chat
    4
    1,584
    SimonP
    Sep 17, 2009
Loading...
