need to understand source and sink currents w.r.t output buffers
Discussion in 'Electronic Design' started by topgun, Jun 17, 2005.
  1. topgun
    topgun Guest
    Hi all,
    Can someone please explain the terms sink current and source
    currents with respect to output buffer in a design.
    When does the output buffer source current and when does it sink
    current?? (i.e relationship to the applied voltages..)
    I am digital engineer and I am trying to understand and expand my
    knowledge related to analog and other fields....
    #1
    1. Advertisements
  2. topgun
    Tim Wescott Guest
    topgun wrote:
    > Hi all,
    > Thanks
    Do this thought experiment:
    Take a capacitor that's charged to 0.75V and connect it to a dry cell
    battery. The capacitor voltage will rise to 1.5V because the battery
    sourced current.
    Now take the capacitor, again charged to 0.75V, and connect it to a
    resistor. The capacitor voltage will drop to 0V because the resistor
    sunk current.
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Tim Wescott, Jun 17, 2005
    #2
    1. Advertisements
  3. topgun
    Joerg Guest
    Hello Topgun,
    With modern CMOS logic you can obtain a rough estimate by finding the ON
    resistance of the upper FET and that of the lower FET from the data
    sheet. Sometimes they are the same but not always. That, Ohm's law and
    the voltage of the load at a given time will provide an estimate of the
    current the device can sink and source at a given VCC.
    But be aware that it isn't always allowed to sink or source as much as
    these resistances would provide for.
    For some logic chips the ON resistance isn't stated explicitly. Then
    check the drops from VCC and GND respectively for various load currents.
    That allows to estimate the ON resistances.
    Regards, Joerg
    http://www.analogconsultants.com
    Joerg, Jun 17, 2005
    #3
  4. topgun
    Mike Monett Guest
    topgun wrote:
    > Hi all,
    > Thanks
    That might be a dangerous question to ask in this newsgroup. A recent
    thread discussin DC vs AC went over 300 posts. But this one should be
    simple so I'll take a crack.
    Consider a 74HC device. When the output is logic one, it is at +5V. Any
    load to ground draws current, which must be supplied by the device. In
    this case, the device is sourcing the current.
    OTOH, when the output is logic zero, it is at 0V. A load connected to +5V
    will draw current from the +5, though the device to gnd. In this case,
    the device is sinking the current.
    The same concept applies to op amps.
    Hope that helps.
    Mike Monett
    Mike Monett, Jun 17, 2005
    #4
  5. topgun
    Ban Guest
    topgun wrote:
    > Hi all,
    Well, as a digital engineer you will know the states high(2-5V) and
    low(0-0.8V). These are TTL-levels for 5V logic. The device has to source
    current when the level is high. So if the device can source 20mA it means
    that with a load that consumes 20mA i.e. a LED the output voltage is higher
    than 2V. In many cases it will be higher than 4V even.
    When the level is low, the buffer sucks in the current from the output. It
    sinks for example 50mA, so when 50mA are flowing into the output, the
    voltage is maintained lower than 0.8V. You could switch on two paralleled
    LEDs with 20mA each.
    Usually a device can sink more current than source, and also has more
    voltage loss and dissipation when sourcing, what can be seen on the specs
    (0.8V vs. 3V across the device).
    With modern CMOS parts the source and sink abilities are almost equal and
    also the transition point is in the middle of the voltage range.
    ciao Ban
    Bordighera, Italy
    Ban, Jun 17, 2005
    #5
  6. topgun wrote:
    > Hi all,
    These descriptions are based on the fluid pressure analogy for
    voltage, with more positive voltage being analogous to more pressure.
    So currents driven from a positive voltage through a driver control
    circuit through load to a more negative voltage are referred to as
    sourced currents. This is because the fluid analogy would be a source
    of fluid being pushed through valve and then through a resistance
    (garden hose) and draining out on the ground (zero volts). Sinked
    currents are analogous to fluid sinking down a drain valve on the
    floor. So load currents that are driven by an external positive
    voltage, and passing through the driver to a more negative (or zero)
    voltage are referred to as sinked currents.
    Sourced = flow controlled on the positive voltage side of the load.
    Sinked = flow controlled on the negative voltage side of the load.
    John Popelish, Jun 17, 2005
    #6
  7. topgun
    Joerg Guest
    Hello Mike,
    > thread discussin DC vs AC went over 300 posts. ...
    And I always thought AC DC was an Australian rock band.
    Regards, Joerg
    Joerg, Jun 17, 2005
    #7
  8. topgun
    topgun Guest
    Hi All,
    Thanks for the good insight into current sourcing and sinking
    I guess now I have much better visulaization...of the whole concept..
    thanks again..
    #8
  9. topgun
    Reg Edwards Guest
    The first things to do are to discard your chip manufacturer's data
    books, go back to square one, and swot up on Ohms Law and elementary
    circuit analysis.
    I say this with the nicest of intentions. It will require a little
    hard work on your part to catch up.
    Reg.
    Reg Edwards, Jun 17, 2005
    #9
  10. topgun
    Pooh Bear Guest
    topgun wrote:
    > Hi all,
    Source means current flowing out.
    Sink means current flowing in.
    Graham
    Pooh Bear, Jun 17, 2005
    #10
  11. topgun
    Tam/WB2TT Guest
    "topgun" <> wrote in message
    news:...
    > Hi all,
    > Thanks
    BS aside, if you connect a resistor from output to ground, you are SOURCING
    current into the load; If you connect a resistor from output to VCC, you are
    SINKING current.
    Tam
    Tam/WB2TT, Jun 17, 2005
    #11
  12. topgun
    Mike Monett Guest
    > Graham
    In metals, like pcb traces, current flow is by means of electrons.
    So when the electrons are flowing out, do you mean the device is sourcing
    current, and when electrons are flowing in, it is sinking?
    Mike Monett
    Mike Monett, Jun 18, 2005
    #12
  13. topgun
    Mac Guest
    >> Graham
    > Mike Monett
    Mike, why are you asking this? Is there some kind of context that has
    gone before (which I missed)? Do you have something against Pooh Bear?
    For the record, current and electrons flow in opposite directions by
    convention. Blame Ben Franklin for guessing wrong before anybody knew
    what current really was. Or at least that is the legend I heard.
    --Mac
    Mac, Jun 18, 2005
    #13
  14. topgun
    Jamie Guest
    topgun wrote:
    > Hi all,
    > Thanks
    yes i know its tricky, those terms have been used so loosely in
    various docs that i have seen.
    this is how i understand it.
    Source Current is a device that supplies the common/Negitive rail
    which in turn would pull something to ground, Sink current is the
    other way around where it supplies voltage into a device that is
    going to the common/negitive rail side.
    if you look at it this way, Source current is something that is needed
    for a voltage source to create current, thus you would be looking at
    a active device for example that pulls to the common.
    maybe i am wrong here but that is how i have always dealt with it.
    Jamie, Jun 20, 2005
    #14
  15. topgun
    Rich Grise Guest
    On Sun, 19 Jun 2005 16:49:51 -0700, Jamie wrote:
    > topgun wrote:
    >> Hi all,
    >> Thanks
    No, you got it exactly backwards. Remember, we're talking about
    conventional current here, which goes the opposite direction from
    electron flow. Sourcing current means conventional current is
    coming out of your source, like water out of a faucet.
    But this is conventional current - the flow of charge from positive
    to negative. The electrons really only pass the charge along, and
    it doesn't really matter which direction it's flowing - the electrons
    themselves, individually, migrate at a few inches an hour or so. Toward
    the current source. ;-)
    That's right, kiddies, the current flow in an electron beam is upstream.
    ;-P
    Cheers!
    Rich
    Rich Grise, Jun 20, 2005
    #15
    1. Advertisements
Similar Threads
  1. Mohammadi
    Amplifiers and Buffers
    Mohammadi, Dec 30, 2005, in forum: Electronic Design
    460
    Mohammadi
    Dec 30, 2005
  2. Dave Moore
    2,776
    Dave Moore
    Jul 10, 2005
  3. jasonben
    Electric field between a source and a sink in a sheet
    jasonben, Jul 17, 2009, in forum: General Electronics Chat
    860
    jasonben
    Jul 23, 2009
  4. Skybuck Flying
    9
    776
    V__i__n_ce__19_7_1_
    Aug 18, 2009
  5. Simmon
    Open collector buffers VS Non Open Collector Buffers
    Simmon, Mar 6, 2014, in forum: General Electronics Chat
    12
    786
Loading...
