mosfet power amp transistor replacement and debugging
Discussion in 'Electronic Repair' started by Lee Collier, Jul 17, 2004.
  1. Lee Collier
    Lee Collier Guest
    Hello,
    I've got a Rauch PB44 power amp that uses the 'classic' J50/K135 paired
    Mosfets. One channel is perfect, but the other just gives me a loud mains
    hum that does not change with the front volume pots, and doesn't have the
    input signal present at all.
    I've tested the PSU and all seems to be well (haven't checked it on the
    scope yet but DVM says +-70VDC which is the same as the good channel).
    I've tested the Mosfets with the DVM using the method at
    http://www.4qd.co.uk/serv/mostest.html comparing good and bad channel, and
    have come to the conclusion that all four J50s on the bad channel are
    duff. I can source replacements at RS but they're about GBP 10 a pop.
    I therefore have a few questions:
    1. I don't want to waste money on replacement parts if I'm wrong in my
    guess. How much damage am I likely to cause if I swap the J50s from the
    good channel? I understand they're static sensitive, is it enough to
    ground the soldering iron tip and touch the (earthed) chassis frequently?
    I have read that solder pumps are bad for static so plan to buy some wick.
    If the problem is before the Mosfets, is it possible to kill the good lot
    and end up with no amp at all?
    2. The Mosfets are Japanese J50/K135, the RS parts are UK 2SJ50/2SJ135.
    If I replace the J50s with 2SJ50s, will I need to replace the K135s with
    the different parts, or are they drop-in equivalent? I haven't been able
    to find this out anywhere. I think 7 new Mosfets (I happen to have 2)
    might make the repair uneconomical.
    3. Any hints on other debugging I could try? I'm proficient with
    solderig iron, DVM and fairly happy with my scope but not experienced with
    fixing power amps.
    Many thanks in advance. This is a beast of an amp so it would be fun to
    have it working...
    Lee
    #1
    1. Advertisements
  2. Lee Collier
    Guest Guest
    Hi Lee
    Apparently you are not blowing fuses so it would seem your J50 outputs
    failed open. Check to see if your Mosfets have source resistors as well as
    gate resistors. Check every one, as well as everything else on the board. I
    don't have access to a schematic for this amp but I would recommend getting
    one. Fixing an amp like this can be a lot harder than it looks without a
    schem - even with a schematic for that matter! What you don't want to do is
    put new output devices (or the good ones from your working channel) in there
    and destroy them due to possible un-detected problems upstream in the
    circuit.
    I have not yet managed to ruin a mosfet by careless handling despite all the
    warnings for static handling - though if you have a wristrap- use it. They
    will destroy very easily though if you hook em up wrong.
    If you have a scope & other basic test gear and a current limiting light
    bulb to insert in mains, and you are brave:
    In lieu of a schematic, I usually do a thorough component check, and then
    attempt to run the amp without outputs installed (do not attach a spkr or
    dummy load yet!) if the circuit will let you do that and observe the output
    waveform via scope probe with a sinewave @input. Sometimes you can operate
    an amp like this and sometimes you will need to install at least one comp.
    pair of output devices to satisfy biasing & feedback requirements to get the
    amp up. Do none of this stuff without a current limiting bulb in series with
    one side of your mains. A 60 w bulb (120v mains) will usually allow you to
    get such an amp up yet limit current enough so that you wont sizzle anything
    while you are troubleshooting. If your light bulb glows real bright you
    likely have a problem somewhere.
    The idea is to determine if the preamp & driver stage is working right
    before installing the expensive outputs - which you can about 90% determine
    by o'scope probing and following the above method. If you observe a normal
    looking amplified version of your input waveform then chances are your
    preamp & driver stages are in good shape. Put in the outputs, or the rest of
    the outputs and check again. If you have any appreciable DC (more than
    about 100mVdc) at the output while the input is shunted - you have problems
    somewhere up stream. When you are confident your sine wave looks good - and
    you have all the outputs installed, hook up your spkr load and check again.
    (Say a blessing prayer first).
    If you have a bulb Ilimiter and follow these two rules - you should be able
    to fix this thing:
    1)do not try to drive a spkr load without the outputs installed.
    2)do not install the outputs until you are confident that the preceeding
    stages are working correctly.
    See this link for some very clever advice on replacements for the obsolete
    J50/K135 devices:
    http://aga.rru.com/TechTips/disp.cgi?file=RobertBraught/PowerFETRepl.tt
    BTW, I would recommend replacing all of the outputs.
    Good luck
    Todd
    "Lee Collier" <> wrote in message
    news:p...
    > Hello,
    > fixing power amps.
    > have it working...
    > Lee
    Guest, Jul 17, 2004
    #2
    1. Advertisements
  3. Lee Collier
    Woody Guest
    news:p...
    > Hello,
    > fixing power amps.
    > have it working...
    > Lee
    If you are getting hum on the speakers, disconnect them and check the d.c.
    voltage to ground on the output terminals. If the amp is d.c. coupled -
    which it very likely will be - there could be up to perhaps 100mV (either
    polarity) present. If an output device has failed short circuit then you
    will see either full or nearly full rail (+ve or -ve) if one device has
    gone, or an offset greater than 100mV if a complimentary pair have failed,
    although in this latter case I would have expected it to blow the rail
    fuses.
    J50 and 2SJ50 are one and the same - it is just the normal way that letters
    are omitted to save space: same for K135 and 2SK135. However do make sure
    they are the same encapsulation. Originally they were in the TO3
    diamond-shaped power transistor cases, but latterly they were repackaged in
    a T-shaped flatpack, albeit with some care these could be made to fit the
    same heatsink assuming there is enough room.
    As said elsewhere unless there is an obvious problem you will have a
    difficult job without a circuit diagram. Your DVM will take so little
    current that good devices could still appear to be faulty because of
    leakage - a common trap into which to fall.
    Woody
    Woody, Jul 17, 2004
    #3
  4. Lee Collier
    DaveC Guest
    On Sat, 17 Jul 2004 00:41:31 -0700, wrote
    (in article <>):
    Excellent FAQ on diagnosing and repairing an amp. Just what I needed when
    I'll (some day) attack that old 400W boat anchor I want to drive my antique
    electrostatic speakers. : -)
    Thanks, Todd!
    Please, no Google links. I wouldn't ask a
    question here if I hadn't done that already.
    DaveC
    This is an invalid return address
    Please reply in the news group
    DaveC, Jul 17, 2004
    #4
  5. Lee Collier
    Lee Collier Guest
    On Sat, 17 Jul 2004 02:41:31 -0500, todd wrote:
    > Hi Lee
    > circuit.
    Thanks - I wish I had a schematic, but I've spent hours searching to no
    avail. It's a Rauch Powerblock 44 from a now-defunct English company.
    <SNIP>
    > to fix this thing:
    OK - the above is really useful, thanks very much. I've got 240V mains
    here but I can do the sums.
    > J50/K135 devices:
    Yeah, I read that. I can buy the originals for about GBP 8 each, and the
    IRFP240/9240 for about GBP 5 each, so I'll have to decide whether I want
    the money or the hassle.
    > Good luck
    > Todd
    That's all been really helpful, I'll get on to it next weekend.
    Lee.
    <SNIP>
    Lee Collier, Jul 18, 2004
    #5
  6. Lee Collier
    Lee Collier Guest
    On Sat, 17 Jul 2004 14:16:09 +0000, Woody wrote:
    <SNIP>
    > fuses.
    The probing I've done so far suggests they've failed open, but I'll give
    that a go in a minute.
    Good point, although I am comparing good side with bad side - my DVM
    is turning on both of each pair on the good side but on the bad side the
    N-channel devices are turning on OK but the P-channel are not
    #6
    1. Advertisements
Similar Threads
  1. lynch
    594
    lynch
    Aug 29, 2003
  2. lynch
    404
    Nico Coesel
    Sep 1, 2003
  3. lynch
    373
    lynch
    Sep 1, 2003
  4. electronoobz
    Ruby amp debugging help
    electronoobz, Dec 22, 2012, in forum: General Electronics Chat
    25
    1,447
    electronoobz
    Dec 29, 2012
  5. AznGothic
    MOSFET Transistor replacement....
    AznGothic, May 13, 2013, in forum: Electronics Repair
    12
    997
    AznGothic
    May 14, 2013
Loading...
