MONITOR: Connector Pins Broken (How do I Repair?)
Discussion in 'Electronic Repair' started by drake, Jul 28, 2003.
  1. drake
    drake Guest
    I have a TVM 4LR VGA 14" computer VDU.
    4 of the 15 pins in the cable connector are broken. The Monitor worked
    fine when 3 were broken before. The broken pins are 5,9,12,15.
    Can anyone tell me which one is the critical pin amongsts these?
    I've looked around, and it seems the only way to salvage the monitor
    is to either replace the
    cable or the connector... both ways involve a lot of work. (But if
    this is the only way, I will do it.
    Will the small wires inside the cable have identifying coloured
    insulation... or will I have
    to use a multimeter? Is there any link to a site describing how to
    rewire a new connector?)
    Dumb Idea: Can I replace the pins in the connector by clipped paper
    pins of same dimension/size?
    Which I'll solder (or superglue) to keep in position? It seems this
    should work fine... but it seems
    too easy... what is the catch?
    Your comments/advice will be appreciated.
    TIA,
    Drake Lars
    drake, Jul 28, 2003
    #1
    1. Advertisements
  2. (drake) writes:
    > Hi,
    Are you sure they are broken? The 4 pins you mention should not be
    critical to basic monitor operation. Perhaps, there is something
    else wrong with it.
    6
    1 Red (Analog) 6 Red Return 11 (ID0) GND (Color) 11. . . 1
    2 Green (Analog) 7 Green Return 12 (ID1) NC (Color) . . .
    3 Blue (Analog) 8 Blue Return 13 Horizontal Sync . . .
    4 Reserved 9 No Connect 14 Vertical Sync . . .
    5 Ground 10 Ground 15 No Connect . . .
    15 10 5
    or
    6
    1 Red (Analog) 6 Red Return 11 Monitor ID0 (opt.) 11. . . 1
    2 Green (Analog) 7 Green Return 12 Data (SDA) . . .
    4 Reserved 9 +5 VDC (frm host)* 14 Vertical Sync . . .
    5 Return 10 Sync return 15 Data clock (SCL)* . . .
    15 10 5
    depending on how old it is.
    > is to either replace the cable or the connector... both ways involve
    > a lot of work. (But if this is the only way, I will do it.
    If there is indeed a pin problem, that's about the only way to
    deal with it. You can't really get at the inners of the connector itself
    usually because it is potted.
    > insulation... or will I have > to use a multimeter? Is there any
    > link to a site describing how to rewire a new connector?)
    No standard, you'll have to use a multimeter.
    Not way to assure a reliable attachment. And, then if a piece of the
    clip gets stuck in your video card connector, no way to get it out.
    --- sam | Sci.Electronics.Repair FAQ Home Page: http://www.repairfaq.org/
    | Mirror Site Info: http://www.repairfaq.org/REPAIR/F_mirror.html
    Important: The email address in this message header may no longer work. To
    contact me, please use the Feedback Form at repairfaq.org. Thanks.
    Sam Goldwasser, Jul 28, 2003
    #2
    1. Advertisements
  3. drake
    Jerry G. Guest
    Not all the pins are used, but if your broken pins are necessary, then
    the complete connector or cable harness must be changed.
    If you are not skilled and equipped for this type of work I would
    suggest you give it to a service centre to put on a new connector for
    you. It is a difficult repair for someone who is not experienced with
    this type of work. If you cross some of the wires, make a short, or
    make a cold solder connection while doing this, it will not be a good
    situation.
    This would not be a very expensive repair when done by a service centre.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    Instruments http://www.zoom-one.com/glgtech.htm
    "drake" <> wrote in message
    news:...
    TIA,
    Drake Lars
    Jerry G., Jul 28, 2003
    #3
  4. drake
    Quadrajet1 Guest
    << Hi,
    Can anyone tell me which one is the critical pin amongsts these? >>
    Don't worry, the pins are not "broken" but were probably never put in in the
    first place. It worked that way since it was new, no reason why it shouldn't
    keep working.
    Seeing how it's a no-name 14" monitor, just trash it and get a good one.
    Quadrajet1, Jul 28, 2003
    #4
  5. drake
    Dave D Guest
    "Jerry G." <> wrote in message
    news:bg3p94$a3l$...
    > situation.
    The question is, is it worth getting a 14" monitor professionally repaired?
    IMO unless there is something very special about this monitor it is scrap.
    Especially considering it is likely there's an internal fault, it doesn't
    appear to be the broken pins causing the problem.
    Dave D, Jul 28, 2003
    #5
  6. drake
    Dave D Guest
    news:...
    > Hi,
    Don't do that, you risk damaging your graphics card.
    What does the monitor do, if anything? Does it stay in standby, missing
    colours, sync problems? A little more info would be very useful.
    #6
  7. drake
    drake Guest
    > Dave
    Ok... the screen is blank.. it does not switch on atall (or else you
    can hear a screen switch on with that "thishoooooooooooooooeeeeeee"
    sound.
    Only the LED is on, all the time. It does not blink atall (as it would
    if the RAM or something were lose). The comp is working fine with a
    borrowed monitor for now.
    Lars
    drake, Jul 29, 2003
    #7
  8. drake
    mike Guest
    drake wrote:
    > Hi,
    > TIA,
    > Drake Lars
    The pins are usually hollow. PUt solder paste in the hole. Stick a tiny
    wire in the hole, slide on a pin from another connector. Heat to melt
    the solder paste. Plug it into the video card and don't ever take it
    out. The connection is not very strong.
    mike
    400cc Dirt Bike 2003 miles $495
    Police Scanner, Color LCD overhead projector
    Tek 2465 $800, ham radio, 30pS pulser
    mike, Jul 29, 2003
    #8
  9. drake
    drake Guest
    mike <> wrote in message news:<>...
    > mike
    Super idea!!! Thanks.
    Have you tried this before?
    Rishi
    drake, Jul 30, 2003
    #9
  10. drake
    mike Guest
    >>mike
    > Rishi
    Yes, it works great.
    But I meant what I said about the solder paste.
    If you try to use wire solder, you'll just make
    a big mess. If you get solder on the outside of the pins
    it will ream out your video card connector, if it goes in at all.
    mike
    mike, Jul 30, 2003
    #10
    1. Advertisements
Similar Threads
  1. Keith
    818
    Wayne
    Aug 29, 2004
  2. Replies:
    1,017
    James Sweet
    Sep 3, 2005
  3. Drew Cutter
    6
    469
    Steve Spence
    Sep 14, 2005
  4. Don McKenzie
    Godzilla lives underneath Japan.
    Don McKenzie, Mar 14, 2011, in forum: Hobby Electronics
    26
    1,168
    jones
    Mar 27, 2011
  5. devatu
    RS485 15 pins to rs 485 9 pins cable?
    devatu, Sep 11, 2014, in forum: Electronics Repair
    655
    Harald Kapp
    Sep 11, 2014
Loading...
