Need to clean inkjet heads on Epson 740
Discussion in 'Electronic Components' started by wylbur37, Nov 5, 2004.
  1. wylbur37
    wylbur37 Guest
    I have an Epson 740 inkjet printer.
    After not using it for a while, I discovered that the inkjet nozzles
    were apparently clogged to the point where the "head cleaning routine"
    was of limited usefulness.
    The printouts show signs of missing lines and "bleeding fibers"
    indicating the presence of accumulated residue around the nozzles.
    I'd like to be able to free the print head carriage assembly
    so that I can wipe the front of the nozzles and clean them,
    but I can't find the right screws to remove.
    The Epson website has various manuals to download but they don't seem
    to have the one that I need. Their Product Information Guide on setup
    and testing (sc740_pg.pdf) mentions (on page 15,
    under Related Documentation) the "TM-SC467 Epson Stylus Color
    440/640/740 Service Manual", but that publication is apparently
    nowhere to be found on their website.
    Can someone either
    (a) explain how to remove the print head assembly so the nozzles can be
    cleaned or
    (b) mention a website where the necessary documentation is available
    for download or
    (c) if you have the document, send me a copy via email as an attachment.
    Thanks for your help.
    #1
    1. Advertisements
  2. "wylbur37" <> wrote in message
    news:...
    > Can someone either
    be
    > cleaned or
    > for download or
    attachment.
    The Epson inkjet printer is a field replaceable item. You throw away
    the printer and replace it with another at the same or less price of a
    set of ink cartridges for it. If you're smart, you'll get a printer
    that has the nozzles built into the cartridge, such as the HP deskjet,
    or similar.
    I'm really serious about this. At work, the teachers go on vacation in
    the summer, and when they come back in the fall, the Epsons are all that
    way. So we just tell them, the Epson is not a district standard
    printer, so we don't support it - sorry. If you get a new one, the
    district standard is HP.
    Watson A.Name - \Watt Sun, the Dark Remover\, Nov 5, 2004
    #2
    1. Advertisements
    Here's a post from a while go - a friend of mine has tried it successfully :
    The symptom is missing horizontal lines
    through text or graphics -- or no print at
    all. This occurs when the water based inks
    dry at the print heads in amounts that the
    head cleaning routine cannot dislodge.
    The newer Epson Stylus Color series print
    heads are particularly affected.
    It can happen whether you refill your inkjet
    cartridges or not.
    One contributing factor is turning off the
    printer from a power bar. This prevents a
    complete shutdown and docking of the heads
    at their docking stations. You will notice
    some activity even after turning the printer
    off by its switch, as it continues to take a
    trickle charge.
    To unclog the heads:
    - Run 3 cleaning cycles from the Epson
    Utility
    - Turn off printer, and restart in Test
    Print mode
    - When cartridges/ print heads are at
    extreme left of carriage, quickly spray 3
    shots of Windex or Ammonia onto docking
    station(s) affected, and turn off printer
    for 5 minutes
    - Repeat process as needed until perfect
    test prints are restored - usually 2
    procedures
    We've saved 14 printers this way.
    Image Control ~ Remanufactured and Generic
    Toner Cartridges
    Lasers/Fax/Copiers ~ Refill Kits for over
    800 InkJets
    1396 Kingston Rd. Toronto ON Canada M1N 1R3
    (416) 694-7509 Fax 694-7929 ~ Member BBB &
    CIPRA
    Canadian Imaging Products Remanufacturers
    Assn.
    Free email help with toner problems ~
    http://www.image-control.com
    Mike Harrison, Nov 5, 2004
    #3
  4. "Mike Harrison" <> wrote in message
    news:...
    successfully :
    > cartridges or not.
    > trickle charge.
    > Utility
    > Print mode
    > for 5 minutes
    > procedures
    I was going to post the Ammonia suggestion. It worked for me, and the
    printer concerned, was still working two years latter when I sold it.
    It is very effective indeed.
    It is worth realising that the removing the head won't really help, since
    the blockage is inside the nozzles, and not something external that can be
    wiped away. The cleaning sponges at the docking end of the carriage, come
    directly into contact with the heads, and cleaner on here works, without
    risking destroying the alignment of the system.
    It is worth also saying, that the Epson heads are far less prone to this,
    than the HP cartridges, and when you have been through 30+ HP cartidges at
    £20 or more a time, in each case replacing them before more than a quarter
    of the ink is used, the Epson system does not seem bad. I have never
    successfully got an HP cartridge to clean.
    Best Wishes
    Roger Hamlett, Nov 5, 2004
    #4
  5. Tony
    Tony Guest
    news:...
    A solvent for dye based inks is commonly used. Windex (Windolene UK) is a
    window cleaning fluid which disperses encrusted or dried ink: Some of the
    newer shower dispersant cleaners work equally well.
    Firstly try a few drops on the docking sponge area which is where the heads
    sit when parked.
    Whipping out the mains plug in mid flight will expose this.
    With a cotton bud introcude a few droplets on the piercing splines and the
    sponge.
    In real determined blockage cases - fill a spent cartridge with the solvent
    (Household ammonia 10:1 works as well) and print a few windy pages . Letting
    it sit overnight can also ease it further.
    The so called cleaning cycle is really priming of ink through the feeder
    tubes and seldom cleans.
    Tony
    Spit less spotlets - spotless inkjet prints...
    http://www.inkylinkusa.com 30% more ink
    http://www.aah-haa.com/affiliates.htm
    And a nice little earner...
    Tony, Nov 5, 2004
    #5
  6. Tony
    Tony Guest
    "Watson A.Name - "Watt Sun, the Dark Remover"" <> wrote
    in message news:...
    > news:...
    Which IMO just tells us quite a bit about the mentality of Teachers and
    supply coordinators in charge of our children. The total cost of ownership
    for an HP is usually twice that of Epson with lexmark leading by a whopping
    margin. So Teachers don't even know about a little preventative maintenance.
    Whip out the plug in mid-flight -prior to that looong vacation - spray in a
    little Windex: some on the docking sponge and its done.
    If you get really religious and cost conscious then a few spent cartridges
    and a preventative print , again prior to vacation will keep them all
    working just fine. That may not be within the teacher's remit or
    intelligence but it works.
    In any case vacation School buildings are normally used by parents and other
    recreational classes during vacation times so why aren't they using the
    printers ? Strikes me your costs could be halved and the tax payer's money
    as well with a little thought and planning. Are you sure the motivation for
    HP is cost.
    Tony
    Tony, Nov 5, 2004
    #6
  7. NSM
    NSM Guest
    news:...
    Look on the net. Someone sells a cleaning solution for Epsons:
    http://www.fixyourownprinter.com/kea0.html (Easy to use, no disassembly
    required) - "Do not use alcohol or Windex, they will very likely ruin your
    printer".
    Can't help, but see the "How to fix your own printer" site
    (http://www.fixyourownprinter.com/)
    | Can someone either
    | cleaned or
    | for download or
    NSM, Nov 5, 2004
    #7
  8. Dbowey
    Dbowey Guest
    wylbur posted:
    << I have an Epson 740 inkjet printer.
    Can someone either
    cleaned or
    for download or
    I have a couple 740s and have had the same problem when I don't use them for a
    few weeks, but I have never had to do anything as intrusive as you propose.
    Remove the ink cartridge(s) by flipping up the plastic lever/cover on top of
    the carriage. Use a barely dampened paper towel to wipe the ink jets, which are
    on the bottom of the cartridge. That is a *messy* step. Wipe-dry it well,
    reinstall it and then run the nozzle cleaning routine. You may need to repeat
    the process.
    Don
    Dbowey, Nov 5, 2004
    #8
  9. Tony
    Tony Guest
    Tony, Nov 5, 2004
    #9
  10. Clarence
    Clarence Guest
    news:...
    > Can someone either
    > cleaned or
    > for download or
    I found it is possible to clean the heads by filling an empty ink reservoir
    with Alcohol and running the test print program many times. After 10 to 20
    runs, it usually clears them out. Then put a reservoir with Epson approved ink
    in and test. Repeat as needed. No guarantee. Depends on how badly it is
    clogged!
    Clarence, Nov 5, 2004
    #10
  11. "Roger Hamlett" <> wrote in message
    news:LoMid.100$...
    > news:...
    nozzles
    routine"
    > successfully :
    > > cartridges or not.
    > > trickle charge.
    > > Utility
    > > Print mode
    > > for 5 minutes
    > > procedures
    since
    can be
    come
    without
    Good point.
    this,
    cartidges at
    quarter
    The HP cartridges may be expensive, but they don't clog up as often in
    as Epsons in my experience, and when they do, all you have to do is
    replace the cartridge, and not waste tons of time on trying to get it to
    clean and work properly as the Epson requires. We've never had as
    many problems or complaints with the HPs as we've had with the Epsons.
    And I hear the Epson printer sitting there for several minutes doing
    this "dance" they do, of so much activity and gyrations just to get a
    single _page_ printed out.
    > I have never successfully got an HP cartridge to clean.
    But you can remove the whole cartridge and set the business end on a
    sheet of paper towel wetted with whatever you want to clean it with. Or
    even put the heads in a shallow liquid, like in a lid from a jar or
    bottle.
    And if you're against tossing the printer cartridges and putting new
    ones in, then youi might consider what some people do. They just buy a
    whole new HP printer on sale for $70 or so, with cartridges, and give
    the old one to a friend or the kids or whatever.
    And save a lot of money by refilling the cartridges. Epson uses a chip
    in heirs to thwart the refills so they can sell more cartridges. But
    the pirates sell kits that have already bypassed those.
    > Best Wishes
    Watson A.Name - \Watt Sun, the Dark Remover\, Nov 6, 2004
    #11
  12. "Tony" <> wrote in message
    news:...
    wrote
    > in message news:...
    > > news:...
    in
    that
    and
    ownership
    whopping
    maintenance.
    in a
    cartridges
    other
    the
    money
    motivation for
    > HP is cost.
    You're using your experiences to judge someone else's situation, which
    is not a valid judgment. The full-time teachers have a 6 by 10 ft
    'office' (more like cubbyhole) which is theirs to lock up all summer
    long, contrary to your judgment.
    As for cost, well, you have to weigh in the other factors such as the
    time it takes for the staff such as our helpdesk staff to do whatever
    has to be done to get the teacher a page properly printed out. If we
    had to go over with a bottle of windex and do as you suggested, it would
    cost us at least a whole additional person full-time, because there are
    hundreds of printers out there. And if you think that it's possible to
    get a teacher to do that cleaning job, you haven't been in this
    situation. Those teachers get paid a lot more than we do. And they get
    off the whole summer, too.
    Suffice it to say that if the teachers can talk their department head
    into buying a 2 thousand dollar HP color laser printer and supplying it
    with a new set of toner cartridges every few months at a cost of several
    hundred dollars each, they can easily afford a few ink cartridges. And
    new Epson printers, when the old ones get clogged up. We have a whole
    warehouse of PCs and monitors, hundreds of them, setting there waiting
    to be scrapped, and that's just a year's accumulation. What's the cost
    of a few printers in the grand scheme of things? Nothing, especially
    when compared to labor costs. The teachers won't deal with these
    details, that's why they have us helpdesk peons. I was the first elec
    tech the district hired, now 2 dozen years later we have dozens of
    techs, just to deal with these user issues, and each tech gets paid the
    cost of a couple cartridges a day. So why not throw inkjet printers at
    the problem if it will save having to hire another tech. We used go
    over and undo and reinstall the printer after the Lusers screwed around
    with the printer setup, until we got wise and took away all users' local
    administrator priveleges. Now they can't goof it up quite as bad and it
    saves a lot of the techs' time. We have nicknames for certain
    departments where there are those Lusers that have a propensity for
    screwing things up. The techs call one dept "HM2", meaning High
    Maintenance #2. They're not the worst; that title's reserved for HM1.
    :eek:)
    Believe me, I'm all for giving each user his own printer, that way I
    wouldn't have to pull new cat5 cable to the big networked HP printer
    they buy for the department. But they don't and I do, so that's called
    Job Security. And the cost of a printer or even a PC is nothing
    compared to the amount of labor and downtime wasted by a wave of virus
    infections such as klez. Now, I can't even send someone a .ZIP file
    because the email system rips it out and tells the recipient that it's
    possibly a virus. But you have to look at the good side. All those
    ..ZIPs that don't get thru are no longer printed out, so it saves on ink,
    paper and printers. ;-)
    > Tony
    #12
  13. James Sweet
    James Sweet Guest
    in message news:...
    > news:...
    > > Can someone either
    > be
    > > cleaned or
    > > for download or
    > attachment.
    > or similar.
    I had an old Epson Stylus II that never dried up, even after months of not
    using it. Later I had a newer Epson and was dissapointed to find it would
    dry out after only a couple weeks of not printing.
    James Sweet, Nov 6, 2004
    #13
  14. Tony
    Tony Guest
    in message news:...
    > news:...
    > wrote
    > > in message news:...
    > > > news:...
    > in
    > that
    > and
    > ownership
    > whopping
    > maintenance.
    > in a
    > cartridges
    > other
    > the
    > money
    > motivation for
    > > HP is cost.
    That was firstly exhausting and then enthralling to comprehend...
    I write and like horror stories about the human pysche: would you like to
    contact me and play name-em-and-shame-em, anonomously of course. No wonder
    the Western World is despised for its waste mountain.
    Tony.
    Tony, Nov 6, 2004
    #14
  15. "Watson A.Name - "Watt Sun, the Dark Remover"" <>
    wrote in message news:...
    > news:LoMid.100$...
    > > news:...
    > nozzles
    > routine"
    > > successfully :
    > > > cartridges or not.
    > > > trickle charge.
    > > > Utility
    > > > Print mode
    > > > for 5 minutes
    > > > procedures
    > since
    > can be
    > come
    > without
    > Good point.
    > this,
    > cartidges at
    > quarter
    Interesting. The exact opposite of me. We have over 300 printer in the
    company I work for. The running costs for HP equivalent models, worked out
    over double that of the Epsons, with a hige number of 'early replacement'
    cartridges. We have had just two Epson's develop clogged nozzles, and both
    cleared.
    I only hear cleaning cycles, if the printer has been switched off, or left
    idle for a couple of days. Normally responses are instantaneous. The HP
    units also do a clean if left idle.
    > bottle.
    Yes, and then the cartridge no longer gives the fine ink dots it used to.
    The quality degrades massively. The same is true after most refills...
    I suspect that this explains a lot. The two machines that did develop
    clogged nozzles, turned out to have both been fitted with a 'refilled'
    cartridge, by one person...
    Best Wishes
    Roger Hamlett, Nov 6, 2004
    #15
  16. Guest
    >Can someone either
    >cleaned or
    >for download or
    I have a site that shows you how to do it, not to hard but you must also clean
    up the parking station as that get paper dust and hair on it and dried ink,
    that must be done so that the print head it covered and has a good vacuum..
    I did mine by using this article, and the 740 works great afterwards..
    I use a stuff called Spray and Wipe, 2mm in a flat tray, left the print here
    face down in it for say one hour, then did it again, also move the head a
    little up and down in the liquid, the liquid does not cover the head just the
    face of it.
    Then did it again with clean water, then dried it off with clean tissue
    Yes here is the URL..
    http://www.inkjetart.com/tips/cleaning/Image01.html
    Please do make shore that the print head is place back correctly as the angle
    of the head is important, the service manual refers to a test problem to set
    the head up, but its also set by locking a screw, this does not get touched
    when removing the hard.
    Life is not measured by the number of breaths we take, but by the moments that take our breath away. (George Carlin)
    , Nov 6, 2004
    #16
  17. Guest
    On Fri, 5 Nov 2004 05:43:12 -0800, "Watson A.Name - \"Watt Sun, the Dark
    >news:...
    >> Can someone either
    >be
    >> cleaned or
    >> for download or
    >attachment.
    >or similar.
    UTTER BOLLOCKS YOU KNOW F ALL.
    , Nov 6, 2004
    #17
  18. Guest
    >Can someone either
    >cleaned or
    >for download or
    face of it.
    Some info on Ajax Spray n Wipe, a Amonia/detergent based all purpose cleaner
    http://new.thecleanmachine.co.uk/products/products418.aspx
    Ajax, Colgate-Palmolive
    Also use buy a local Printer repair shop, and used by them on Epson printers
    , Nov 6, 2004
    #18
  19. "Tony" <> wrote in message
    news:...
    wrote
    > in message news:...
    > > news:...
    > > wrote
    > > > in message news:...
    > > > > news:...
    vacation
    > > in
    all
    > > that
    the
    Teachers
    > > and
    > > ownership
    > > whopping
    > > maintenance.
    spray
    > > in a
    > > cartridges
    all
    and
    > > other
    using
    > > the
    payer's
    > > money
    > > motivation for
    > > > HP is cost.
    which
    the
    whatever
    we
    would
    are
    to
    get
    head
    it
    several
    And
    whole
    waiting
    cost
    especially
    to
    wonder
    > Tony.
    No, I wouldn't want to, because you wouldn't pay me 28 bucks an hour to
    do so. Besides, we full-time employees don't work on the printers, we
    have a vendor send a field tech over for one day a week, and we pay them
    a bundle of money just for that. I'm sure we wouldn't want to pay them
    to have him here more just to clean print heads. We've scrapped a whole
    lot of laserjets because the cost to repair is more than the printers
    are worth, so we just buy a new one.
    And if you think this is expensive, you should see the bills for the
    Xerox monster they have out in the publications center. It looks like
    this, but I think it's an earlier model.
    http://www.xerox.com/go/xrx/equipment/product_details.jsp?Xcntry=USA&Xla
    ng=en_US&prodID=DT6180&cat=Product+Taxonomy%2fProduction+Systems%2fDocuT
    ech
    #19
  20. NSM
    NSM Guest
    <> wrote in message
    news:...
    Plonk!
    NSM, Nov 6, 2004
    #20
    1. Advertisements
Similar Threads
  1. wylbur37
    wylbur37, Nov 5, 2004, in forum: Electronic Equipment
    29
    861
    Martin
    Nov 11, 2004
  2. Guest
    Epson T0321 Inkjet cartridge chip resetter
    Guest, Oct 8, 2004, in forum: Electronic Repair
    539
    Guest
    Oct 14, 2004
  3. wylbur37
    wylbur37, Nov 5, 2004, in forum: Electronic Repair
    28
    1,131
    Martin
    Nov 11, 2004
  4. slef clean oven not hot enuf to clean
    , Feb 13, 2006, in forum: Electronic Repair
    675
  5. Farmer Bill
    How to Clean Audio Cassette Heads
    Farmer Bill, Sep 26, 2006, in forum: Electronic Repair
    15
    2,850
Loading...
Share This Page
