Navico PH-8000 Autopilot
Discussion in 'Boat Electronics' started by John Proctor, Feb 21, 2004.
  1. John Proctor
    John Proctor Guest
    First don't tell me to talk to Simrad as the local distributor doesn't
    own up to knowing anything about this autopilot.
    I have a Navico PH-8000 power pilot on my 37' Jeanneau Sun Odyssey. The
    drive is hydraulic and steering is cable driven. My problem is that the
    pilot has become increasingly intermittant over the last several months.
    I have a PC-8000 controller in the cockpit and I thought that this might
    be flakey so I replaced all the components and now it doesn't seem to
    work at all. Does anyone have any schematics for this autopilot that
    they might be willing to share. Given the price of a new pilot I would
    like to get this one working again but there is a limit to how much agro
    I can take;-)
    Any help would be welcome.
    Regards,
    John Proctor
    S/V Chagall
    John VK3JP
    #1
    1. Advertisements
  2. John Proctor
    John Proctor Guest
    In article
    > I can take;-)
    > Regards,
    > John Proctor
    > S/V Chagall
    Well the gods are smiling!
    I pulled the PC-8000 controller and had another hard look at it. Outside
    the box the resistance measurements on the 2-wire control bus were ok.
    However when I put it back in the case thet were screwy. To shorten the
    story the pc board was settling into the case deepere than it was meant
    to and as a result several of the push buttons were always activated.
    Shortening the shafts a little solved the problem and guess what it
    works!
    Ah life is sweet when you don't have to spend $3K (AUS) to replace your
    autopilot!
    Regards,
    John Proctor VK3JP
    S/V Chagall
    John VK3JP
    John Proctor, Feb 23, 2004
    #2
    1. Advertisements
  3. Good sleuthing on your part. A good example of how a mechanical problem can
    cause electrical problems.
    I bought a used Icom M600 recently from a dock neighbour. He had some ham
    friends check it out and they said it worked fine except for the internal
    speaker. They were in the process of ordering a new speaker from Icom when
    I said "Wait, I'll check it out myself". Speaker did not work when first
    tried but signal showed on signal strength display.
    Read owners manual (which hams provided).
    Manual says speaker will not work if microphone is not connected.
    Connect microphone and speaker is A-OK.
    A very cheap fix.
    "John Proctor" <> wrote in message
    news:...
    > In article
    > > I can take;-)
    > > Regards,
    > > John Proctor
    > > S/V Chagall
    > works!
    > autopilot!
    > Regards,
    > John Proctor VK3JP
    > S/V Chagall
    > John VK3JP
    Gordon Wedman, Feb 26, 2004
    #3
    1. Advertisements
Similar Threads
  1. Ken
    Navico Marine Pilot 1600?
    Ken, Jul 18, 2003, in forum: Boat Electronics
    3
    1,081
    Ken Corbett
    Jul 24, 2003
  2. Vito Steockli
    Navico & Sinrad
    Vito Steockli, Dec 1, 2003, in forum: Boat Electronics
    688
    Vito Steockli
    Dec 4, 2003
  3. Ralph Mudge
    Navico autopilot
    Ralph Mudge, Jul 13, 2004, in forum: Boat Electronics
    1,259
    Ralph Mudge
    Jul 13, 2004
  4. Frank Klose
    Schematics NAVICO RT6500
    Frank Klose, Aug 9, 2005, in forum: Boat Electronics
    873
    Frank Klose
    Aug 9, 2005
  5. Peter
    Problems with Navico corus windset
    Peter, Feb 18, 2006, in forum: Boat Electronics
    1,321
    Clark
    Sep 20, 2006
Loading...
