Need help w/ lo-noise precision shunt Volt regulator
Discussion in 'General Electronics' started by Victor, Mar 4, 2004.
  1. Victor
    Victor Guest
    I'm trying to decide which approach of two different shunt voltage
    regulation schemes will result in the lowest noise for supplying a
    LM3875 based home audio amplifier to drive high efficiency(100-107 db)
    horn speakers. Granted, the LM3875 already has a PSRR and CMRR of 120
    dB, but I'd like to take out the noise before it hits the chip.
    The amp can draw considerable current(4-6.5 A) for short periods to
    2-5 mS which is the reason I'm choosing shunt over normal in-line
    reuglation. I don't want the max current rating of the regulator to be
    the limiting factor in performance or have to add banks of capacitors
    after regulation to make up for that shortcoming. Experimentation has
    shown that 1000uf at the pins of the LM3875 prevent oscillation and
    provide the best performance without making the sound sluggish.
    To make up for that, I'll be using a a battery supply to avoid AC line
    noise and provide the needed capacitance, but this has it's own set of
    noise problems which can be viewed at the bottom of this page:
    http://www.tnt-audio.com/clinica/regulators_noise4_e.html
    Anyway, on to shunt regulation and noise filtering:
    1. The Two-transistor Shunt Regulator can be found at the top of the
    same page above and boasts an average noise level of -100dB across the
    normal audio frequency range. It seems fairly simple and doesn't need
    any tweaking.
    Or
    2. A precison hi current shunt regulator using TI's TL1431 "Precision
    Programmable Reference" followed by LM833/2N4401 noise shunt which
    boasts a 40dB noise reduction with careful construction.
    The particular circuit "Precision High-Current Series Regulator"
    can be seen in Figure 18. on page 13 of the datasheet at:
    http://www-s.ti.com/sc/ds/tl1431.pdf
    Ahich of thee two approaches seem best?
    And, I'm hoping someone can tell me what rating resistors are best for
    low-noise supply? I'm assuming 1 watt 5% wirewound will do, although
    something tells me that 1% might be best in the critical Vref spots.
    Also, are electrolytic caps best in these circuits and what mx voltage
    rating?
    Any advice greatly appreciated,
    Victor, Mar 4, 2004
    #1
    1. Advertisements
  2. Victor
    Robert Baer Guest
    > any tweaking.
    > Or
    > rating?
    That "regulator" shown inthe first reference has a lot of design
    problems.
    First, it has temperature problems, due to the fact that the Vbe of Q1
    changes over temperature.
    Second, unless a goodly current passes thru that zener, it will
    *generate* a lot of ugly noise with a large 1/F component.
    Frankly, it sucks.
    The various "band-gap" shunt regulators (one of which referred to by
    the second link) is far better.
    Granted, one has the problem of integrating them with a power
    transistor to get similar high current results, but figure 20 on page 13
    is an excellent start.
    Adding a capacitor from collector to base of the transistor will help
    decrease the impedance at the high frequency end.
    You must realize that the maximm voltage Vo for most of these band gap
    references is 6V, and not the 10V that it seems you would like.
    I see that the high current TL1431 can go to 35V, which is better than
    the low power ones that i have been investigating; good choice.
    Robert Baer, Mar 5, 2004
    #2
    1. Advertisements
Similar Threads
  1. Max_Venezia
    shunt precision
    Max_Venezia, Jan 14, 2004, in forum: Electronic Design
    5
    400
    Rene Tschaggelar
    Jan 15, 2004
  2. Steve Kavanagh
    Reading on receiver LO phase noise impact on sensitivity
    Steve Kavanagh, Oct 1, 2006, in forum: Electronic Design
    8
    1,506
    vasile
    Oct 10, 2006
  3. eromlignod
    Zap a volt regulator w/ no cap??
    eromlignod, Oct 31, 2006, in forum: Electronic Design
    16
    798
    David L. Jones
    Nov 2, 2006
  4. Jim
    431 shunt regulator help
    Jim, Feb 18, 2009, in forum: Electronic Design
    26
    1,677
    Bill Sloman
    Feb 22, 2009
  5. Gadgetastic
    To shunt or not to shunt?
    Gadgetastic, Jun 22, 2013, in forum: General Electronics Chat
    8
    604
    Gadgetastic
    Jun 23, 2013
Loading...
