multimeter reset
Discussion in 'Electrical Engineering' started by Anthony, Mar 27, 2012.
  1. Anthony
    Anthony Guest
    I have an older digital multimeter, a Radio Shack 22-163. It uses two
    AA batteries.
    The device wasn't malfunctioning in any way, but I decided to do a
    visual inspection of the batteries powering this device.
    One of the two sets of terminals was corroded, but not badly.
    1) Why does one set of terminals corrode, and the other does not?
    I decided to remove the batteries. Nothing is obviously wrong, they're
    not leaking that I can tell. They're actually in good shape considering
    they're a couple years old.
    2) I replaced the batteries with another set that I had lying around,
    now the unit "resets" itself, and then proceeds to act normally whenever
    I power it on. All the LCD lights blink, and the beeper, which I
    normally keep off, and then the device normally remembers that it was
    off between usage, and remains off, now is back on every power up. It
    is obviously defaulting.
    Now, why is all this happening, and how can I fix it?
    thanks
    #1
    1. Advertisements
  2. Rich.
    Rich. Guest
    "Anthony" <> wrote in message
    news:4f70fb62$0$43582$...
    >I have an older digital multimeter, a Radio Shack 22-163. It uses two AA
    >batteries.
    > The device wasn't malfunctioning in any way, but I decided to do a visual
    > 2) I replaced the batteries with another set that I had lying around, now
    > the unit "resets" itself, and then proceeds to act normally whenever I
    > power it on. All the LCD lights blink, and the beeper, which I normally
    > keep off, and then the device normally remembers that it was off between
    > usage, and remains off, now is back on every power up. It is obviously
    > defaulting.
    > thanks
    1. Are the batteries installed correctly? (yes double check)
    2. Are the batteries definitely good?
    Rich., Mar 27, 2012
    #2
    1. Advertisements
  3. Anthony
    Anthony Guest
    >> AA batteries.
    >> considering they're a couple years old.
    >> whenever I power it on. All the LCD lights blink, and the beeper,
    >> which I normally keep off, and then the device normally remembers that
    >> it was off between usage, and remains off, now is back on every power
    >> up. It is obviously defaulting.
    >> thanks
    Sorry for the delay, problem with the news sever.
    Yes to all. I suspect (but can't confirm) that the corrosion on one of
    the terminals is interfering (why is there corrosion on one set of
    terminals, and not the other, again?) but the corrosion is clearly not
    preventing electrical signal.
    thanks
    Anthony, Mar 28, 2012
    #3
  4. Don Kelly
    Don Kelly Guest
    >>> AA batteries.
    >>> thanks
    > of the terminals is interfering (why is there corrosion on one set of
    > thanks
    Corrosion will only occur at the anode. You often see this with car
    batteries (not as much as it used to be.
    http://en.wikipedia.org/wiki/Galvanic_corrosion
    The terminals should be well cleaned-try a bit of emery cloth to get
    clean shiny metal as there is likely a bit of stuff on the contact
    surface which puts some resistance into the meter supply circuit,
    reducing voltage sufficiently to cause problems. I've had a blood
    pressure meter get quite unreliable in a similar situation.
    If the meter is to be stored for a long period, take the batteries out.
    Don Kelly
    cross out to reply
    Don Kelly, Mar 28, 2012
    #4
  5. Anthony
    Anthony Guest
    >>>> AA batteries.
    >>>> thanks
    >> thanks
    Ok, but this doesn't answer why the unit resets itself at every
    power-on, and what I can do about it. Electrical contact is definitely
    happening, because the unit powers on just fine.
    Galvanic Corrosion explains why one set of terminals would corrode and
    the other does not, if they were different materials, but in this case,
    they are the same material.
    Anthony, Mar 29, 2012
    #5
    1. Advertisements
Similar Threads
  1. Julia Goolia
    Why does the Basic Stamp RESET periodically?
    Julia Goolia, Feb 4, 2004, in forum: Electronic Basics
    753
    Julia Goolia
    Feb 6, 2004
  2. Dummy
    Microcontroller reset condition
    Dummy, May 18, 2004, in forum: Electronic Basics
    4
    1,586
    Martin Riddle
    May 18, 2004
  3. KBG
    24,427
    Jamie
    Jan 11, 2007
  4. Don McKenzie
    867
    Don McKenzie
    Jun 29, 2010
  5. Skybuck Flying
    Reset Switch GND, RESET#, brown, white
    Skybuck Flying, May 26, 2011, in forum: Electronic Design
    6
    1,185
    Skybuck Flying
    May 27, 2011
Loading...
Share This Page
